#41
On Thu, 17 Apr 2014 14:36:07 +0000, Wolf Aviator wrote:
At 22:31 16 April 2014, son_of_flubber wrote: I have a question about the history of soaring... (I'm not asking a practic= al serious question.) Has anyone tried and/or had any luck with a 'slow burn single use' solid ro= cket in a glider? It would have the advantage of high energy density, low = drag and quick start. I suppose that it might melt something important if = it were were mounted on the fuselage. What about a wing mount close to the= root? I know this idea sounds crazy, but a pop-up jet sustainer strikes me as onl= y slightly less outrageous. Germans did Me-163. I know that it had not an 'slow burn' solid rocket, but it was liquid fuel, but still it was glider with rocket engine ![]() .....but never something you could call a 'safe ride'. Regards Wolf http://youtu.be/WCej1kZInZk Cool video, though. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#42
Has anyone tried and/or had any luck with a 'slow burn single use' solid rocket in a glider? It would have the advantage of high energy density, low drag and quick start. I suppose that it might melt something important if it were were mounted on the fuselage. What about a wing mount close to the root? I know this idea sounds crazy, but a pop-up jet sustainer strikes me as only slightly less outrageous. Fritz von Opel in 1929. www.youtube.com/watch?v=vsqg28y_s3s Ed |
#43
At 20:41 17 April 2014, Edward Bittenbender wrote:
www.youtube.com/watch?v=vsqg28y_s3 Sorry, the youtube link should have read: www.youtube.com/watch?v=vsqg28y_s3s Ed |
#44
On 04/17/2014 10:30 PM, Renny wrote:
Unless I am missing something here, are you really not talking about the system in the Antares 20E or something very similar? The Antares is a purpose designed electric self launcher. It has a large set of batteries to provide the necessary energy, accommodated in a custom built open class airframe. I am thinking of a retrofit, pylon mounted, electric sustainer. The mass of the motor and batteries would be similar to the FES, (45kg) and easily carried by many existing pure sailplane designs. The biggest challenge would be to mount the batteries in the wings. If, as it seems from your message, you are talking about a retrofit, please be aware that there is a tremendous amount of complexity involved in an electric installation in a glider. Assuming you can work that all out, then you would have to deal with the bureaucracy of dealing with your local aviation authority such as the: FAA, EASA, etc, etc. With tremendous effort and money, it may actually be doable, but it may be virtually impossible to be able to legally fly your electric glider. In addition, the costs of such as system may be far more than the value of one's "pure" glider....It really is a "vexing" problem! I am aware that this is a non-trivial challenge. I addressed my question to Luka who has spent many years developing the FES system and getting it certified. He is probably the best qualified person to comment on the viability of this concept. Ian PS: My comments on modifying my LS3a were made with tong in cheek. Even if Luka did bring a suitable kit to market it probably would probably be better to start with a more modern airframe. At least I would have something to fly in the meantime! |
#45
On Thursday, April 17, 2014 12:49:31 AM UTC-4, Mike the Strike wrote:
Many of our emergency landing spots .... or smugglers landing spots near the border where you are likely to meet with armed villains). As a Yankee and fan of "Breaking Bad", I'm having a hard time sorting fact from fancy. A run-in with Banditos (or the DEA suspecting nefarious cargo in the glider) is a possibility? |
#46
On Thursday, April 17, 2014 2:46:21 PM UTC-7, son_of_flubber wrote:
On Thursday, April 17, 2014 12:49:31 AM UTC-4, Mike the Strike wrote: Many of our emergency landing spots .... or smugglers landing spots near the border where you are likely to meet with armed villains). As a Yankee and fan of "Breaking Bad", I'm having a hard time sorting fact from fancy. A run-in with Banditos (or the DEA suspecting nefarious cargo in the glider) is a possibility? One of our emergency strips not too far from the Mexican border is a semi-abandoned ranch strip that sees a lot of night-time use by smugglers. I landed there a few years ago and was retrieved by road uneventfully. A colleague who landed there more recently found two men had opened his canopy and were rifling through his cockpit after he'd walked away from his ship. They sped away on ATVs as he approached. Smugglers often have local ground support who use off-road vehicles and frequent deserted airstrips! An FES system has some appeal! Mike |
