Getting out of the clouds in a Ventus C
Old May 11th 15, 11:49 PM posted to rec.aviation.soaring
Dan Marotta
Default Getting out of the clouds in a Ventus C
You shouldn't be in an unusual attitude soon after losing visual
reference unless you immediately begin wiggling the stick around. If the
controls stay pretty much where they were, the glider should maintain
the same attitude, more or less. But then I only have a paltry 42 years
experience with instrument flying...
On 5/10/2015 11:13 AM, waremark wrote:
And if you try the more generally recommended approach of airbrakes out, hands and feet off? That seems to work in both the gliders I most often fly.
You should enter the recovery mode from an unusual attitude since you will probably be in an unusual attitude very soon after losing external visual reference.
Unless I have reason to think the cloud goes down to the ground, I would not consider bailing out unless/until the wings come off.
Dan Marotta
Old May 12th 15, 04:05 PM posted to rec.aviation.soaring
Andy, well, since I originally posted my Ventus B story I tried again the other day. It worked but airspeed indicator was blanked out completely by cross control. I didn't remember that happening before. However it was doable with sound alone. I didn't try it without the trailing edge dive brakes open and would guess that without the extra drag it would be harder to maintain slower airspeeds to reduce side loads on the tail and rudder. Any aerodynamicists out there that can do the rough calcs to see if load limits would be exceeded? Or are there even side load calcs available?
CH
Old May 12th 15, 06:23 PM posted to rec.aviation.soaring
Tango Whisky
You can'then exceed load limits by simple deflection far below manoeuvring speed. That's the definition of it.
With 900h on my Ventus, I would never fancy anything else than horizontal stabilisation with landing flaps followed by full airbrakes to get out of an IMC trap. Ever.
Tango Whisky
Tango Whisky
Old May 31st 15, 03:04 PM posted to rec.aviation.soaring
I find this thread very interesting.
Matt--
So the yaw string was streaming to the right, and the ship was slowly turning right?
What would you estimate the bank angle to be, and in which direction?
(To the left I presume, but "aggressive slip to the left" really only specifies the amount and direction of yaw string deflection, especially in a complex situation like this where direction of bank and direction of turn may be opposite.)
I experienced something very similar to this while playing around with full crossed controls in a Challenger ultralight. In the Challenger, the rudder went to full deflection, and stayed there, even WITHOUT any pilot input-- the adverse yaw from the ailerons set up a strong enough slip angle to blow the rudder all the way over to full deflection. We ended up turning slowly right, while banked slightly left, with the yaw string streaming way to the right, and full left ailerons held to cancel the right roll torque from sideslip + dihedral, and the rudder blown all the way over to the right.
I'd like for some more people to try this and report back.
Keep in mind the importance of leaving the spoilers closed-- see the O.P. on this thread.
But for an added test of robustness-- what happens if you initiate the maneuver in the OPPOSITE bank that you expect to end up in-- say begin in a right bank/turn and THEN apply full left aileron and full right rudder? In other words how far can the aircraft be perturbed from the steady-state, in terms of bank angle, and still return to the steady state?
By the way, here are some related threads, just to put them all in once place:
Chukar's own account -- includes CH's original suggestion re fully crossed controls to enter a stable spiral in clouds--
http://groups.google.com/forum/#!top...ng/LFr-fXMjoMc --
In wave, in blue hole at cloud level, hole closes, in IMC, then what? -- includes much discussion of the benign spiral maneuver--
https://groups.google.com/forum/#!to...ng/ALP7WFf3GYs
Emergency instrumentation for cloud encounters-- O.P. referenced a simple piezoelectric turn rate indicator, branched off into an extensive discussion of the artificial horizon capability built into some of the top-of-the-line varios--
https://groups.google.com/forum/#!to...ng/b0RXcbDa8ik
Needed: Inexpensive AHRS module to work with Oudie, XCsoar, LK8000, etc...--discussion of how to create an artificial horizon capability if you aren't flying with a vario with such capability built-in
https://groups.google.com/forum/#!to...ng/B-W-MMSf7V4
On Sunday, May 10, 2015 at 10:44:59 AM UTC-5, Matt Herron Jr. wrote:
Test #2
Yesterday I tested a variant of the first test; Gear down, flaps to +2 (not landing flaps), spoilers NOT deployed, stick all the way back and left, rudder full right. I held the controls in this position without adjustment/input.
Results:
Plane went into an aggressive slip to the left, nose low. We did a slow, steady turn to the right for 2.5 revolutions. During that time pitch was stable. The nose came up a bit, then went down. the nose went down, but then came back up. Nothing dramatic. I think I lost about 1000ft/revolution.. I will post the trace today.
