Phoenix LSA / motorglider / towplane question
Old February 20th 14, 01:55 PM posted to rec.aviation.soaring
Tom K (TK)
Default Phoenix LSA / motorglider / towplane question
This is an attractive aircraft with a lot of room. It also says it can be used as a tow plane ?!?!
Does anyone have any experience with it as a tow plane?
Old February 20th 14, 08:27 PM posted to rec.aviation.soaring
150flivver
We used to have a Lambada that is like an earlier version of the Phoenix, I believe. It was only adequate for towing ultralights and very light gliders such as our PW-5. Visibility towards the rear was very limited.
Old February 21st 14, 11:52 AM posted to rec.aviation.soaring
https://www.youtube.com/watch?v=Go8cB8ZxUUI
Old February 21st 14, 03:16 PM posted to rec.aviation.soaring
Tom (2NO)
Looks like better climb rate than our Super Cub.
Old February 21st 14, 03:20 PM posted to rec.aviation.soaring
Mike the Strike
I witnessed launches using the 100-HP Samba (cousin to the Lambada) at the 2000 Worlds in South Africa. As I recall, they restricted it to 15-m ships.. With heavy ships at high density-altitude, acceleration and the take-off run appeared long. Climb rates were a bit lower than with more powerful tugs, as you would expect, but seemed to be satisfactory.
This class of aircraft should work fine as a tug at sea level with light gliders, but might be under-powered for launching ballasted ships or two-seaters at higher density-altitudes.
Let the experiment be done!
Mike
Question re towplane airworthiness (USA) Greg Arnold[_3_] Soaring 12 April 20th 10 06:12 PM
Pik-27 towplane Brad[_2_] Soaring 2 March 10th 09 12:01 AM
towplane mirrors Curt Cole Soaring 3 May 28th 04 02:40 PM
Towplane Mirror Thomas J Johnson Soaring 1 May 21st 04 10:36 PM
Phoenix AIM-54A (QUESTION) Krztalizer Naval Aviation 10 February 23rd 04 07:22 AM
