Stalking the elusive Type Certificate
Old December 19th 14, 06:11 PM posted to rec.aviation.soaring
Pat Russell[_2_]
Default Stalking the elusive Type Certificate
I have some questions about the FAA Type Certificate (TC). My questions are not about the Type Certificate Data Sheet (TCDS). Typically, the TCDS refers to the TC.
I have never seen a TC.
Here are my questions:
1. What does a TC look like?
2. Are copies of the TC available to the public?
3. Is it referenced by the same identifier as the TCDS?
I have the same questions about the EASA TC.
Looking forward to enlightenment. Thanks.
Old December 19th 14, 06:39 PM posted to rec.aviation.soaring
Papa3[_2_]
There is an FAA Website that has them. Here's an example for Duo Discus. Not all gliders have a Type Certificate in the US (as I'm sure you already know).
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/c65e39afff1d1d778625743b005c49ee/$FILE/G85EU.pdf
Old December 19th 14, 06:50 PM posted to rec.aviation.soaring
John Carlyle
In the US it appears that you are looking for a Form 8110-9, if the following link is accurate: http://www.astech-engineering.com/sy...tcprocess.html I did a quick search and found the blank form, but it wasn't very helpful and I couldn't find a filled in form 8110-9.
-John, Q3
Old December 19th 14, 07:05 PM posted to rec.aviation.soaring
Papa3[_2_]
Whoops - this is the main search page where you would start:
http://rgl.faa.gov/Regulatory_and_Gu...meset?OpenPage
Old December 19th 14, 07:14 PM posted to rec.aviation.soaring
Dan Daly[_2_]
EASA sample here. http://www.windpath.ca/index.php?opt...&id=4&Itemid=4 for the Perkoz.
Simple certificate with a signature from your FAA equivalent.
Old December 26th 14, 02:07 PM posted to rec.aviation.soaring
Pat Russell[_2_]
Thanks, Dan. That's the Canadian equivalent of what I am looking for, and I suspect that the FAA version looks similar. I wonder why they can't be found? Perhaps there's only one copy in a vault in the basement in Oklahoma City.
Old December 26th 14, 03:52 PM posted to rec.aviation.soaring
I'm curious as to why you are looking for this.
UH
Old December 31st 14, 12:48 AM posted to rec.aviation.soaring
Pat Russell[_2_]
No particular reason. The mind tends to wander this time of year.
L13A Type certificate holder Bruce Soaring 7 August 19th 10 07:01 PM
Parachute Required by Type Certificate [email protected] Soaring 1 April 27th 09 11:15 PM
Softie parachute EASA type certificate bjorn Soaring 2 January 25th 07 06:10 PM
Tracking the Elusive Tracing Paper Veeduber Home Built 18 August 30th 04 12:53 PM
C182RG Type Certificate Data Sheets EDR Piloting 6 July 3rd 04 03:11 AM
