American Spirit / Falcon Owners
Old February 9th 13, 08:27 PM posted to rec.aviation.soaring
Default American Spirit / Falcon Owners
Does anyone on this forum currently own/fly and American Falcon or Spirit? I am keen to talk with you. Please send me an email off the forum ) or give me a call 250-792-4850.
Thanks,
Andrew Doepner
Old February 10th 13, 02:21 AM posted to rec.aviation.soaring
Bob Kuykendall
Thanks,
Andrew Doepner
Andrew, do you have one of those ships or kits?
Thanks, Bob K.
http://www.hpaircraft.com
Old February 11th 13, 05:09 AM posted to rec.aviation.soaring
Thanks,
Andrew Doepner
Thanks, Bob K.
Bob,
I do not own one. I am contemplating buying one and am looking for more information from current owners and former or current builders.
Andrew
Old February 11th 13, 02:58 PM posted to rec.aviation.soaring
Jonathon May[_2_]
On Feb 9, 12:27=A0pm, wrote:
=20
Spir=
(doep=
=20
=20
Thanks,
=20
=20
Andrew Doepner
=20
=20
=20
=20
=20
=20
Thanks, Bob K.
=20
Bob,=20
inf=
Andrew
I appologise right from the strart if Iv'e got this wrong.
There was a thread on this forum about a mold taken off a crashed ventus
and used for a short production run,was that mixed up with the spirit?
Old February 11th 13, 05:46 PM posted to rec.aviation.soaring
Bob Kuykendall
Andrew, there are a couple of things you need to know about the Spirit/
Falcon:
* Full disclosu I offer a competing sailplane kit, so anything I
tell you should be automatically suspect. You have to do your homework
on this.
* Static tests of the as-originally-designed wing structure have
failed in static test at less than the design load limit; the wing
should have been good for at least 1.5 times the design limit. The
problem seems to have been shear failure of the wing root rib where
the transverse pin on the opposite wing spar plugs into it.
* Fixes for the root rib shear issue were designed and at least one
builder tested them. Make sure you know what the fixes are and how to
implement them.
* There are a number of ASC ships that are operational and get flown
regularly, so it is apparently possible to make a usable sailplane out
of one.
* I have satisfied myself that the Spirit and Falcon are relatively
direct copies of a crashed Ventus that was used to make the ASC molds.
However, I haven't gotten any of the remaining principals to go in
record to that effect.
* ASC founder Tor Jensen was killed in 2006 in a motorcycle accident
near Reed's Pinnacle in Yosemite, so he is not available to offer
advice.
* Ralph Luebke seems to be the go-to guy for the various fixes and
upgrades, I wouldn't consider buying a kit without talking with him
about it.
* Marty Eiler of California City flew most of the ASC ships and knew
Tor well; I also recommend you talk with him before buying any ASC kit
or ship.
Wandering off topic, I learned a lot about sailplane design and
development from watching a couple of ASC kits go together at a shop
in Fremont, California:
* Big floppy wing shells and fuselage shells are a real pain for the
builder to align and join, and it is a huge problem if they are
aligned wrong. That is something best done at the kit factory.
* Integrity of the basic structure is key. Static tests to at least
design limit load must be performed and documented.
* Detail design is important in and of itself.
Thanks, Bob K.
Old February 11th 13, 06:32 PM posted to rec.aviation.soaring
Jonathon May[_2_]
builders.
Falcon:
on this.
implement them.
of one.
advice.
about it.
or ship.
Thanks, Bob K.
Thank you Bob for laying it out so clearly,I was worried I was stirring the
waters with little knowledge
Old February 11th 13, 07:05 PM posted to rec.aviation.soaring
JS
Tom Riley built and is regularly found flying an exceptionally good example of the ASC Spirit. It is based in Tehachapi, CA.
Old February 11th 13, 08:06 PM posted to rec.aviation.soaring
Wallace Berry[_2_]
In article
or ship.
I visited that shop once. They had one ASC ship partially assembled and
a set of fuselage shells at that time. I do remember the pieces all
being very floppy. The guy working on them was not at all complementary
of the kit. It was supposed to go together without the need for jigs
(fat chance). He was especially unhappy with trying to close up the
trailing edge of the wings. Apparently, it was hard to get it aligned
and clamped shut before the resin would start to go off. I seem to
remember him saying something about needing 10 guys with little cups of
resin to close the wing.
That guy also told me that it was copied mostly from a Ventus, but that
the cockpit area of the fuselage was bit deeper, thus it would not quite
fit in a clamshell trailer set up for a Ventus. Seems like ASC had their
own trailer design.
WB
Old February 12th 13, 03:34 AM posted to rec.aviation.soaring
Frank Whiteley
for more information from current owners and former or current builders..
Falcon:
on this.
implement them.
of one.
advice.
about it.
or ship.
Thanks, Bob K.
Ralph cooked a wing root fix for post build which results in a bump. Contact Dr. Mark Maughmer at Penn State for a construction fix. At least one kit went there for his sailplane design program. Another kit is at Mississippi State. Contact the club. It was nearing completion last year. There was a 95% completion in AZ a couple of years ago. There is a 95% completed prototype in CA according to a recent message. There was one for sale in Boulder over a year ago.
AFAIK, none have failed in flight.
Frank Whiteley
Old February 14th 13, 03:02 PM posted to rec.aviation.soaring
Paul Moggach
All of the molds, and spare parts etc. for the Spirit now reside in
Toronto, Canada along with one flying example, and one kit, and are sitting
collecting dust currently.
Looking for the American Falcon Richard Sawyer Soaring 1 June 17th 08 10:10 PM
Spirit, concluded - Spirit - 17 - on tour orchard beach maine.jpg (1/1) Mitchell Holman[_2_] Aviation Photos 0 May 23rd 07 01:00 PM
Spirit, concluded - Spirit - 16 - on tour PierreSD.jpg (1/1) Mitchell Holman[_2_] Aviation Photos 0 May 23rd 07 01:00 PM
Spirit, concluded - Spirit - 15 - on tour littlefalls_mn.jpg (1/1) Mitchell Holman[_2_] Aviation Photos 0 May 23rd 07 01:00 PM
NCO earns American Legion Spirit of Service Award Otis Willie Military Aviation 0 June 26th 04 10:31 PM
