Glider Crash in Shirley, NY
Old May 5th 13, 02:03 AM posted to rec.aviation.soaring
Default Glider Crash in Shirley, NY
It's a privilege to continue to learn from you Chris. :-)
MM
Old May 5th 13, 05:52 PM posted to rec.aviation.soaring
Dan Marotta
I flew my LAK-17a yesterday with 2 gallons of water in the tail tank, none
in the wings. The feel was definitely different on takeoff but not
difficult. At altitude, I lowered landing flaps and slowed to 40 KIAS
before the glider gently dropped the nose. A little release of back
pressure and I was flying again.
Spins are prohibited per the flight manual so I kept the rudder neutral.
"Chris Rollings" wrote in message
At 06:32 05 May 2013, Jim White wrote:
At 19:05 04 May 2013, Chris Rollings wrote:
At 14:55 04 May 2013, wrote:
On Friday, May 3, 2013 11:03:29 AM UTC-5, kirk.stant wrote:
On Friday, May 3, 2013 8:21:53 AM UTC-7, Waveguru wrote:
=20
recovers nicely once it departs.
Agreed but the 32s I've flown required positive forceful control inputs
to
initiate recovery. Virtually every other glider I've flown will begin
to
r=
ecover merely by relaxing back pressure and applying a touch of
opposite
ru=
dder. The 32 is one of my favorite machines to fly but it's spin
characteri=
stics and recovery are somewhat unique. Whatever the causal factors in
thi=
s accident it's terrible to lose yet another of our comrades.
A fairly large number of German single-place glass gliders have similar
characteristics, albeit with somewhat lower control forces but the same
deflections required, particulary with the C of G in the aft part of the
range.
Which ones Chris? Both gliders I have owned come out just by thinking
about
it. Discus B and ASW27.
LS7, Ventus B & C (couldn't fit in the A so never tried it), ASW20 and
ASW24 (only at aft C of G), lots of others.
Old May 5th 13, 06:15 PM posted to rec.aviation.soaring
I have only had a couple flights in a 2-32. My instructor specifically warned me about the spoilers (dive brakes). Unlike spoilers on most modern gliders, these things actually do brake or slow down the airspeed when applied. It takes a conscious effort to maintain proper airspeed when using the spoilers on approach. My instructor also warned me about the tendency of the 2-32 to drop a wing and spin when pushed beyond its limits. The impression I got was that while it seems easy to fly, the 2-32 is not forgiving.
Old May 7th 13, 10:23 PM posted to rec.aviation.soaring
As part of an aerobatics course, we used a 2-32 for all the spin training and really wrung it out trying all kinds of things to screw it up and recover. The 2-32 does do some weird things. For example, if you put the control inputs in to recover in the wrong order, it may not recover. You have to go back to the full spin position (rudder in direction of spin and stick full back) and start over. Sometimes the spin would stop and it would immediately spin the other way. In training we could get quite a few turns in, trying to accelerate the spin, slow it down, mess it up on purpose and recover, but we had plenty of height to work with. I've had flights where the instructor would just say, " that was interesting, never saw it do that before." One experienced instructor (now and aerobatics instructor) referred to a spin in a 2-32 as a "come to Jesus" moment. Anyone wanting to really learn all about spins should get some specialized training in a 2-32 before the last of them is unfortunately destroyed and people flying them recreationally should make sure they are truly proficient and comfortable with spins. There's a reason NASA bought one and outfitted it with equipment to try to better understand what happens in a spin.
Info req: Altitude record breakers Michael Randrup and Walter Shirley Krztalizer Military Aviation 4 May 25th 11 05:42 PM
Glider crash kills Sydney man Mal Soaring 0 December 27th 06 11:03 AM
Glider Crash - Minden? Mitch Soaring 141 September 13th 06 08:31 PM
Scottish Glider Crash Mike the Strike Soaring 22 July 17th 06 12:00 AM
Glider/Skydiving Crash dm Soaring 0 September 27th 03 06:13 PM
