I'm looking for a source for some fuses for my 1972 ASW 15 panel. They may be called mini barrel fuses and were apparently used in military helicopters. They look like this: http://www.ebay.com/itm/Buss-mini-ba...item58a6f18404.
The seller doesn't have the size I need. Thanks. |
On Monday, August 24, 2015 at 11:44:31 AM UTC-4, wrote:
I'm looking for a source for some fuses for my 1972 ASW 15 panel. They may be called mini barrel fuses and were apparently used in military helicopters. They look like this: http://www.ebay.com/itm/Buss-mini-ba...item58a6f18404. The seller doesn't have the size I need. Thanks. Try this: http://www.findchips.com/search/FM09 Hope that helps, Best Regards, Dave |
PS: This might be a good time to replace your fusing with current
automotive style blade fuses - they are MUCH more reliable! Stay away from glass cylinder types... |
Thanks. I found what I was looking for at Digikey. The type of fuse is GMW series. $10 for one fuse. I'll ask my A&P about updating but there are already nice little holes in the panel for the old fuses. Maybe time for a whole new panel! Funny how the need for one fuse can transform into thousands of dollars.
On Monday, 24 August 2015 20:10:07 UTC+2, Dave Nadler wrote:
PS: This might be a good time to replace your fusing with current automotive style blade fuses - they are MUCH more reliable! I can second that. Thanks to the recommendations on RAS I'm rewiring my old glider and using blade fuses. Cartridge fuse holders are not very reliable especially if they are mounted on wires that are moved/bumped around a lot. Blade fuses are cheap, reliable and can be found at any electronics store, fuel/gas station or motor spares stores. From what I've seen in older gliders the trend appeared to be a main fuse at the battery (or batteries) and one or two main instrument fuses mounted in the instrument panel (usually of the cartridge type). I'm not sure if this was done by the manufacturer or installed later by glider owners but I think it is a very silly set up. If there is a short circuit in one of the instruments or related circuits, you lose all your instrumentation when the main fuse in the panel blows and you're unlikely going to be able to rectify the short circuit in flight so replacing the fuse will most likely just result in more blown fuses. The same logic applies to resettable fuses. Rather fuse each instrument separately according to manufacturer specifications so that if an instrument or related circuit develops a short you only lose that portion of the circuit instead of everything. I've moved all the instrument fuses (eight of them) behind the instrument panel into a fuse block holder to save panel space and remove the temptation to fiddle when my attention should be outside the cockpit. 10 or 15 Amp fuses right at the battery terminals 14 gauge wire from the batteries to the panel (bit of an overkill) 1,2,3 or 5 Amp fuses for each instrument according to manufacturer recommendations |
The current fuses are not the glass tube cartridge type. As they were used in helicopters and are mil spec so I would hope that they are fairly reliable. The one I am replacing wasn't blown but damaged - likely by me while trouble shooting a faulty radio. In any case, I do have a blade type at the battery and one fuse for each instrument. Now, when I add an ADS-B box, transponder, PowerFlarm and air conditioning I will probably re-wire. ;).
On Monday, August 24, 2015 at 3:03:11 PM UTC-4, wrote:
Thanks. I found what I was looking for at Digikey. Yes, much better: http://www.digikey.com/product-searc...1?k=fuse%20gmw Above should have been FM01; DigiKey doesn't list them that way though. The type of fuse is GMW series. $10 for one fuse. That's what happens with old uncommon parts! I'll ask my A&P about updating but there are already nice little holes in the panel for the old fuses. Maybe time for a whole new panel! Funny how the need for one fuse can transform into thousands of dollars. |
Any reason why you are not using circuit breakers?
Fuses seem a little old fashioned these days. |
Its what came with the ship when I bought it. If it ain't broke....
On Tuesday, August 25, 2015 at 10:55:12 AM UTC-4, Ross wrote:
Any reason why you are not using circuit breakers? Fuses seem a little old fashioned these days. Circuit breakers waste energy, fuses don't. In a battery powered system blade fuses are the best choice. -John, Q3 |
| Thread Tools | |
| Display Modes | |
| Fuses on the panel, or not | SF | Soaring | 41 | November 18th 16 10:41 PM |
| Fuses in general | Tuno | Soaring | 19 | December 11th 08 07:45 PM |
| fuses vs. circuit breakers | raulb | Soaring | 0 | November 8th 07 03:48 PM |
| Bussman Fuses | kevmor | Piloting | 10 | May 25th 07 04:25 AM |
| Bussman Fuses | kevmor | Piloting | 2 | May 22nd 07 10:28 PM |
