Flight tracking technologies
Old March 9th 16, 06:38 PM posted to rec.aviation.soaring
kiwiindenver
Default Flight tracking technologies
Hi All,
For those of you wondering about glider flight tracking options this year. I suggest watching the Seminole Lake Gliderport activity so see an example of a number of technologies all in one place.
Here is the link http://glideport.aero/map?p=GlidePort:396
Pilots with Spot
AXC,FH,G1,F6,KM,N1K,U
Pilots with InReach
DK,nb?
Pilots with Cell phone data
U (Roman has both Spot and a Cell phone)
No single solution is perfect. I suggest you watch the traces and see the delays and information provided by each technology.
Some of my personal observations
* Spot doesn't have altitude
* InReach appears to be the most consistent regarding delays. It has altitude
* Cell has the richest data but can be highly variable in delays.
Alan
Old March 9th 16, 08:20 PM posted to rec.aviation.soaring
On Wednesday, March 9, 2016 at 11:38:30 AM UTC-7, kiwiindenver wrote:
Hi All,
Pilots with Spot
Pilots with InReach
DK,nb?
Alan
For those that missed it. Roman's cell trace was silent for about 1:20. That is a LONG time. IMHO that is also not typical, 30min is not unusual.
CORRECTION : Roman has InReach, not Spot. You can see the altitude trace.
I like watching Roman's cell trace. Compare the two traces for yourself to see the difference. BUT it can be VERY frustrating due to delays.
I like the cell data but I certainly would not trust my life to it.
Alan
Old March 9th 16, 09:50 PM posted to rec.aviation.soaring
George Haeh
Oudie Live is an app that sends position
data via Bluetooth to your phone which
then sends a data packet to a web service
such as Livetrack24, Soaring Spot or See
You Cloud. Note each service has its
differences.
XCSOAR can also work with Skylines.
Cell coverage over the Alberta foothills is
sparse on the ground, but at altitude Oudie
Live updates Livetrack24 just fine.
Our private owners use it along with
PowerFLARM which can also be used for
retrospective flight path reconstruction for
SAR, but Livetrack24 positions are
available within minutes.
I also have a PLB. Unless I end up on a
high ridge in line of sight of a tower
(there's quite a few that are not), the cell
phone won't help.
At 20:20 09 March 2016,
Hi All,
in one place.
Here is the lsuink
p=GlidePort:396
Pilots with Spot
Pilots with InReach
DK,nb?
phone)
each technology.
altitude
Alan
Alan
Old March 9th 16, 10:36 PM posted to rec.aviation.soaring
In the West, notably Minden and Montague cell coverage at altitude is probably less than 50 percent (subjectively). On the ground it is worse, so not much in the way of emergency service. My wife follows me on In Reach and loves it. She hated spot. She knows more than we do.
Dale Bush
Old March 10th 16, 03:09 AM posted to rec.aviation.soaring
George Haeh
While cell coverage in a particular area
may not be enough to sustain a voice call,
it may be sufficient to transmit an ~100
byte data packet. Retries might be made
by the software.
The only way to find out for sure anywhere
is by flying the software and observation
of the updated flight path on the ground.
That said there's some giant coverage
gaps in the US West. We won't know until
somebody tries.
At 22:36 09 March 2016,
proba=
no=
and=
more than we do.
Dale Bush
Old March 10th 16, 04:23 AM posted to rec.aviation.soaring
I fly in the Owens Valley area and find mobile text messaging is spotty at best. The iPhone will not retry a failed transmit, but will try for quite a while before reporting a failure. I'll sometimes text status to my wife and it might take a few tries to get it sent. I might see a response several hours later.
This year I upgraded my original inReach to a SE. So now she'll have the old one on a basic plan and I'll use the aviation plan. So no matter where we are, we can text each other via inReach.
Now that I've moved on from my ASH-26E to a ASW-27b, it's possible I might be landing out in some remote area. Having reliable comms with my crew is vital.
5Z
by the software.
Old March 10th 16, 04:39 AM posted to rec.aviation.soaring
2G
5Z
by the software.
I originally had SPOT I and liked it, but decided to try Inreach because of the messaging capability (if you land out in the middle of Nevada you WON'T have any cell service!). I gave up on it after the first year when I found it next to impossible to suspend the monthly service, which costs $75 per month. Figuring a 6 month flying season, that works out to close to $500 per year. I went back to Spot, which costs me about $100 per year. Yeah, you don't get altitude, but who really cares? My crew only cares if I stop moving. Yes, the Inreach does keep trying if a message doesn't get thru, but with 99% reliability that has not been an issue IMHO.
Tom
Old March 10th 16, 05:26 AM posted to rec.aviation.soaring
Surge
XCSoar also supports LiveTrack24.
LiveTrack24 support was added in XCSoar version 6.3 (2012/03/29)
Old March 10th 16, 04:50 PM posted to rec.aviation.soaring
In Reach now has a plan that allows you to suspend your tracking during the inactive months. Currently I am paying $5.17 a month. Their staff is very technical and their billing plans are complicated but if you persist with the right representative you can find a plan that works for our sport. DeLorme was just acquired by Garmin which will probably mean their products will become more user friendly. The ability to text from anywhere anytime is a huge advantage when landing in remote areas. The down side is that the text format is a virtual keyboard where you have to tediously select each letter from packets of three much as in an old telephone keypad. I have wondered how good I would be at that chore if agitated or injured after an outlandish.
Old March 10th 16, 05:34 PM posted to rec.aviation.soaring
JS
Alternatively you can connect InReach to a cell phone by bluetooth, and use the phone's texting features.
As Dale points out, you can buy in cheap - if you don't use tracking. There's a very usable InReach plan that includes tracking for $25 a month.
SPOT uses a less reliable satellite network than InReach.
APRS works well too. 3-minute intervals for Lat/Lon, Alt, Heading and Speed.
Like a GPS logger, if not mounted properly any tracker will be unreliable.
New technologies flight computer Ed Gaddy[_2_] Soaring 1 July 14th 08 07:43 PM
New technologies flight computer Ed Gaddy[_2_] Soaring 0 July 14th 08 03:41 PM
Flight tracking Nathan Young Instrument Flight Rules 9 March 19th 05 01:58 AM
