The battery on the V2 doesn't last long enough, and I'd like to supply the unit with some power from my on board 12V system. I know I can set up a cigar lighter plug in type connection to the mini connector at the bottom. But I'd like to use the DC connector at the top. What voltage and what type of connector can I use? Can I put 12V directly in with simple plug that fits?
	Guy  |
Hi Guy,
	I don't know what the "DC connector at the top" is, but the Vertica needs 5V power. Best Regards, Paul Remde Cumulus Soaring, Inc. wrote in message ... The battery on the V2 doesn't last long enough, and I'd like to supply the unit with some power from my on board 12V system. I know I can set up a cigar lighter plug in type connection to the mini connector at the bottom. But I'd like to use the DC connector at the top. What voltage and what type of connector can I use? Can I put 12V directly in with simple plug that fits? Guy  |
On Jun 2, 8:11*pm,  wrote:
	The battery on the V2 doesn't last long enough, and I'd like to supply the unit with some power from my on board 12V system. I know I can set up a cigar lighter plug in type connection to the mini connector at the bottom. But I'd like to use the DC connector at the top. What voltage and what type of connector can I use? Can I put 12V directly in with simple plug that fits? Guy You want something like this: http://www.glidertools.com/products/...rguider-avier/ (There are also alternative versions of this power-supply that may be less-expensive, if you don't normally deal in Euros) Enjoy, --Noel  |
On Sunday, June 2, 2013 9:45:11 PM UTC-7, noel.wade wrote:
	On Jun 2, 8:11*pm, wrote: The battery on the V2 doesn't last long enough, and I'd like to supply the unit with some power from my on board 12V system. I know I can set up a cigar lighter plug in type connection to the mini connector at the bottom. But I'd like to use the DC connector at the top. What voltage and what type of connector can I use? Can I put 12V directly in with simple plug that fits? Guy You want something like this: http://www.glidertools.com/products/...rguider-avier/ (There are also alternative versions of this power-supply that may be less-expensive, if you don't normally deal in Euros) Enjoy, --Noel If you just want power, you can buy a 12V - 5V down converter for about $5. Go to eBay and put in "12V USB power supply" as search terms. Pick one of a hundred suppliers or so. There are even ones with the mini USB cable attached. Most are Chinese based but you will still get it in 3 days. If you need power AND serial comm, then go to glidertools. I don't have a V2 but I thought it was the same thing as my Avier, there is no 5V plug on it except the mini USB. Don't plug 12V into the headphone jack - the result won't be pretty.  |
Sounds like he wants a power supply like the Socket Mobile plug supplies--the round push in connector that is close to the mini USB plug on the Vertica/AVier--that would leave the mini USB open.
	Don't know what size the socket moblie connector is, and the Avier/Vertica V2 doesn't come with a wall charger and a round 5V plug for the little hole that looks like it receives one. But is that a headphone jack and not a power supply jack? The Avier and Vertica V2 are the same device. I went with the cigarette lighter option for 7 bucks... Squeak  |
On Sunday, June 2, 2013 9:11:27 PM UTC-6,  wrote:
	The battery on the V2 doesn't last long enough, and I'd like to supply the unit with some power from my on board 12V system. I know I can set up a cigar lighter plug in type connection to the mini connector at the bottom. But I'd like to use the DC connector at the top. What voltage and what type of connector can I use? Can I put 12V directly in with simple plug that fits? Guy Thanks for all the comments. Glad to know the top connector is not a power input. It's labelled DC on one of the manual diagrams. For me, that meant DC power input. The V2 is the same as the Avier. I'll make sure it's 5V going in thru the USB mini. A car lighter plug-in to USB mini connector cable came with the computer. I think I'm good. Thanks again.  |
	The battery on the V2 doesn't last long enough, and I'd like to supply the unit with some power from my on board 12V system. I know I can set up a cigar lighter plug in type connection to the mini connector at the bottom. But I'd like to use the DC connector at the top. What voltage and what type of connector can I use? Can I put 12V directly in with simple plug that fits? Guy Squeaky, Yes indeed that hole in the top is for a head phone jack. I just checked it out. I'm I glad I asked here first before plugging in 12V. I too am going for the lighter plug-in. Having a cigarette lighter hole in the panel will look weird, but hey, it looks like the right, and simple, thing to do. Now, how am I going to run my Colibri GPS into this thing? No there's no end, is there? Guy  |
			 Quote:
On Tue, 04 Jun 2013 18:37:35 -0700, gwblood wrote:
	On Sunday, June 2, 2013 9:11:27 PM UTC-6, wrote: The battery on the V2 doesn't last long enough, and I'd like to supply the unit with some power from my on board 12V system. I know I can set up a cigar lighter plug in type connection to the mini connector at the bottom. But I'd like to use the DC connector at the top. What voltage and what type of connector can I use? Can I put 12V directly in with simple plug that fits? Guy Squeaky, Yes indeed that hole in the top is for a head phone jack. I just checked it out. I'm I glad I asked here first before plugging in 12V. I too am going for the lighter plug-in. Having a cigarette lighter hole in the panel will look weird, but hey, it looks like the right, and simple, thing to do. Now, how am I going to run my Colibri GPS into this thing? No there's no end, is there? Guy IMO cigar lighter plugs are good things to avoid: most of the time I spend more time pushing the buggers back into the socket than I do using whatever they're powering. However bits of them are useful: the cheapie cigar lighter USB charger you find in eBay is very easily improved. If you carefuly open up the plastic plug that fits the lighter, you'll find a tiny switch-mode 12v to 5v converter, complete with an LED to show when its on. Here's how to make it useful: - take it out of the plastic plug moulding - get a small box from Maplins (in the UK) or Farnells (anywhere) to house it - remove the 12v cigar lighter contacts and solder on some suitable wire that will connect to your glider's power supply. Add connectors etc to match your glider's electrical installation. - put the adapter (plus a fuse and holder if you want) in the small box, install behind your panel. Use grommets and strain relief where both leads exit the box. Optional: drill a small hole and press fit the LED in it so you can see it when you've screwed the top on the box and mounted: this is handy for trouble shooting. - thread the cable with USB through to where you've mounted the V2: this cable should still be attached to the circuit board. - job done. You've gotten rid of a big, unreliable cigar lighter socket and should now have a small, neat, installation. FWIW I've had a setup like this in my Libelle for 6 years now. Its never given any trouble at all. I used an IPAQ 36xx car charger as the basis because its rated for 5v at 1400 mA, rather more headroom than the 5v at 1000 mA of your typical Chinese USB charger. -- martin@ | Martin Gregorie gregorie. | Essex, UK org |  |
| Thread Tools | |
| Display Modes | |
| Vertica V3? | son_of_flubber | Soaring | 28 | January 10th 13 09:44 PM |
| WinPilot locked up my Vertica 2 PNA - help! | [email protected] | Soaring | 5 | January 1st 13 09:04 PM |
| EW Microrecorder External Power | [email protected] | Soaring | 4 | July 11th 12 02:03 AM |
| Ipad compatible bluetooth GPS which has an external antennasocket and external pwr input? | macpacheco | Instrument Flight Rules | 1 | November 12th 11 04:32 PM |
