New Cobra trailer - - which top?
Old February 18th 15, 04:00 AM posted to rec.aviation.soaring
Default New Cobra trailer - - which top?
On Wednesday, February 11, 2015 at 9:14:19 AM UTC-8, Ben wrote:
So, if you were ordering a new Cobra trailer, would you order a fiberglass top or an aluminum top? For sake of discussion, lets exclude obvious price difference.
I've never seen an aluminum top with insulation. What type of insulation is used and is it worth the 1000 plus euros?
For those having a reasonably new Cobra trailer, in your opinion, what options are "mandatory" and what options are "losers"?
Thanks for your feedback.
I'm curious, what does one pay for a 15 meter Cobra Trailer delivered to a West Coast port?
Old February 18th 15, 05:01 AM posted to rec.aviation.soaring
Brand new?...20 ish..depending on extras etc. But that number is based on what the Euro was compared to the US Dollar 18 months ago. The Euro is about 20% cheaper now.
Old February 19th 15, 01:55 AM posted to rec.aviation.soaring
The UV issue is solved by a black factory coating (gloss paint?) on the inside of the glass top. It was available in 1998+, maybe only as an option, but both my 1998 & 1999 have it.
Old February 19th 15, 02:11 AM posted to rec.aviation.soaring
Andrzej Kobus
It has been a standard for a long time.
Old February 19th 15, 02:18 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Last two trailers I got the fiberglass and had a local craftsman insulate the interior. I thought the fiberglass looked better and was lees likely to form condensation. I was not sorry for my choice. I have also had AL tops, but as a personal preference I prefer fiberglass.
Old February 19th 15, 10:47 AM posted to rec.aviation.soaring
On Wednesday, February 18, 2015 at 9:18:19 PM UTC-5, Jonathan St. Cloud wrote:
What did you use for the insulation?
Kevin
Old February 19th 15, 11:33 AM posted to rec.aviation.soaring
Bruce Hoult
Styrofoam sheets are probably the only reasonable answer. If you want to make it more durable you can brush or roll or spray on a layer of epoxy resin or urethane. NOT polyester resin. And some thin glass mat if you want to be super fancy.
  #28
Old February 19th 15, 12:05 PM posted to rec.aviation.soaring
Bruce Hoult
Movie and stage show people make a lot of scenery and props out of foam, and then need a hard coating on them to protect them.
This seems to be one of the ones they use:
http://www.fxsupply.com/materials/foamcoat.html
Coverage seems to be about 150 sq ft per gal, so you might need about three gallons or $160 worth to do sides and top of a trailer. Here in Wellington, the same area of recycled polystyrene sheets will cost about twice that.
  #29
Old February 19th 15, 02:22 PM posted to rec.aviation.soaring
Jonathan St. Cloud
I used a closed cell soft foam. Not sure where my mechanic got it but it was ⅜ inch thick.
  #30
Old February 19th 15, 04:10 PM posted to rec.aviation.soaring
Dan Marotta
Well that might protect the glider inside the trailer but it does
nothing for the fiberglass trailer top.
Dan Marotta
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
looking for used Cobra trailer Brad[_2_] Soaring 3 July 1st 11 02:58 AM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
Cobra Trailer [email protected] Soaring 22 December 7th 06 11:38 PM
Cobra Trailer Soaring 1 September 28th 03 01:14 PM
