Backing up a cobra trailer uphill. Is it safe ?
Old October 17th 15, 03:20 AM posted to rec.aviation.soaring
Default Backing up a cobra trailer uphill. Is it safe ?
I have a steep driveway where I want to park my Cobra trailer.
Is it safe to backup the trailer up the incline ?
This means that the run-up brake will be completely compressed.
Can this be done without any damage to the mechanisme ?
Is my understanding correct that there is some kind of free-running mode on the brakes when pushing backwards ?
3U
Old October 17th 15, 08:59 AM posted to rec.aviation.soaring
Tango Whisky
The brakes will open as the wheels start turning backwards, although the rod is completely compressed. No problem.
Bert Ventus cM TW
Old October 17th 15, 01:05 PM posted to rec.aviation.soaring
Ian Reekie
The mechanical magic is all explained here
http://www.al-ko.co.uk/edit/files/ha...m-handbook.pdf
Rgds
Ian
Old October 17th 15, 02:35 PM posted to rec.aviation.soaring
3U
The answer should be self-evident since you're dealing with German Engineering, buddy!
Old October 17th 15, 03:41 PM posted to rec.aviation.soaring
3U
No problem with the brakes if they are properly adjusted but I've encountered two situations where a trailer hitch popped off the ball damaging the rear of the tow vehicle when backing up a steep driveway.
It seems that some ball hitches don't like a large positive angle (trailer angling upwards with respect to the car) when combined with backing loads.
This led one owner to use an electric winch inside his garage to pull the trailer in without risking his car.
Old October 17th 15, 06:03 PM posted to rec.aviation.soaring
Rgds
Ian
Wondering about the handbook. It calls for 290Km torque value. This translates to 213 FT LBS. Is this correct or does it translate to 65TT LBS? My brake stays applied when I back up and I am going to take the brakes apart and figure out why. Thanks
Old October 17th 15, 07:15 PM posted to rec.aviation.soaring
Rgds
Ian
I can believe it, it's about what other axle nuts holding a cartridge bearing calls for.
Ranges go from ~140 ftlbs to over 200 ftlbs torque.
If they were an "old style" taper roller bearing, it's a lot less (more like 30 ftlbs).
New Cobra trailer - - which top? Ben[_6_] Soaring 34 February 19th 15 09:43 PM
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
looking for used Cobra trailer Brad[_2_] Soaring 3 July 1st 11 02:58 AM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
Cobra Trailer [email protected] Soaring 22 December 7th 06 11:38 PM
