Just purchased a used aircraft with a 5 year old Becker AR4201 radio that seems to work normally BUT no sound goes out on transmission. Previous owner says everything was fine prior to my purchase of the aircraft. No changes made. I am using the previous owner's Bose headsets. So I can understand the wiring was done correctly on initial installation.
The PTT click can be heard on the hand held radio opening the frequency, but no sound of the voice transmission is transmitted to the receiving handheld radio. Black triangle on top row shows the radio is transmitting. But no voice is coming through. Tried two different working headsets, one is a friends and is brand new. Same situation. All functions on screen are normal. No error codes. Receives transmissions from the handheld radio and also receives the ATIS loud and clear. What am I missing? RMM |
I don't know a lot about radios, at all, but my 4201 manual stated clearly that the transmit button should not be depressed if the antenna wasn't connected. Something about burning out the 'transmit amplifier' or something similar-sounding. Could that have been done? That statement was recently affirmed through a discussion with a fellow pilot in our club that had done just that on accident. He had to send it back to the factory for repair.
~Travis On Saturday, April 26, 2014 3:11:06 AM UTC-7, RMM wrote: Just purchased a used aircraft with a 5 year old Becker AR4201 radio that seems to work normally BUT no sound goes out on transmission. Previous owner says everything was fine prior to my purchase of the aircraft. No changes made. I am using the previous owner's Bose headsets. So I can understand the wiring was done correctly on initial installation. The PTT click can be heard on the hand held radio opening the frequency, but no sound of the voice transmission is transmitted to the receiving handheld radio. Black triangle on top row shows the radio is transmitting. But no voice is coming through. Tried two different working headsets, one is a friends and is brand new. Same situation. All functions on screen are normal. No error codes. Receives transmissions from the handheld radio and also receives the ATIS loud and clear. What am I missing? RMM |
Thanks Travis.. Antenna was always connected when we had the unit powered up. So no chance of the PTT being depressed without the antenna being connected. I did not see that warning in my reading of the manual though. We did attach a new connector on the antenna cable at the radio end. But the ground at the connector was checked before attempting the use the radio. The antenna receives fine, as mentioned. So that does not seem to be the issue. Your response is much appreciated. Thanks RMM On Sunday, April 27, 2014 2:22:53 AM UTC+10, TravisBrown73 wrote: I don't know a lot about radios, at all, but my 4201 manual stated clearly that the transmit button should not be depressed if the antenna wasn't connected. Something about burning out the 'transmit amplifier' or something similar-sounding. Could that have been done? That statement was recently affirmed through a discussion with a fellow pilot in our club that had done just that on accident. He had to send it back to the factory for repair. ~Travis |
Ah. Right you are, Sir.
I checked my 'hardware' section of my aircraft's documentation, and see that I was thinking of this: "Dummies Guide to Aircraft Antennas" hosted at Cumulus-Soaring. https://www.cumulus-soaring.com/xcom...es%20Guide.pdf Lots of good info for me in there, including that bit about the antenna being connected (and in reasonable tune) prior to depressing the PTT. Don't know why he had to call me a 'dummy,' though. :-) ~Travis On Saturday, April 26, 2014 9:48:57 AM UTC-7, RMM wrote: Thanks Travis.. Antenna was always connected when we had the unit powered up. So no chance of the PTT being depressed without the antenna being connected. I did not see that warning in my reading of the manual though. We did attach a new connector on the antenna cable at the radio end. But the ground at the connector was checked before attempting the use the radio. The antenna receives fine, as mentioned. So that does not seem to be the issue. Your response is much appreciated. Thanks RMM On Sunday, April 27, 2014 2:22:53 AM UTC+10, TravisBrown73 wrote: I don't know a lot about radios, at all, but my 4201 manual stated clearly that the transmit button should not be depressed if the antenna wasn't connected. Something about burning out the 'transmit amplifier' or something similar-sounding. Could that have been done? That statement was recently affirmed through a discussion with a fellow pilot in our club that had done just that on accident. He had to send it back to the factory for repair. ~Travis |
