flight sotware for iphone?
Old May 31st 16, 01:34 PM posted to rec.aviation.soaring
HGXC[_4_]
Default flight sotware for iphone?
I may need a backup soaring program. I'm having trouble with my Oudie. Is there a flight software out there that I can download on my iphone?
Dennis
Old May 31st 16, 02:10 PM posted to rec.aviation.soaring
Sean[_2_]
iGlide. It is excellent.
Old May 31st 16, 04:53 PM posted to rec.aviation.soaring
jfitch
Dennis
iGlide. If you have a 6 or later, it will also use the built in barometer giving you pressure altitude. It works well enough you wonder why you have any other instruments.
Old May 31st 16, 05:22 PM posted to rec.aviation.soaring
Dennis
How badly does it eat up data?
Old May 31st 16, 07:03 PM posted to rec.aviation.soaring
Once flying it's self contained. No need for a data connection.
Old May 31st 16, 08:30 PM posted to rec.aviation.soaring
Any negatives from users? Have been looking at it for awhile. THough not IGC verified it seems to be about on par with Oudie
Old May 31st 16, 09:49 PM posted to rec.aviation.soaring
jfitch
It's personal preference, but I would put it head and shoulders above Oudie. Approximately a 30 year advance in UI by comparison. If you like a TTY, then Oudie is for you.
Old June 1st 16, 12:02 AM posted to rec.aviation.soaring
Casey[_2_]
I've used mine about a dozen times now. Several people told me that the GPS in the iPhone was not accurate enough. Well my first few flights had me taking off about 50-100' from where I actually did. But that is close enough for navigation but probably not comp turn points. So I got the Bad Elf and the accuracy is spot on. The only thing is iGlide will only go into vertical view and not landscape putting my bad elf connection on the bottom of the iPhone. My knee hit the Bad Elf and broke the connection inside. Bad Elf replace for free and now I slid my iPhone up so I would not hit the bottom of it. I also move the entire mount out of the way when I exit. iGlide is expensive, but very nice and very easy to use. And the iPhone 6Plus S is sunlight readable and is mounted perfect for face timing my wife.
Old June 1st 16, 05:59 AM posted to rec.aviation.soaring
Ramy[_2_]
There is also winpilot for iPhone/iPad.
Ramy
Old June 1st 16, 01:19 PM posted to rec.aviation.soaring
joesimmers[_2_]
I have the lite version of Iglide, it is cheap ($35 range)
It is perfect for a backup glide computer.
By far the easiest most user friendly UI of anything out there.
This is important if you end up needing it but have not used
it for a while.
iPhone 5 vs iPhone 6 sunlight readability 6PK Soaring 2 March 23rd 16 12:54 AM
iGlide update for iPhone 6 (4.7 inch) and iPhone 6 plus (5.5 inch) Sean Fidler Soaring 29 March 9th 15 04:24 AM
Free flight computer software for iPad/iPhone WinPilot Soaring 31 December 11th 13 02:22 AM
Loading flight data to iPhone from serial port devices Craig Funston Soaring 5 July 25th 11 09:09 PM
iPhone flight tracking fjohnson Products 0 August 19th 09 12:03 PM