#48
On 04/18/2014 03:15 AM, Greg Arnold wrote:
Sounds similar to this project at DG: http://www.dg-flugzeugbau.de/?id=1070 That is a very interesting write up. However DG have chosen to mount the batteries in the fuselage with the motor. Some interesting points from DG's website: "The sink rate with the extracted motor is much better than the DG-1001T's sink rate due to the better aerodynamics and drag. So it was possible to keep on climbing in weak thermals although the engine was extracted." It seems "plummet mode" with this electric pylon sustainer is not nearly as bad as some of the anecdotes that Dave described in his presentation. "We also found during the development process that the available space and load allowance compared to the required battery is much better in the DG-1001 than in the "LS10-ste" which had been the original plan. This is why as a first step we have are developing the two-seater with an electric motor, and the LS10 will follow once a new generation of batteries is available." FES have put the motor on the front. DG needed a two seater to fit the motor into the fuselage with the batteries. If we are going to see a main stream electric pylon sustainer in existing single seater designs, it looks like the batteries will have to go in the wings. I also note that DG needed partnerships and government subsidies to get their electric sustainer off the ground. Clearly this is not a trivial exercise. According to http://www.front-electric-sustainer.com/technology.php FES use 2 off 15kg batteries. Total voltage is max 118V. If you could get one equivalent battery into each wing, that would be 59V DC per wing. Enough for a very nasty shock, but not quite as lethal as the 200V DC that DG talk about. With wing mounted batteries you could easily afford to carry 20kg or 25kg in each wing. This would allow for either heavier/safer battery technology, or more capacity. Bigger batteries would have a lower discharge "C" rate and hence a longer life (ie more charge/discharge cycles). Wing mounted batteries could be married to DG's pylon, motor and electronics. (Or FES motor and control electronics). Yup, I am just dreaming ... Are there any DG-1001 electric sustainer owners on this forum? I would love to hear some feedback! Ian |
#49
Following on the single-use solid fuel rocket sustainer idea...
Does the math/physics/dollars work for single-use (non-rechargeable) battery pack for FES? Scenario:Use once to avoid an expensive/dangerous landout, then replace the batteries. With a single-use FES, you would retain the sporting attitude/fun of flying a pure glider. You would only press the start button to 'save your a--'. It seems uneconomical to buy an expensive set of rechargeable batteries unless you plan to use them often. If I had a rechargeable FES, I would end up flying it like a motor glider (not that there is anything wrong with that). http://www.amazon.com/Duracell-Proce...size+batteries Ten years from now you could upgrade to rechargeable batteries. |
#50
On Friday, April 18, 2014 4:44:42 PM UTC-4, son_of_flubber wrote:
Does the math/physics/dollars work for single-use (non-rechargeable) battery pack for FES? A quick look seems to indicate that the energy density of non-rechargeable alkaline batteries (the flashlight kind) is somewhat better than rechargeable LI batteries (the cellphone type), so a single-use-FES is not on-the-face-infeasible. |
| Thread Tools | |
| Display Modes | |
| AS responds to the latest Ventus 2cxa | KevinFinke | Soaring | 3 | March 18th 09 04:45 AM |
| Ventus 2C W&B - 15M vs 18M | [email protected] | Soaring | 0 | March 29th 06 11:20 PM |
| FS: Ventus C | KO | Soaring | 9 | November 5th 05 01:58 AM |
| FS: Ventus C 17.6 | John Shelton | Soaring | 0 | November 16th 04 01:55 AM |
| FS Ventus C 17.6 | John Shelton | Soaring | 0 | November 15th 04 10:10 PM |