Conclusion:
I personally would try this maneuver in clouds before bailing out. It seemed stable, with a high rate of decent. I don't know if I had elevator authority, as the stick was all the way back. I need to test the slip in the other direction to make sure the behavior is also stable (I tend to always drop the left wing on stall). Your milage will of course vary...
Anyone else want to try this?
Matt
Old May 31st 15, 07:02 PM posted to rec.aviation.soaring
Matt Herron Jr.
Matt--
I was banked left about 15-20 degrees (guessing from memory), nose was significantly down. I had to hold full right rudder with some effort to keep it in a slip. Yaw string was to the right. No spoilers or you loose pitch control due to turbulence over horiz. stab.
Matt
Old June 2nd 15, 02:10 PM posted to rec.aviation.soaring
And your direction of bank was to the left I presume...
I've experienced something very similar in Challenger ultralight, climbing under power.
In hindsight I wish I had experimented with seeing what would happen if the bank angle were perturbed significantly in one direction or the other. If find myself flying a sailplane that exhibits these characteristics, I'll be sure and check that out. Would be good to know, if one is contemplating using that technique for a blind descent in a situation with some turbulence. My concern is that if the bank angle is somehow perturbed past wings-level into a right bank, you might end up in a really tight spiral to the right. But I don't know for sure.
Btw this technique wouldn't work in a 2-22. I'm sure you can guess why. The ailerons are too powerful, in relation to the rudder.
It's interesting to think through the dynamics at play here. Why is this situation stable? What are the dynamics that act to restore the bank angle, after a slight perturbation? Are they significantly different than the dynamics of a benign spiral? I suppose the basic dynamics of a stable benign spiral are-- increased bank angle also increases sideslip which interacts with dihedral to create more rolling-out torque. Decreased bank angle also decreases sideslip, which allows other competing rolling-in torques to increase the bank angle.
In the cross-controlled spiral you'd have something kind of similar going on-- you have a strong sideslip (skid?) from the rudder (yaw string streams toward inside of turn, which is toward the high wingtip), creating a roll torque that tends to increase the bank angle. Any decrease in bank angle will increase the turn rate which will tend to increase the drag of the outboard (low) wingtip and decrease the slip (skid?) angle, decreasing the roll torque toward the high wingtip, and allowing other competing factors to drive an increase in bank angle. Any increase in bank angle will decrease the turn rate which will tend to decrease the drag of the outboard (low) wingtip and increase the slip (skid?) angle, increasing the roll torque toward the high wingtip, and driving a decrease in bank angle.
In a normal spiral, the high descent rate creates a requirement for roll toward the low wingtip just to hold the bank angle constant, so roll damping tends to drive a decrease in bank angle. That's why opening the spoilers helps keep the bank angle from increasing.
But in this cross-controlled spiral, the direction of turn is toward the HIGH wingtip, not the low wingtip. The high descent rate creates a requirement for roll toward the HIGH wingtip just to keep the bank angle constant, so roll damping tends to drive an INCREASE in bank angle. (The opposite would be true if the maneuver were performed while climbing under power.) So opening spoilers would NOT be expected to create a stabilizing effect in roll-- this helps to explain how a similar dynamic could exist even in powered flight. Likewise the drag from the sideslip, and the resulting high sink rate, would NOT be expected to contribute a stabilizing effect in roll.
In a normal spiral, the outside (high) wingtip is moving faster than the inside (low) wingtip, which tends to generate a rolling-in torque, increasing the bank angle. In the cross-controlled spiral, the high wingtip is also the inboard wingtip, and it is moving slower than the low wingtip which is also the outboard wingtip, creating a roll torque that tends to decrease the bank angle.
It's a curious animal. I wonder what other gliders show exhibit this stable cross-controlled spiral behavior-- and how stable it really is?
S
Now I see you did say left, thanks.
Old June 2nd 15, 04:13 PM posted to rec.aviation.soaring
Matt Herron Jr.
not sure about the full aerodynamic affect of roll stability, but I imagine if the wings started to level off the turn rate would increase. This would give more speed to the outboard wing which would tend to drop it back down due to full upward deflection of the aileron on that wing. I did observe pitch stability during this maneuver, with the nose coming up, aircraft slowing down, then nose dropping again, speeding up.
Worth noting that with a 45 second turn rate and an average decent rate of 2200 fpm, I am loosing 1650 feet per turn. It won't take more than 2 turns or so to get me out of the clouds, so there is not a lot of opportunity for the maneuver to decay into something nasty if indeed it is possible.
Matt
Pyrocumulus clouds over CA son_of_flubber Soaring 0 August 7th 14 09:49 PM
Clouds bildan Soaring 9 December 20th 08 09:08 PM
PH-GRD breaking through the clouds Tom Hayden Aviation Photos 0 October 2nd 07 08:40 PM
How clouds are made Glenn[_2_] Aviation Photos 1 October 2nd 07 05:28 AM
