Has anyone else had an issue with a V7 freezing in place for a few seconds? The sound cuts out at the same with the data being display but not changing.
My Clearnav vario is still working so I do not think it is an air issue. |
On Wednesday, September 3, 2014 1:24:06 PM UTC-7, Tom (2NO) wrote:
Has anyone else had an issue with a V7 freezing in place for a few seconds? The sound cuts out at the same with the data being display but not changing. My Clearnav vario is still working so I do not think it is an air issue. I have this exact problem running 3.01 and i think, 3.1 firmware. Screen freezes, sound goes to zero, power to GPS is interrupted, and NMEA from GPS (PowerFlarm core) is interrupted to PDA (Oudie) I reported it to LXNav and they think it's a software problem and asked if I could try and push the button during a freeze to see if the McCready screen pops up. No other suggestions from them... Please report your issue to Uros at: Matt |
Has anyone else had an issue with a V7 freezing in place for a few seconds? The sound cuts out at the same with the data being display but not changing. My Clearnav vario is still working so I do not think it is an air issue. I also cannot get flarm alerts on my V7. The "display flarm" enabled option will not stay checked. My setup is; V7 powered by main batteries Powerflarm core powered by V7, connected through GPS cable Flarmview connected to PF Core Oudie connected to V7 I do get flarm warnings on the FlarmView, and also on SeeYou on the oudie, so I know they are getting to the V7, but the V7 will not display them at ay time. |
On 09/04/2014 10:40 AM, Matt Herron Jr. wrote:
On Wednesday, September 3, 2014 1:24:06 PM UTC-7, Tom (2NO) wrote: Has anyone else had an issue with a V7 freezing in place for a few seconds? The sound cuts out at the same with the data being display but not changing. My Clearnav vario is still working so I do not think it is an air issue. I also cannot get flarm alerts on my V7. The "display flarm" enabled option will not stay checked. My setup is; V7 powered by main batteries Powerflarm core powered by V7, connected through GPS cable Flarmview connected to PF Core Oudie connected to V7 I do get flarm warnings on the FlarmView, and also on SeeYou on the oudie, so I know they are getting to the V7, but the V7 will not display them at ay time. You need to be running latest firmware of both V7 and PowerFlarm. I get FLARM, ADS-B, and PCAS alerts on my V7 Luke |
On Wednesday, September 3, 2014 4:24:06 PM UTC-4, Tom (2NO) wrote:
Has anyone else had an issue with a V7 freezing in place for a few seconds? The sound cuts out at the same with the data being display but not changing. My Clearnav vario is still working so I do not think it is an air issue. It might be a power issue. See this thread: https://groups.google.com/forum/#!searchin/rec.aviation.soaring/v7$20/rec.aviation.soaring/lmcPBqJgXRo/sHXvb_ZmHpYJ If you're powering everything from the V7, it may be too much. Dan 2D |
I had the same problem. I worked through it by disconnecting everything, ie oudie and pflarm and the issue did not resolve. In digging around behind the panel I noted the V7 was very hot to the touch. That suggests an overheating issue?
Mark |
Has anyone else had an issue with a V7 freezing in place for a few seconds? The sound cuts out at the same with the data being display but not changing. My Clearnav vario is still working so I do not think it is an air issue. I thought this too, so made a cable to power the flarm core separately. V7 still crashed, but no longer crashed the PF. |
Has anyone else had an issue with a V7 freezing in place for a few seconds? The sound cuts out at the same with the data being display but not changing. My Clearnav vario is still working so I do not think it is an air issue. I am running the attest firmware- no flarm alerts |
I had this problem, Uros was unable to solve it. He sent me a replacement
V7 that did the same. I tried disconnecting everything to no avail. It happened more often in very hot weather. When I changed my glider's batteries this year from 14 volts to 12 volts the problem went away. It seems to work continuously now. The manual says "10-16 volts DC" input and I wonder if my hot battery was producing a voltage close to the upper limit. Alan At 17:03 06 September 2014, Matt Herron Jr. wrote: On Wednesday, September 3, 2014 1:24:06 PM UTC-7, Tom (2NO) wrote: Has anyone else had an issue with a V7 freezing in place for a few seconds? The sound cuts out at the same with the data being display but not changing. My Clearnav vario is still working so I do not think it is an air issue. I am running the attest firmware- no flarm alerts |
On Sunday, September 14, 2014 12:54:15 PM UTC-7, Alan Montague wrote:
I had this problem, Uros was unable to solve it. He sent me a replacement V7 that did the same. I tried disconnecting everything to no avail. It happened more often in very hot weather. When I changed my glider's batteries this year from 14 volts to 12 volts the problem went away. It seems to work continuously now. The manual says "10-16 volts DC" input and I wonder if my hot battery was producing a voltage close to the upper limit. Alan At 17:03 06 September 2014, Matt Herron Jr. wrote: On Wednesday, September 3, 2014 1:24:06 PM UTC-7, Tom (2NO) wrote: Has anyone else had an issue with a V7 freezing in place for a few seconds? The sound cuts out at the same with the data being display but not changing. My Clearnav vario is still working so I do not think it is an air issue. I am running the attest firmware- no flarm alerts Alan, Please give me a call. There is a solution to this problem Richard www.craggyaero.com |
| fin/wing tanks freezing | Matt Herron Jr. | Soaring | 34 | June 10th 13 04:14 PM |
| Now we have freezing rain! | GARY BOGGS | Soaring | 9 | January 21st 12 03:28 PM |
| FSX Crashing /freezing ! | Kekke | Simulators | 1 | July 19th 07 10:54 AM |
| Screen freezing. | W.Lindsay | Simulators | 3 | May 10th 06 10:03 PM |
| GPS_LOG freezing and freezing | cernauta | Soaring | 4 | May 8th 05 07:39 PM |
