iPhone upload to OLC
Old July 5th 17, 03:04 PM posted to rec.aviation.soaring
TomNau
Default iPhone upload to OLC
Does anyone use (or is it possible to use) an iPhone to upload their flight logs to the OLC? Thanks.
Old July 5th 17, 04:10 PM posted to rec.aviation.soaring
Dan Marotta
I've done it with an Android phone, so you should be able to do it with
your iPhone. You'll need to have the igc file on the phone, or a way to
access it from the phone, and then just use a web browser to do the deed.
Dan, 5J
Old July 5th 17, 05:34 PM posted to rec.aviation.soaring
jfitch
Where is the IGC file? If you are using an iPhone app to generate it, I believe that app would need the built in facility to upload (iGlide for example). iOS 10 does not have a Finder, or File explorer, or otherwise user exposed file system. iOS 11 is supposed to have this facility. I believe Android has had it nearly from the beginning.
You can of course tether your iPhone to your computer and upload that way.
Old July 5th 17, 06:28 PM posted to rec.aviation.soaring
TomNau
My IGC files get written to an SD card. I thought maybe I could connect a card reader to my iPhone and use that to upload but that may not be possible.
Old July 6th 17, 04:13 AM posted to rec.aviation.soaring
I use a HooToo thumb drive to copy files to the iPhone, then export to DropBox. Safari recognizes DropBox as a source of files to upload to OLC.
If you're stuck with a SD card, then I'm sure there's a product that allows you to transfer to the iPhone/DropBox for upload to OLC or any other website.
-Tom
Old July 6th 17, 02:14 PM posted to rec.aviation.soaring
TomNau
Dropbox. Thanks Tom! I'll give that a try.
Old July 7th 17, 11:19 PM posted to rec.aviation.soaring
Sean Fidler
https://www.ebay.com/i/322423997636?...D1251947428669
Old July 9th 17, 04:26 AM posted to rec.aviation.soaring
TomNau
It worked! I downloaded my flight to Dropbox with a card reader and then uploaded the file to OLC. Thanks!
Old July 9th 17, 06:03 AM posted to rec.aviation.soaring
I-glide will upload directly to OLC. Fast and easy.
Old July 9th 17, 06:14 AM posted to rec.aviation.soaring
But how do you get the IGC file into iGlide? That's what the OP was wanting to do. If iGlide is running during the whole flight, then it will have a complete IGC file. But I do other things with my iPhone during flight, like communicate with my wife/crew once out of radio range, and take photos, and use WingX Pro to look at current sectional charts, etc...
I recently got a Air Vario (Butterfly) with the connect stick and have managed to get my iPhone to connect to the WiFi, but I can't figure out how to download the IGC file from the vario to the iPhone. Probably worth starting a new thread.
5Z
iPhone 5 vs iPhone 6 sunlight readability 6PK Soaring 2 March 23rd 16 12:54 AM
iGlide update for iPhone 6 (4.7 inch) and iPhone 6 plus (5.5 inch) Sean Fidler Soaring 29 March 9th 15 04:24 AM
--- New Aviation Upload Site --- APW[_2_] Piloting 1 October 29th 08 05:31 PM
--- New Aviation Upload Site --- APW[_2_] Home Built 2 October 27th 08 02:15 PM
Trying a PowerPost 200 upload B58.jpg (3/3) (616 k) Darrell Aviation Photos 0 December 27th 06 12:37 AM
