FAA Plans to Change to Radios with 8.33 MHz spacing?
Old April 11th 13, 10:33 PM posted to rec.aviation.soaring
Paul Remde
Default FAA Plans to Change to Radios with 8.33 MHz spacing?
Hi,
I imagine someone on this newsgroup can point me in the right direction on a
technical/FAA question.
Becker offers 2 versions of their AR6201 radio. The original version has
frequency spacing that can be set to either 25 mHz or 8.33 mHz. The new,
slightly lower cost option has frequency spacing fixed at 25 MHz It is my
understanding that the 8.33 MHz spacing is required in Europe, but not
currently in the USA. Customers are asking me whether the FAA has any plans
to go to the 8.33 MHz spacing in the near future - so they can be better
equipped to select the radio version that makes sense. At a recent soaring
seminar someone stated that they thought the FAA was going to require radios
with the 8.33 MHz spacing starting in 2020.
Can anyone help me?
Thank you in advance.
Paul Remde
Cumulus Soaring, Inc.
Old April 11th 13, 10:45 PM posted to rec.aviation.soaring
Richard[_9_]
On Thursday, April 11, 2013 2:33:51 PM UTC-7, Paul Remde wrote:
Hi, I imagine someone on this newsgroup can point me in the right direction on a technical/FAA question. Becker offers 2 versions of their AR6201 radio. The original version has frequency spacing that can be set to either 25 mHz or 8.33 mHz. The new, slightly lower cost option has frequency spacing fixed at 25 MHz It is my understanding that the 8.33 MHz spacing is required in Europe, but not currently in the USA. Customers are asking me whether the FAA has any plans to go to the 8.33 MHz spacing in the near future - so they can be better equipped to select the radio version that makes sense.. At a recent soaring seminar someone stated that they thought the FAA was going to require radios with the 8.33 MHz spacing starting in 2020. Can anyone help me? Thank you in advance. Paul Remde Cumulus Soaring, Inc.
Google can help.
Richard
www.craggyaero.com
Old April 12th 13, 12:11 AM posted to rec.aviation.soaring
Paul,
Am I missing something here? Don't we currently have 0.25 MHz spacing and
isn't the plan to divide that into three channels which would make 0.0833
MHz spacing?
Respectfully,
"Paul Remde" wrote in message ...
Hi,
Can anyone help me?
Paul Remde
Old April 12th 13, 12:19 AM posted to rec.aviation.soaring
Andrzej Kobus
On Apr 11, 5:33*pm, "Paul Remde" wrote:
Hi,
Becker offers 2 versions of their AR6201 radio. *The original version has
frequency spacing that can be set to either 25 mHz or 8.33 mHz. *The new,
slightly lower cost option has frequency spacing fixed at 25 MHz *It is my
currently in the USA. *Customers are asking me whether the FAA has any plans
equipped to select the radio version that makes sense. *At a recent soaring
Can anyone help me?
Paul Remde
I don't think that would fly. This is not Europe (luckily) where they
have mandate to swap ALL radios by 2018. I could see a requirement
being introduced for such channel spacing in busiest airspace some
time into the future or above certain FL. In Europe the requirement
was introduced in 1994 and it only required 8.33 spacing for above
FL245 then with time it was pushed down to be generally mandated by
2018.
Old April 12th 13, 12:34 AM posted to rec.aviation.soaring
Andy[_1_]
On Thursday, April 11, 2013 4:11:12 PM UTC-7, Wayne wrote:
Paul, Am I missing something here? Don't we currently have 0.25 MHz spacing and isn't the plan to divide that into three channels which would make 0.0833 MHz spacing? Respectfully, Wayne
Only thing missing is the correct placement of the decimal point
25kHz, 8.33kHz
Andy
Old April 12th 13, 03:12 AM posted to rec.aviation.soaring
Bob Kuykendall
On Apr 11, 2:33*pm, "Paul Remde" wrote:
... *At a recent soaring
I will be someewhat surprised if we get to 2020 and we are still using
what we think of today as "aircraft radios." I think that by then we
will find that the bandwidth dedicated to those old grampa boxes will
have been divided up and auctioned off, and we will be communicating
over a system based on mobile phone infrastructure.
If I'm wrong, I'll buy you a beer at the 2020 SSA convention. Offer
limited to the first 24 "I told ya sos."
Thanks, Bob K.
Old April 12th 13, 03:43 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
On 4/11/2013 7:12 PM, Bob Kuykendall wrote:
On Apr 11, 2:33 pm, "Paul Remde" wrote:
... At a recent soaring
Is there still a premium for the extra channels? The last panel mount
radio I bought had 8.33 khz spacing (you can disable it for easier
tuning). It was only $23 more than their 25 kHz spacing unit.
email me)
Old April 12th 13, 03:53 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Maybe over the ADS-B system? or something like the FRS "walkie-talkies"?
Dump the AWOS transmissions because we'll get all our weather over
ADS-B? Hey, my next glider can already be ordered with it!
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old April 12th 13, 04:06 AM posted to rec.aviation.soaring
Bill D
Thanks, Bob K.
I've got a feeling you'll win that bet. By 2020, the 2 meter AM simplex air-band will be nearly 100 years old and very likely the last of its kind in use. It's way past its use-by date. There are better ways to communicate..
Old April 12th 13, 04:22 AM posted to rec.aviation.soaring
Frank Whiteley
On Thursday, April 11, 2013 3:33:51 PM UTC-6, Paul Remde wrote:
Hi,
Can anyone help me?
Paul Remde
http://hraunfoss.fcc.gov/edocs_publi...-11-1403A1.pdf
http://www.uspa.org/Portals/0/Downlo...C-10-103A1.pdf
Don't know about the FAA, but the FCC permits some use under Part 87. Haven't found a mandate, yet.
Frank Whiteley
Contest Grid Spacing? ContestID67[_2_] Soaring 3 June 1st 11 03:29 AM
Long EZ plans, Mini IMP plans, F4U Corsair plans, materials, instruments for sale reader Home Built 1 January 26th 11 01:40 AM
Duster Plans For Sale - BJ-1b fullsize sailplane plans WoodHawk Soaring 0 April 25th 05 04:37 AM
[igc-discuss] To change or not to change... rules ? Denis Soaring 0 February 16th 05 07:24 PM
U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* JStONGE123 Military Aviation 1 May 11th 04 06:22 AM
