Record height for a winch launch?
Old November 29th 16, 01:53 PM posted to rec.aviation.soaring
Default Record height for a winch launch?
On Monday, 5 March 2001 01:00:08 UTC+1, MHende6388 wrote:
Curious what the highest sailplane launch from a winch has ever been for the
longest cable.
Michael
At the Reinsdorf Airfield whinch launches with 2,600m (8500ft) cable are possible. As long as I know, the record was a ASK-21 to 1380m (4500ft).
Old November 29th 16, 02:46 PM posted to rec.aviation.soaring
Bruce Hoult
longest cable.
Michael
This takes this month's award for replying to a thread last posted to 15 years ago.
I note that back then I said:
Winches are great, but 2000 ft over the end of the airfield is only
worth about the same as 1500 ft from a typical towplane that puts you in
the general direction of the lift.
In the intervening time I've found that I've been releasing from aero tow lower and lower and almost always getting away if the conditions are reasonable. I seldom tow over 1500 ft and at some sites often release at 700 - 800 ft above the strip. A few tow pilots have approached me after I come back, saying they though I must have some problem.
Flying in the back seat with other qualified pilots at the controls it's amazing how many people hold on to the tow straight through monster thermals at 1000 ft simply because they're fixated on their pre-flight notion to tow to 2000, 2500 or whatever. Or maybe don't yet have the surplus mental bandwidth in that aircraft to follow the towplane in active conditions and also at the same time keep an eye on the vario.
I know I was like that myself once, and only got woken up from it one day on a site check in a Grob at Omarama when the top competition pilot/CFI in the back seat asked me why I didn't take the booming thermal we just flew through. All I could think about was slack line recovery after the towplane was suddenly 50 ft below me -- not ask *why* the towplane was suddenly plummeting.
Old November 29th 16, 03:46 PM posted to rec.aviation.soaring
AS
longest cable.
Michael
There are several YouTube videos out there showing winch launches made from the Weelde, Belgium airbase going to 1,450m (4,760ft) using 3,000m of Spectra/Dyneema line and a K21.
https://www.youtube.com/watch?v=R1uC0lFVXNU
https://www.youtube.com/watch?v=-Dw6r_1r91M
https://www.youtube.com/watch?v=oyRlkOgkZho
We (Carolina Soaring Assoc.) do achieve anywhere between 1,300-2,100ft using our home built winch powered by a mildly hopped-up Ford 460 engine and 4,300ft of Spectra. Wind and pilot skills have a strong influence on the resulting release height.
Uli
Old November 29th 16, 04:36 PM posted to rec.aviation.soaring
longest cable.
Michael
I'm with Bruce: high release altitudes, who needs them. Taking pride in releasing low and getting away is a great way to start a good day. Our tow pilots know that and take pride in towing me to the low thermals. They also love to needle me the one or two times each year when I have to relight...
Things are a bit different when ballasted, but only a bit.
Old November 29th 16, 07:01 PM posted to rec.aviation.soaring
Aerobatic pilots need altitude. The pilots of Weelde were aerobatic glider pilots.
Old November 29th 16, 07:23 PM posted to rec.aviation.soaring
AS
longest cable.
Michael
...high release altitudes, who needs them
I am with Roel.b: Aerobatic pilots and students need high launch altitudes to keep cost down! ;-)
Old December 1st 16, 12:30 AM posted to rec.aviation.soaring
Releasing early is not just a cost issue. I used to take pride in releasing from aerotow in the first good thermal, below 1,000 feet or not. But at our gliderport, landing back and waiting for the queue to clear in front of you on a good day can take an hour or more depending on how many training flights/rides are stuffed in. Doesn't happen often but the penalty when it does is severe.
Chip Bearden
Old December 2nd 16, 02:23 AM posted to rec.aviation.soaring
Frank Whiteley
Indeed
https://www.youtube.com/watch?v=-Dw6r_1r91M ~1450m in 2 minutes. Record of 1740m was done in 2007 with run of 3000m.
IIRC, the winch (not the mel ad video) that was used in the record 1700m launch and some launches
https://www.youtube.com/watch?v=zFKs...F0FF821E223010
Check out this first solo and her video
http://www.northdevongazette.co.uk/n...ight_1_4797335
Frank Whiteley
Old December 2nd 16, 04:36 PM posted to rec.aviation.soaring
Indeed
Frank Whiteley
Number of aerobatic glider pilots in the Chicagoland area (4 clubs including Beloit WI) is exactly Zero. High tows, who needs them?
Old December 4th 16, 12:53 AM posted to rec.aviation.soaring
kirk.stant
Herb, what do you do on days when there is no lift?
Take a high tow then spend a few exhilarating minutes pulling G's and making the world go around - you just haven't lived until you have looked up at the ground from the top of a loop, or felt that moment of stillness at the apex of a hammerhead (stall turn) when there is just the silent rotation of your glider before it accelerates back straight down...
You guys have K-21s, don't you? Use them!
Seriously - if you have the opportunity to take an acro course - do it; it will open up a whole new way to enjoy gliders, and improve your flying skills.
Kirk
66
Have enjoyed acro in a variety of gliders including G-103 Acros, K-21s, 2-32s, 1-26s, L-13ACs and an incredible Swift S-1 (9G's on that one!!!). Oh, and maybe a little in my LS6... ;^)
How to get maximum height on a winch launch? Dan G Soaring 38 December 22nd 16 01:29 AM
New winch height record Bill Daniels Soaring 74 December 2nd 07 12:54 PM
Winch launch speed versus height gain Neil Soaring 20 November 9th 07 01:57 AM
Perlan height record in Argentina Charles Yeates Soaring 3 September 1st 06 01:59 PM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 01:33 AM
