I've had xcsoar on my Dell streak running Android 2.3.3 "Olleh" ROM for some time now and it's worked well.
However, some sort of update was applied recently via Google Play and now the Streak is very unstable - it turns itself off randomly now. I've uninstalled all updates but the problem persists. So, before I download and re-flash the ROM I thought I'd see what versions others are running and find out how stable it is. I suppose my Streak could just be going south on me but not sure. Anyway, please post back with what versions you're running and how stable it is. Also, let me know if you use the Streak internal GPS or if you're connecting to an external GPS as the problem seems to worsen when I have GPS enabled. Thanks. Robert |
running 2.3.3 olleh with a streak. No updates applied; stable. I disabled the internal gps and use an IOIO board with a PowerFLARM and LX7007 ProIGC as device b anc c. It works well. Running XC Soar 6.4.
Using the internal gps, it would... wander. Dan |
Hi Robert,
I'm running 2.3.7 (Cyanogen Mod 7, or CM7) which I got from the XDA Developers online. I see that there's now a cyanogenmod.org which may be of help but I haven't tried it. My Streak has been rock solid with CM7. I connect my Streak to my CAI 302 via Bluetooth using a K6BT serial to Bluetooth converter which I got through Cumulous Soaring and it works great. I leave the internal GPS enabled as a backup should the 302 or Bluetooth link fail. After a flight, I download the igc file to the Streak or to my Android phone and move it to Dropbox where it's available when I get home. I then upload to OLC and Skylines direct from Dropbox. It's too easy! If you decide to try CM7 and can't find everything you need for the Streak 5, send me an email or post here and I'll make mine available through Dropbox or Google Drive. (another) Dan "Dan Daly" wrote in message ... running 2.3.3 olleh with a streak. No updates applied; stable. I disabled the internal gps and use an IOIO board with a PowerFLARM and LX7007 ProIGC as device b anc c. It works well. Running XC Soar 6.4. Using the internal gps, it would... wander. Dan |
On Sun, 4 May 2014 09:14:22 -0600, "Dan Marotta"
wrote: Hi Robert, I'm running 2.3.7 (Cyanogen Mod 7, or CM7) which I got from the XDA Developers online. I see that there's now a cyanogenmod.org which may be of help but I haven't tried it. My Streak has been rock solid with CM7. I connect my Streak to my CAI 302 via Bluetooth using a K6BT serial to Bluetooth converter which I got through Cumulous Soaring and it works great. I leave the internal GPS enabled as a backup should the 302 or Bluetooth link fail. After a flight, I download the igc file to the Streak or to my Android phone and move it to Dropbox where it's available when I get home. I then upload to OLC and Skylines direct from Dropbox. It's too easy! If you decide to try CM7 and can't find everything you need for the Streak 5, send me an email or post here and I'll make mine available through Dropbox or Google Drive. (another) Dan I have a K6BT serial to Bluetooth converter that I'm not using. (Works great) If anyone is interested in buying it, send me an offer via email. Wayne |
Hi Dan,
I am interested in obtaining the CM7 files; check your email for details. Regards, Bernie. |
Hi Bernie,
Email sent. Dan "Bernie" wrote in message ... Hi Dan, I am interested in obtaining the CM7 files; check your email for details. Regards, Bernie. |
On Saturday, May 3, 2014 2:42:55 PM UTC-5, wrote:
I've had xcsoar on my Dell streak running Android 2.3.3 "Olleh" ROM for some time now and it's worked well. However, some sort of update was applied recently via Google Play and now the Streak is very unstable - it turns itself off randomly now. I've uninstalled all updates but the problem persists. So, before I download and re-flash the ROM I thought I'd see what versions others are running and find out how stable it is. I suppose my Streak could just be going south on me but not sure. Anyway, please post back with what versions you're running and how stable it is. Also, let me know if you use the Streak internal GPS or if you're connecting to an external GPS as the problem seems to worsen when I have GPS enabled. Thanks. Robert Well, I finally got around to upgrading the ROM to CM7 as Dan suggested - thanks Dan. No joy. The ROM itself runs great and has many very nice features that vastly improve the Olleh ROM. But, alas, as soon as I enable the internal GPS it starts rebooting as before. I'm forced to conclude that there is a HW problem with my GPS circuitry. Bummer. Robert |
| Thread Tools | |
| Display Modes | |
| Temperature Probe for Dell Streak | Dan Marotta | Soaring | 14 | April 20th 13 03:56 AM |
| Spring Cleaning Early: Dell Streak 5 pkg, Winter Vario 57mm, more | Evan Ludeman[_4_] | Soaring | 2 | December 31st 12 01:14 AM |
| Dell Streak 5 available | soartech[_2_] | Soaring | 0 | November 14th 12 06:44 PM |
| Short review of the Dell Streak with XCSoar | Max Kellermann | Soaring | 6 | February 9th 11 05:22 PM |
| Streak Shadow | david H | Home Built | 0 | December 26th 03 11:22 PM |