Just purchased a used aircraft with a 5 year old Becker AR4201 radio that seems to work normally BUT no sound goes out on transmission. Previous owner says everything was fine prior to my purchase of the aircraft. No changes made. I am using the previous owner's Bose headsets. So I can understand the wiring was done correctly on initial installation. The PTT click can be heard on the hand held radio opening the frequency, but no sound of the voice transmission is transmitted to the receiving handheld radio. Black triangle on top row shows the radio is transmitting. But no voice is coming through. Tried two different working headsets, one is a friends and is brand new. Same situation. All functions on screen are normal. No error codes. Receives transmissions from the handheld radio and also receives the ATIS loud and clear. What am I missing? RMM It receives distant aircraft transmissions OK? Then the antenna is likely connected. Wire a test microphone directly to the rear inputs of the radio and try that. |
The radio uses a harness and has a Sigtronics 200S dual intercom installed. Harness is here... http://www.aircraftspruce.com/catalo...201harness.php Sigtronics intercom is here... http://www.sigtronics.com/pdf/air_pd...00S_E_INST.pdf Where and how do you suggest wiring in the test microphone? What type of microphone is suitable? Thanks RMM It receives distant aircraft transmissions OK? Then the antenna is likely connected. Wire a test microphone directly to the rear inputs of the radio and try that. That does not work then send it off to Becker for repair. |
On Saturday, April 26, 2014 5:11:06 AM UTC-5, RMM wrote:
Just purchased a used aircraft with a 5 year old Becker AR4201 radio that seems to work normally BUT no sound goes out on transmission. Previous owner says everything was fine prior to my purchase of the aircraft. No changes made. I am using the previous owner's Bose headsets. So I can understand the wiring was done correctly on initial installation. The PTT click can be heard on the hand held radio opening the frequency, but no sound of the voice transmission is transmitted to the receiving handheld radio. Black triangle on top row shows the radio is transmitting. But no voice is coming through. Tried two different working headsets, one is a friends and is brand new. Same situation. All functions on screen are normal. No error codes. Receives transmissions from the handheld radio and also receives the ATIS loud and clear. What am I missing? RMM Similar problem turned out to be something called the modulator. Keying the mike only resulted in "click" noise being transmitted. I clearly could hear ATC saying they could hear the click but were not receiving any voice transmission from me. Cost a couple hundred to fix. |
Thanks..
I will check the connections more closely tomorrow and if they look good, then Seems the unit must go to Becker in Florida. RMM Similar problem turned out to be something called the modulator. Keying the mike only resulted in "click" noise being transmitted. I clearly could hear ATC saying they could hear the click but were not receiving any voice transmission from me. Cost a couple hundred to fix. |
RMM wrote:
The radio uses a harness and has a Sigtronics 200S dual intercom installed. Harness is here... http://www.aircraftspruce.com/catalo...201harness.php Sigtronics intercom is here... http://www.sigtronics.com/pdf/air_pd...00S_E_INST.pdf Where and how do you suggest wiring in the test microphone? What type of microphone is suitable? Thanks RMM It receives distant aircraft transmissions OK? Then the antenna is likely connected. Wire a test microphone directly to the rear inputs of the radio and try that. That does not work then send it off to Becker for repair. Everything you need to know is in the install documentation for the radio. If it is not clear what to do from that you need to find somebody to help you. It is precisely all the mic side of the wiring harness and intercom crap you want to bypass in your test. Darryl |
My friend is an engine guy and a ham radio operator, but not an electronics tech. The aircraft is E-AB and I am trying to learn this stuff.
Seems if the D-Sub is disconnected the whole system goes down. I am unsure how to proceed. If you could, please give a short description of the method used to do this. I can read the pin diagram and wiring diagrams. What type of procedure and gadgets do this kind of work. Thanks RMM Everything you need to know is in the install documentation for the radio. If it is not clear what to do from that you need to find somebody to help you. It is precisely all the mic side of the wiring harness and intercom crap you want to bypass in your test. Darryl |
| Becker AR4201 | Robin Birch[_2_] | Soaring | 0 | April 21st 14 07:22 PM |
| Becker AR4201 | Robin Birch[_2_] | Soaring | 0 | April 21st 14 06:11 PM |
| BECKER AR4201 | guts | Soaring | 1 | April 23rd 12 09:50 PM |
| Becker AR4201 tuning problem | Hellman | Soaring | 2 | October 18th 08 12:14 AM |
| VHF Becker AR4201 | Philippe | Home Built | 2 | July 9th 04 09:30 PM |
