#21
"John Carrier" writes: Just out of curiosity, what is the source for all your PsubS data? In the case of the numbers I posted, the inital data comes from teh Standard Aircraft Characteristics for the particular aircraft. Using the characteristcs of teh engine, I generate the thrust curve for that altitude & speed range, which gives me the total for Drag. (For the engine, I can dope it out with Sea Level Static Thrust & SFC data, the bypass ratio, and overall pressure ratio.) Then come the fun part, breaking the drag numbers down to the individual contributions, and fit them into a predicticed curve for total drag coefficient. Then I test vs. certain point conditions - Vmax at Sea Level, and various altitudes for Vmax values, and PsubSmax at Sea Level, (Rate of Climb), and the altitude at which PsubSmax = 100 ft/minute (Service ceiling). If the numbers are within reason, then it gets plugged into teh flight model section of the Mighty Wurlitzer to deliver a PsubS matrix for all acheivable speeds and altitudes. (Much repetitive work, let teh computer do it!) While that's crunching away, I'm running mathematicl models of teh airplane geomety through LDstab and VLM to get the stability derivitives and the control moments. So far, I've got things tuned to deliver numbers with a nominal 3% accuracy to the flight test data, which is less than the variation that you'll find in a squadron-sized group of airplanes. A-4F always clean. TA-4J on occasion clean. Thanks, John. I don't have any good Skyhawk numbers yet, but it seems that on a little jet like that, the tanks would make a big difference, wrt drag. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
"John Carrier" writes: After some research concerning those aircraft that were decidedly subsonic in level flight (no pushover from altitude to gain greater speed), it would appear mach effect is the overriding concern. The last low altitude record before the transition to high (F-100, with several ... F-86, F-4D ... previous to that) were all done at the Salton Sea. Hi temp (higher TAS for mach) and low altitude (-227 MSL), delayed transonic drag rise. Quite so - they discovered that a pushover into teh course for teh records didn't make any difference - the drag increase was so great that it just didn't matter. We weren't teh only ones to use this - The Brits made a record attempt with a slightly modified Hunter over the Dead Sea. IIRC. That would be the only Speed Record set below Sea Level. The PsubS bulge doesn't occur until you get into the cleraly supersonic designs. Then it behooves a "low altitude" record to occur as high above MSL as possible. Hence the sageburner and later Greenamyer efforts in the high desert (less IAS, more TAS, 988 mph for Darryl ... great film by the way). I agree. The biggest deal there is that an afterburning turbojet really denifits from Ram Compressionwhich gets really large above Mach 1. You get a lot more thrust, without the penalty of more Ram Drag. Bottom line, in our running discussion, I now find your argument compelling. I was incorrect. I don't think that we were disagreeing on all that much, really. Sometimes in my efforts to put things into non-technical terms, I over-simplify. If you think I'm off, or not explaining properly, please do jump in with a correction or an improved explanation. Thank you for the questions, and helping me to improve my focus. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
Guy Alcala writes: Getting back to Pete's point, was the MiG-17's top level speed altitude (usually given as 13,000 feet) likely because of engine temp limits at lower altitude plus the use of A/B up higher, or for the reasons you mention in this thread? The other swept-wing subsonics sans A/B all seem to be fastest on the deck. I wonder if the F-86D/K/L Sabre's top speed graph was similar to the MiG-17's, owing to the A/B -- Walt? I think the only F-86 graphs I have are for navy Furies and the F-86H. As it just so happens, I have my F-86D Dash-1 (Flight Handbook) to hand. And it does have a Vmax curve. In the case of a clean airplane, 16,000# weight, in AB, the Vmax curve looks something like this: Alt Mach Vmph VKTAS 0 0.91 692 601 10,000 0.93 677 588 20,000 0.94 659 572 30,000 0.94 634 550 40,000 0.93 611 530 So, in the Dogship's case, it still holds to the pattern where teh maximum