Ipaq 4700 question
Old May 1st 13, 01:42 PM posted to rec.aviation.soaring
Nick Kennedy
Default Ipaq 4700 question
Hi Gents
I left my ipaq 4700 unplugged for a couple of years and now it seems to be
really dead. I plugged it in for a couple of days and hit the soft reset,
nothing, no light at the top. Is there anyway to revive this little guy?
Nick Kennedy
Old May 1st 13, 04:06 PM posted to rec.aviation.soaring
Uncle Fuzzy[_2_]
On Wednesday, May 1, 2013 5:42:58 AM UTC-7, dogger wrote:
Hi Gents I left my ipaq 4700 unplugged for a couple of years and now it seems to be really dead. I plugged it in for a couple of days and hit the soft reset, nothing, no light at the top. Is there anyway to revive this little guy? Nick Kennedy
Very likely you will need to replace the battery. At least it's easy on the 4700 series! With it plugged in, you might try a hard reset, which involves holding at least three of the buttons (I don't remember which) and hitting the recessed reset button with the stylus. I don't have the procedure handy, but I've found it by 'googling' it before.
Old May 1st 13, 08:40 PM posted to rec.aviation.soaring
quietpilot
I have an 5555 that behaves is the same way. The main battery is fine but inside there is a little internal disk shaped one that holds a charge when swapping the main battery. Disconnecting and reconnecting this resurrected it from the dead a number of times. Its fine until left off power for over a few months or so.
It and its little brother are free at
http://www.glidersource.com/cgi-bin/post.cgi?id=281
Old May 1st 13, 08:53 PM posted to rec.aviation.soaring
Maciek K.
make sure the battery lock switch is in its right position.
Maciek
Old May 1st 13, 09:16 PM posted to rec.aviation.soaring
Gordon Walker[_2_]
It would also be a good idea to replace the back-up battery whilst
you are at it. Takes 2 minutes and costs about £2, so no big deal.
http://www.youtube.com/watch?v=cYwc_-ISnsA
Old May 2nd 13, 01:23 AM posted to rec.aviation.soaring
Peter von Tresckow
Buy an Oudie... Or something similar
Old May 2nd 13, 03:04 AM posted to rec.aviation.soaring
Hi Gents
Nick Kennedy
There is a battery INSIDE that keeps certain settings alive - one of the settings is that battery can be charged using the plug, otherwise plugging it into charger wont make any difference. Replace the inside battery and then replace the regular battery at the back with one that still holds some charge. Once powered up change settings to charge via the usb. Now you can re-charge all of the other batteries that you thought are dead and useless...
Old May 2nd 13, 04:17 AM posted to rec.aviation.soaring
Paul Remde
Hi,
I'm not sure my experience with my iPaq hx4700 agrees with the note below
about the internal battery. The main battery on my iPaq hx4700 is fine, but
the backup battery died many years ago. The unit functions just fine. The
main battery charges fine. But I know the backup battery is dead because if
I remove the main battery the unit loses all its internal memory and
settings. I'm not motivated to replace the backup battery. I have one but
I haven't installed it yet.
I only keep the iPaq hx4700 because I want to be able to run SeeYou Mobile
and Glide Navigator II on it when I need to support customers that use those
programs on a PDA.
I suspect that replacing the main battery will solve the problem with the
"dead" unit below. Or perhaps the unit is really dead (not battery
related).
I sell the Naviter Oudie 2, so I'm biased, but I can honestly say that I
highly recommend it. It is a great product. One feature I love is that it
has non-volatile memory. No data gets lost and nothing needs to be reset if
the main battery gets low. It just works. I also love that Naviter
stripped out all the Windows software. I used to spend a lot more time on
the phone helping customers work Windows CE on a PDA. That is not necessary
with the Oudie.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
_________________________________
Hi Gents
Nick Kennedy
useless...
Old May 2nd 13, 07:56 AM posted to rec.aviation.soaring
Hi Gents
I left my ipaq 4700 unplugged for a couple of years and now it ems to be
Nick Kennedy
I bought a replacement battery for my 4750 a few years ago he http://www.pdasmart.com/ I have no interest in the company personally, just know that they sell the correct batter for that unit.
Old May 2nd 13, 05:15 PM posted to rec.aviation.soaring
JohnDeRosa
One comment based on a IPaq model 2215 so may not relate to your 4700.
The battery cover of the 2215 must be in place for the unit to power
up. The difference between "in place" and "not in place" could be
used for microscopic scientific measurements. I had the cover come
loose (ever so slightly) in flight and the unit powered off, which was
a lot of fun (not). Took me a while to figure out what was going on.
There is a small tab on the battery cover that pushes a switch telling
the unit life is good. Of course this tab often breaks. Of course a
replacement cover is difficult and expensive to come by. Fix =
gaffers tape on the cover. I never understood what they were trying
to protect me from. I suppose the lithium battery but sheez.
Am I bitter? Nah. I switched to an Oudie!
YMMV.
- John
FS: Ipaq 4700 + Winpilot Pro Ramy Soaring 0 January 21st 12 05:25 AM
Instruments and iPaq 4700 for sale, USA Chris Soaring 1 November 3rd 09 01:34 PM
Winpilot pro and Ipaq 4700 locking up. joesimmers Soaring 5 July 17th 08 05:42 AM
IPAQ 4700/4705 Doug LS4 Soaring 9 January 31st 06 01:01 PM
New iPAQ 4700 Paul Remde Soaring 2 October 9th 04 11:06 PM
