Glider accident while filming commercial in 2011. NTSB Report updated
Old June 21st 13, 07:40 PM posted to rec.aviation.soaring
Frank Whiteley
Default Glider accident while filming commercial in 2011. NTSB Report updated
On Friday, June 21, 2013 11:25:30 AM UTC-6, noel.wade wrote:
On Friday, June 21, 2013 7:16:25 AM UTC-7, JohnDeRosa wrote:
Can anyone comment if the "steep nose high attitude" was intentional?
I don't think anyone can say exactly what was intentional, other than the deceased pilot.
I have heard - secondhand - that during the planning of the commercial they had wanted a shot from in front of the SUV looking back at it, with the glider rising suddenly & dramatically above it. Whether that was part of the final plans or whether they were trying to film that scene at the time of the accident is anyone's guess.
Frank - One thing to remember is that we do not _know_ if the pilot initiated the turn, or if it merely appeared so as the first phase of spin entry (i.e. a wing-drop). It is entirely possible the pilot was intending to land straight ahead but experienced an asymmetric stall (again, could've been the cross-wind, or a gust, or mechanical turbulence, or lack of coordinated controls, or whatever - we just don't know). I also don't think the satellite photo/maps show clearly if there are bushes or a fence between the runway and the large field - it is possible the pilot had better information about that than we do.
--Noel
Google Earth has pretty good images. There is at least a hedge and probably a fence at the airport boundary, which is about 90 yards past the pavement. There do not appear to be wires. The field may be hay production/pasture or something else. Could have been bales as late as October, ruling it out as an option.
I agree, wind may have been a factor, especially with the surrounding hills and mountains. I wouldn't read much into the Ellensburg winds though.
However, the rope break was clearly a contributing factor and might have been eliminated.
Frank Whiteley
  #32
Old June 21st 13, 07:54 PM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
Quote:
Originally Posted by View Post
I was supposed to do this commercial.
Instead the company went to the lowest bidder.
I had a much safer script for this and
it would have promoted soaring, but the
car company and the production company
had no interest in any of that. All
they wanted was the low hanging fruit,
which was a glider being jerked into
the sky by a car.
This is very typical in the film biz.
There is a lot I cannot talk about because
of the investigation.
It was a sad event that did not have to happen
and could have easily been avoided.
VI
Isn't that always the way, but then again the Astronauts all blasted off into space with stuff built by the lowest bidder.
Walt
  #33
Old June 21st 13, 08:46 PM posted to rec.aviation.soaring
UN
There are additional documents located in the NTSB Docket including witness statements from the driver, photographs of the broken towrope and a video of the accident scenario.
http://dms.ntsb.gov/pubdms/search/hi...KEN=7351 7888
On Friday, June 21, 2013 12:14:22 PM UTC-5, Frank Whiteley wrote:
On Thursday, June 20, 2013 1:53:31 PM UTC-6, Steve Leonard wrote:
http://www.ntsb.gov/aviationquery/br...FA010 &akey=1
Happened to be looking through the NTSB Database and saw that they updated the report about a month ago.
Some have said there's nothing new in this report. Indeed there remain some missing details, but there is also a new fact that I don't recall from the prior reports and my inquiries, including discussion with the observer in the back of the launch vehicle.
If the facts are correct, anyone involved in ground launching should have zeroed in on the rope. Nylon rope is very elastic compared to premium UHMWPE ropes, that is, nylon has some 16% elongation at 15% of breaking strength. UHMWPE rope elongation at 30% of breaking strength is under 1%.
Working limits of premium UHMWPE and steel wire ropes are 1/5 to 1/6 of breaking strength. During winch launching we tend to operate beyond these working limits regularly by loading to 1/4 to 1/3 of breaking strength with premium UHMWPE ropes, and presumably as high as 3/5 with the regular UHMWPE and steel wire ropes. For all practical purposes, there is minimal elongation.
Nylon rope's typical working limit is 1/12 of breaking strength. 5/16" nylon rope, as described in the report is rated from about 1490lbs to 3300lbs breaking strength depending on construction and processing. Most constructions are rated in the 1500lb to 2200lb BS range, which would indicate that a DG1000 could easily reach and exceed 1/1 with most nylon ropes and reach 2/3 with the best ropes assuming a black TOST weak link was used. Repeated [over]load cycles will accelerate fatigue and this rope would have been loaded near breaking strength repeatedly over the course of several launches. One can only imagine the elongation near the breaking point. Perhaps they started with a 200ft rope which was stretched to 234ft when it broke. 17% elongation. Breakage without any signs of appreciable wear would be expected within a very few launches. I'm not aware of any glider operations using nylon rope for ground launching. Steel, poly-types, and dacron, yes, but not nylon.
There is a large field off the end of runway 7. If the pilot thought he had enough height to attempt to circle to a landing, he definitely had this field as an option. The remainder of the conjecture would seem that he commenced a turn before resuming flying speed after the break.
Frank Whiteley
  #34
Old June 21st 13, 09:05 PM posted to rec.aviation.soaring
Steve Barter
http://www.gliding.co.uk/bgainfo/saf...hlaunching.htm
It's winch launching, not auto towing, but relevant. Some might find it
useful
and interesting.
