PowerFLARM firmware v3.00 released (feature complete)
Old May 16th 13, 02:10 PM posted to rec.aviation.soaring
Dave Nadler
Default PowerFLARM firmware v3.00 released (feature complete)
On Wednesday, May 15, 2013 11:43:05 PM UTC-4, Matt Herron Jr. wrote:
I guess I could unscrew my glare shield after every flight,
but I don't want to.
Get one of these:
http://www.frontx.com/pro/p1011_036.html
Oudie will hopefully display (nearly instantaneous)
IGC file download progress information.
Hope that helps,
Best Regards, Dave
Old May 16th 13, 02:58 PM posted to rec.aviation.soaring
Andrzej Kobus
Get one of these:http://www.frontx.com/pro/p1011_036.html
Hope that helps,
Best Regards, Dave
I have a brick and I still can't update a config file or firmware with
this cable because I don't see the LED on the unit. I actually need to
take off the canopy. Is there solution to this problem coming?
Shouldn't a display show this LED status through the communication
protocol. This a big pain in the rear end.
Old May 16th 13, 03:33 PM posted to rec.aviation.soaring
Luke Szczepaniak
Andrzej et all..
Turn off the flarm, plug in the USB stick, turn on the flarm, wait for
the display to go to the standard view (butterfly with gps and tx boxes)
- the update is done, pull out the USB go fly and have fun. No need to
watch the LED. If you want to verify the update was completed, turn off
the flarm, turn it back on and hit the display knob during boot up to
get flarm info. Installing the panel mounted USB extension makes life
even easier.
Don't let the tech drive you nuts, you will enjoy flying a lot more :-)
Luke
Old May 16th 13, 04:21 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Andrzej Kobus wrote, On 5/16/2013 5:58 AM:
Hope that helps,
Best Regards, Dave
Firmware _updates_ are rare, so that is a small inconvenience. Updating
the config file doesn't need any LED watching. It's not an "update", it
just reads a tiny file into the box. Just leave the USB stick in the
unit all the time, and it will read the file automatically in a fraction
of second as it starts up - no need to monitor it.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old May 16th 13, 04:52 PM posted to rec.aviation.soaring
Dan Daly[_2_]
I use this panel pass-through, and it works well: "NEUTRIK - USB A/B Pass Thru Black D-Type". I have a usb stick with a flashing LED to indicate it is accessing.
I would be nice if there were a menu item, perhaps below the one where you set it to download IGC files, where you could end recording and then download IGC files to the USB stick without cycling power. I have to turn off everything, then boot my 7007 (provides power to the Core) in order to get the IGC file out.
I am happy that I can transfer declarations from my Dell Streak/XC Soar via IOIO to the Core - very handy.
Old May 16th 13, 05:10 PM posted to rec.aviation.soaring
Luke Szczepaniak
There is an IGC flight download menu item in the new display firmware,
it seems to work fine.
Luke
Old May 16th 13, 05:11 PM posted to rec.aviation.soaring
Dave Nadler
Stop whining and follow the instructions.
Yes, display units report the status of software updates,
IGC file downloads, etc...
Really now...
  #28
Old May 16th 13, 05:32 PM posted to rec.aviation.soaring
Really now...
Uh, Oh, Dave is getting angry! However, I agree with him. Downloading a flight trace is so easy. Turn off the brick, insert usb-stick, turn it back on and wait until the normal butterfly thingy is displayed with green status boxes. The unit will only download files that are not already on the stick and it beats the 4800 baud rate that I get with ConnectMe out of my 302 by a factor of 20.
Herb
  #29
Old May 16th 13, 05:49 PM posted to rec.aviation.soaring
kirk.stant
Herb
No, Dave is getting frustrated, and I agree with him! If you upgrade the display software and look at the stupid thing - IT HAS AN IGC FILE DOWNLOAD FEATURE! So stick in the free USB extender, route it so you can reach it without taking your glider apart, then after your incredible flight, WITHOUT CYCLING THE PFB POWER, stick in your fancy thumb drive with the pretty lights, go to the igc file download menu, and get your stinking file so you can rush to post it on OLC to the amazement of the unwashed masses and adoration of the breathless groupies...
I would say RTFM, but of course the M isn't quite up to date yet...
Sheesh, don't you guys know any 14 year olds?
Kirk
66
  #30
Old May 16th 13, 06:11 PM posted to rec.aviation.soaring
A friend has proposed the idea of using a fiber-optic cable to bring the
Core's LED out to the panel. I don't know whether or not that will work,
but it is an interesting idea. He's looking into it.
Paul, I've done this. You need to get good quality fiber optic multi-strand and it works pretty well. There is some loss but under a shadowed part of the panel, you can see it just fine. The trick is to make a coupling for the fiber at the LED end.
Darren
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 26th 12 12:58 AM
PowerFLARM Portable - Firmware Update Available - Mode C Traffic Now Supported Paul Remde Soaring 24 January 22nd 12 02:50 AM
New ILEC SN-10 Firmware Paul Remde Soaring 5 August 25th 05 09:11 PM
v3.20 Firmware now out for Garmin 296 {nt} Cockpit Colin Piloting 0 March 8th 05 02:12 AM
Garmin 196 firmware update v3.1 released Aloft Piloting 0 August 13th 03 01:50 AM