absolute speed it greates at Sea Level. (Airframe limits are 610 KIAS, no Mach Limit without external tanks.) I've often wondered about the MiG-17's numbers as well. The guy to ask, if he's monitoring, is Dave Sutton. It's kinda hard to argue when he can walk out into the hangar and check. I've suspected that its some sort of Q limit. My main suspect would be wing flex at high speeds reducing roll rate, like what happens with a B-47. At those speeds and altitudes, there's usually not enough temperature rise due to ram compression for that to be a factor. I've heard some funny stories about the teh flight limits on Soviet airplanes. Apparently, the Soviets were very conservative about the limits they placarded for their export airplanes. (I don't know about their domestic stuff) This may have been due to an, erm, "mistrust" in the levels of training received by their clients. I do know that when the Indian Air FOrce adopted the MiG-21 and Su-7. that they were very disappointed with the transition training that they received. But then, at that time, the IAF still had close ties with the RAF, not only having flown Brit equipment (Vampires, Hunters, and Gnats), but also having their pilots trained "RAF Style" in India, and arranging advanced training at the Fighter Leader's School and Empire Test Pilot's School. The IAF rewrote the handbook for the MiG-21 and Su-7, and in the process, opened up the flight envelopes a great deal. The Su-7 was surprising - it turned out to be much faster, adn with much better PsubS than th handbook limits had indicated. The biggest problems were that the control system was set up for Soviet Weight Lifters (I've never heard of anyone over-Ging an Su-7), and it would run itself out of gas in sight of its own airfield. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
#24
records didn't make any difference - the drag increase was so great that it just didn't matter. We weren't teh only ones to use this - The Brits made a record attempt with a slightly modified Hunter over the Dead Sea. IIRC. That would be the only Speed Record set below Sea Level. Actually, pushovers not allowed. The aircraft was prohibited from exceeding 300 meters altitude for the duration of the flight and had to be at 100 meters or less for the 4 passes on the 3-5 km course. Salton Sea is slightly below sea level if my sources are correct. R / John |
#25
Go to the FAA Type Certificate database at:
http://www.airweb.faa.gov/Regulatory...e?OpenFrameSet Each type certificate lists the maximum operating airspeed and Mach number. The airspeed is the limit until an altitude is reached at which the Mach number listed equals the airspeed. Then, the Mach number limits the aircraft. Be careful - some type certificates list the airspeed in Knots Indicated Airspeed (KIAS), some in Knots Calibrated Airspeed (KCAS), some in Knots Equivalent Airspeed (KEAS) and some in Knots True Airspeed (KTAS). |
#26
Peter Stickney wrote:
In article , Guy Alcala writes: Getting back to Pete's point, was the MiG-17's top level speed altitude (usually given as 13,000 feet) likely because of engine temp limits at lower altitude plus the use of A/B up higher, or for the reasons you mention in this thread? The other swept-wing subsonics sans A/B all seem to be fastest on the deck. I wonder if the F-86D/K/L Sabre's top speed graph was similar to the MiG-17's, owing to the A/B -- Walt? I think the only F-86 graphs I have are for navy Furies and the F-86H. As it just so happens, I have my F-86D Dash-1 (Flight Handbook) to hand. And it does have a Vmax curve. In the case of a clean airplane, 16,000# weight, in AB, the Vmax curve looks something like this: snipperoo Thanks for the data, Pete. Sorry for the delayed reply. Guy |
#27
On Wed, 16 Jun 2004 11:49:47 -0500, "John Carrier" wrote:
Just out of curiosity, what is the source for all your PsubS data? A-4F always clean. TA-4J on occasion clean. R / John You flew a scooter without the "auxiliary landing gear"? You, Sir, are a brave soul!!! Al Minyard |
GPS Altitude with WAAS | Phil Verghese | Instrument Flight Rules | 42 | October 5th 03 12:39 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
#1 Jet of World War II | Christopher | Military Aviation | 203 | September 1st 03 03:04 AM |
Aircraft engine certification FAR's | Corky Scott | Home Built | 4 | July 25th 03 06:46 PM |
