Breakers as Switches - Good Idea?
Old February 18th 16, 10:23 AM posted to rec.aviation.soaring
Tim Newport-Peace[_2_]
Default Breakers as Switches - Good Idea?
At 08:55 18 February 2016, Jim White wrote:
At 17:17 17 February 2016, Steve Koerner wrote:
I think the right way to look at this is to take a gander at the spec
sheet=
of the referenced part. At the top of the sheet is a table showing the
re=
sistance that the breaker introduces for varying current ratings. It
shows=
for example that a 5A breaker introduces 0.03 ohms. Next, consider
p=
eak load of the device that you're powering. If it's a radio, for
example,=
look at its transmit current. Let's say the peak current is 1 amp.
Then
the voltage drop across the breaker is: V =3D iR =3D (1)(.03) =3D 30 mV
That's insignificant. The actual effect on battery life is that it will
mo=
re likely be extended by the introduction of the additional load; it's
just=
that the drop out point for the connected instrument will be 30mV lower
For a lithium battery with a fairly sharp fall off, I think you'll
normally=
end up net positive to battery life by the introduction of the small
serie=
s load (as long as the connected instrument works down to the steep part
of=
the battery discharge curve). =20
And, BTW, fuses have resistance too -- it's the same game with a fuse.
I was using ETA 106-P30 trips that have internal resistance of 0.9ohm fo
the 1a and 0.05 for the 5 amp. The problem was my Becker radio which onl
likes to work at 12V+. The 5amp breaker dropped the voltage by over 1V o
transmit which for SLA batteries made it unworkable. A standard blade fus
had much less impact.
I now use LifePo4 so this is now a mute point. However one point to not
with trips is the trip time. Mine were 10 seconds at 2x rated load
Standard fuse trips much faster.
If your Becker wont work below 12v there is something odd.
What model is it? The spec for AR6201 (25/8.33KHz) is: Input Voltage
Range: 9 V DC to 32.2 V DC
http://www.becker-avionics.com/ar620...with-8-33-khz/
Old February 19th 16, 04:36 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Jim White wrote on 2/18/2016 12:55 AM:
I was using ETA 106-P30 trips that have internal resistance of 0.9ohm for
the 1a and 0.05 for the 5 amp. The problem was my Becker radio which only
likes to work at 12V+. The 5amp breaker dropped the voltage by over 1V on
transmit which for SLA batteries made it unworkable. A standard blade fuse
Unless your Becker is about 25+ years old, there is something wrong with
it. For decades, Beckers have worked to 10 volts.
email me)
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Old February 19th 16, 06:22 AM posted to rec.aviation.soaring
If it's rated for use as a switch, sure you can use a breaker as a switch. I have a Tyco breaker that's rated as a switch (looks like a toggle switch) that I bought because when I was planning a FLARM install that was integrated with an LX8080 Simple/V5 I wasn't sure whether the LX delivered switched or unswitched power to the FLARM. As it turned out it delivered switched power so the breaker is on my shelf rather than in the glider. The glider has two aircraft spec breakers on the panel and one built into the battery box. My glider no longer has any master switch as all the avionics have their own built in on/off switches so the only thing the master switch did for me was to present me with the possibility of turning everything off in flight by accident.
Old February 19th 16, 10:22 AM posted to rec.aviation.soaring
Jim White[_3_]
sheet=
re=
shows=
p=
example,=
Then
mV
will
mo=
just=
lower
normally=
serie=
part
of=
fus
4201
Old February 19th 16, 10:27 AM posted to rec.aviation.soaring
Jim White[_3_]
for
only
on
fuse
email me)
From the installation manual:
'Supply voltage range 12.4 V to 15.1 V '
It will receive below 12V but will not transmit properly.
Old February 19th 16, 11:07 AM posted to rec.aviation.soaring
for
only
on
fuse
email me)
So it IS a 20+ year old design.
You will need to upgrades it to a 8.33KHz model before 2018 anyway.
Pity you missed Becker's trade-in offer.
http://www.becker-avionics.com/wp-co...ion-AR6201.pdf
Old February 19th 16, 03:44 PM posted to rec.aviation.soaring
Dan Marotta
Give them a call anyway, they may be friendly and make you at least some
offer.
Good luck!
Dan, 5J
Old February 19th 16, 03:52 PM posted to rec.aviation.soaring
Jim White[_3_]
offer.
Good luck!
Dan, 5J
Nonsense. I'll get another 2 years at least out of it. Then new 8.33 radios
will be under $1000
Old February 19th 16, 07:51 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
offer.
Good luck!
http://www.becker-avionics.com/wp-co...011/10/150108-
Exchange-action-AR6201.pdf
Dan, 5J
radios will be under $1000
Some already are. I see that the Dittel KRT2 is already cheaper than when
I bought mine two years back.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Good Idea? Little Luke Piloting 1 August 20th 08 04:22 PM
Pilots Uniform: Good idea?? [email protected] Owning 16 December 6th 07 07:44 PM
"Trying out" a different insturctor just to see - good idea? Badidea? GEG General Aviation 18 May 8th 05 08:33 PM
Is replacing Maverick with JCM a good idea? Scott Ferrin Military Aviation 12 June 16th 04 10:07 PM
Defrag before install a good idea? Mark Cherry Simulators 3 September 23rd 03 07:51 AM
