FLARM false poitives
Old December 7th 15, 07:57 PM posted to rec.aviation.soaring
Luke Szczepaniak
Default FLARM false poitives
Hi All, in the numerous FLARM threads I see multiple references to false positives. I had seen many myself before I came across the following config in the dataport:
#Enable Competition Mode - changes warning configuration
#Set 0 to disable, set 2 to enable
$PFLAC,S,CFLAGS,2
After setting this parameter to 2 and configuring my display to only alert me on critical threats the false positives went away completely making for a much more pleasant experience. Those of you who still experience the false positives *may* want to try this. It does not remove any information from your display but it does tighten the alert criteria.
Happy Soaring
Luke
Old December 7th 15, 08:24 PM posted to rec.aviation.soaring
Tango Eight
$PFLAC,S,CFLAGS,2
Happy Soaring
Luke
I've been doing this for a couple of years at contests. Works great.
T8
Old December 8th 15, 12:37 AM posted to rec.aviation.soaring
George Haeh
Default FLARM false positives
We got rid of a bunch of false positives on
tow when the glider Flarm aircraft type
was changed from towplane to glider.
Old December 8th 15, 05:36 PM posted to rec.aviation.soaring
Sean Fidler
Thanks for sharing Luke. My old portable does this (Buffalos now). Ill fix it. My new core does not, but good to know for the future.
Flarm IGC files on non-IGC certified Flarm? Movses Soaring 21 March 16th 15 10:59 PM
Trivium or false? Square Wheels[_3_] Aviation Photos 4 December 18th 07 10:39 AM
False glideslopes -- NZ60 [email protected] Instrument Flight Rules 11 February 5th 07 03:16 PM
Can there be false lobes on a *localizer*? [email protected] Instrument Flight Rules 14 November 17th 06 11:27 PM
True or false zalzon Naval Aviation 1 August 12th 04 04:29 PM
