I have just acquired a Toshiba tablet and was hoping to use it as means to transfer log files to OLC. Seems that there is a problem between the files I now successfully put on a flash drive and use my laptop to send to OLC; something to do with the tablet working on a different format.
Bearing in mind that I am digitally challenged, has anyone sorted this out? So please in plain language. And thanks! Howard |
Dennis:
Needed to do something similar at work with an ipad and music files. Tried a couple of "finder" apps. Contacted the app developers. Bad news, Apple will not allow full file access through USB on its ios devices. Howard: I thought using android for this was easy using an OTG cable and the USB stick containing the file from my logger. Unsure what your logger is, but the "flash" card should work the same way. If a Micro SD, likely without needing the cable. To move files to the tablet, try using an android app called ES File Explorer. There's an option for file format to save as. Without it in front of me, it's something like "use original format" or "convert to android". Use original format. Jim On Tuesday, September 2, 2014 12:39:37 PM UTC-7, HGXC wrote: I just went thru this. I fly with a Cambridge GPS, LNAV and a compaq with Glide Nav2. I download the GPS file on site and then run a program to convert the Cambridge data into IGC files. Then when i get internet I send it to OLC. I wish someone would make an app that will allow me to download to my iphone, convert and send to my OLC. Does anyone know of anyone working on this? Dennis |
Jim:
Many thanks! I will try this tomorrow, when hope to fly. Will report back on the grounds that if a computer illiterate like me can make it work anybody can. Howard On Tuesday, September 2, 2014 9:40:40 AM UTC-6, wrote: I have just acquired a Toshiba tablet and was hoping to use it as means to transfer log files to OLC. Seems that there is a problem between the files I now successfully put on a flash drive and use my laptop to send to OLC; something to do with the tablet working on a different format. Bearing in mind that I am digitally challenged, has anyone sorted this out? So please in plain language. And thanks! Howard |
Not sure how many are aware of the possibility that we created together with OLC:
1. Copy your file to your Android phone or tablet any way you can (Howare already can do it apparently) 2. Run SeeYou on your tablet (it's available through Google Play and complimentary if you already have an active SeeYou subscription) 3. Open the flight in SeeYou on your tablet/phone. 4. Press the Menu button then choose "Upload to..", OLC will be one of the choices. 5. Enter your OLC username and press "Share". OLC then mandates another step in the process which however is quite easy to complete even on a small smartphone. This works great, I use it all the time. Cheers, Andrej Kolar -- glider pilots use http://www.naviter.com/ On Tuesday, September 2, 2014 5:40:40 PM UTC+2, wrote: I have just acquired a Toshiba tablet and was hoping to use it as means to transfer log files to OLC. Seems that there is a problem between the files I now successfully put on a flash drive and use my laptop to send to OLC; something to do with the tablet working on a different format. Bearing in mind that I am digitally challenged, has anyone sorted this out? So please in plain language. And thanks! Howard |
Having neither wifi in my hangar nor a data plan on my Android phone, I
copy my igc file from my 302 to my phone via XCSoar and Bluetooth (K6 BT) and then move it to my Dropbox. When I come in range of a wifi the file is placed in the cloud and, when I start my laptop at home, the file is automatically downloaded to the laptop. I then go to the OLC website and upload. There are so many ways... Dan Marotta On 9/8/2014 6:14 AM, Naviter Info wrote: Not sure how many are aware of the possibility that we created together with OLC: 1. Copy your file to your Android phone or tablet any way you can (Howare already can do it apparently) 2. Run SeeYou on your tablet (it's available through Google Play and complimentary if you already have an active SeeYou subscription) 3. Open the flight in SeeYou on your tablet/phone. 4. Press the Menu button then choose "Upload to..", OLC will be one of the choices. 5. Enter your OLC username and press "Share". OLC then mandates another step in the process which however is quite easy to complete even on a small smartphone. This works great, I use it all the time. Cheers, Andrej Kolar -- glider pilots use http://www.naviter.com/ On Tuesday, September 2, 2014 5:40:40 PM UTC+2, wrote: I have just acquired a Toshiba tablet and was hoping to use it as means to transfer log files to OLC. Seems that there is a problem between the files I now successfully put on a flash drive and use my laptop to send to OLC; something to do with the tablet working on a different format. Bearing in mind that I am digitally challenged, has anyone sorted this out? So please in plain language. And thanks! Howard |
| GPS, Wx for Tablet PC | Wiz | Piloting | 4 | May 24th 07 07:11 PM |
| Using a tablet PC when airborne? | Victor J. Osborne, Jr. | General Aviation | 4 | December 16th 04 11:49 PM |
| Transfer of IGC files from LX5000 to pocketPC | Marc Teugels | Soaring | 1 | January 16th 04 03:56 PM |
| Homebrew EFB from Tablet PC | Leland Vandervort | Owning | 7 | August 10th 03 08:28 PM |
| Homebrew EFB from Tablet PC | blanche cohen | Piloting | 0 | August 9th 03 07:00 AM |