  #35
Old June 21st 13, 09:49 PM posted to rec.aviation.soaring
Bill D
Frank Whiteley
Frank, that's all true but it's in the nature of ropes to break. Good ropes break less often than crappy ropes but they still break - that's just how it is. The trick is to never put oneself in a a position where a rope break causes an accident. Good pilots EXPECT the rope to break on every launch and have a plan to deal with it.
The NTSB supplemental data with the witness video clearly shows the pilot did not lower the nose, made no attempt to recover airspeed and (likely) started a turn leading to a stall and spin to impact. Nor does the video show any evidence the pilot made an attempt to stop the spin departure once it had begun.
Google Earth shows a 1400' plowed field off the departure end of runway 7. If this field was useable, the rope break was survivable provided the pilot promptly lowered the nose, recovered airspeed and landed ahead in the field.
  #36
Old June 22nd 13, 12:21 AM posted to rec.aviation.soaring
Don Johnstone[_4_]
To people unfamiliar with winch launching or auto tow the climb angle looks
very steep, and certainly is compared to an aero tow.
234 feet is very short for an auto tow rope and you would not expect the
glider to get more than 200 ft from that.
I have completed 10,000 winch launches and of those about 2000 have been
practice launch failures, about 100 for real. I have done about 200 auto
tow launches where the most common cause of lack of power is lifting the
driving wheels of the tow truck off the ground at the top of the launch.
Folowing a launch failure (rope break/loss of power)nearly all pilots take
the initial recovery automatically, moving the stick forward to adopt a
nose down attitude. This will always introduce negative G which in effect
reduces the wing loading on the glider meaning the stall speed is much
lower than is normally the case. If an attempt to turn is made at this
stage, as the effect of the negative G goes away, a stall may occur and if
aileron is applied and there is any bank a spin is most likely. A DG 1000
is one of the GRP gliders that will spin readily. A full recovery from a
spin at 200 ft is not possible.
This is why we teach the recovery as move the stick forward to adopt at
least the approach attitude AND wait until approach speed is gained. Then
make the decision as to whether you are going to land ahead or turn.
  #37
Old June 22nd 13, 12:28 AM posted to rec.aviation.soaring
the video is heart wrenching. my condolences to friends and family.
I was thinking, the flight is not unlike the second half of a very low pass which has been known to cause another accident in the recent past. Unfortunately done at far too slow of a speed of just 70mph for such a low altitude "pass". Just not enough energy for the pull up and maneuvering back around for landing.
  #38
Old June 22nd 13, 02:09 AM posted to rec.aviation.soaring
Bill D
least the approach attitude AND wait until approach speed is gained. Then make the decision as to whether you are going to land ahead or turn.
________________________
The math says you will do better to push the nose lower than the approach attitude both in recovering airspeed sooner and retaining as much altitude as possible.
Without the benefit of an angle of attack indicator, the greatest safety margin is to push the nose as far below the horizon as it was above at failure and hold it there until at least the "Yellow Triangle" airspeed is in hand. This "rule of thumb" prevents diving the glider into the runway from a low failure and provides a good margin at higher altitudes.
With an AOA indicator, if you chose, you could gently reload the wings at the top of the trajectory using an AOA equivalent to best L/D which results in the least loss of height. Since angle of attack determines whether the wing will stall, the airspeed at the beginning of the reload can safely be below the normal 1G stalling speed.
Speaking of AOA indicators and stick buzzers, does anyone think one might have saved this pilots life?
  #39
Old June 22nd 13, 02:10 AM posted to rec.aviation.soaring
Bill D
Excellent observation.
  #40
Old June 22nd 13, 02:28 AM posted to rec.aviation.soaring
Frank Whiteley
Frank Whiteley
Google Earth shows a 1400' plowed field off the departure end of runway 7.. If this field was useable, the rope break was survivable provided the pilot promptly lowered the nose, recovered airspeed and landed ahead in the field.
Hard to say from the report images whether the rope had any worry marks, but there are some discolorations in the break area. It appears to be reasonable quality rope, but nylon just is not the right media and is very low working limit for it's breaking strength and diameter. The recoil of the rope in the video is pretty interesting as the bulk of the rope bunches up in a clump only a few fuselage lengths behind the glider. If the rope had previously recoiled toward the release on the car during earlier launches, it's possible it was compromised by impacting the car or release hardware (hence the marks). One witness described seeing 6-8 inches of rope remaining at the car end.
Unfortunately the short out of focus view obscures any chance of seeing control deflections and possible pilot intent.
Ropes may be expected to break, but choice of rope makes a big difference.
Frank Whiteley
NTSB crash report, autopsy report- Stevie Ray Vaughan Mark. Piloting 5 March 22nd 20 11:17 PM
NTSB Report on Bill Phillips' Accident Ron Wanttaja[_2_] Home Built 63 September 29th 09 01:02 PM
Preliminary NTSB report on Walton accident ChuckSlusarczyk Home Built 11 July 12th 05 05:23 PM
Prelim NTSB report, Pilatus accident in PA vincent p. norris Piloting 15 April 11th 05 03:52 PM
NTSB Aircraft Accident Reports Updated Daily? [email protected] Owning 2 March 4th 05 02:25 PM
