There does not appear to be anything wrong with the integrated flash memory
but has anbody had problems with the internal RAM backup power battery failing on this unit? |
The internal battery is a lithium button battery which will fail after 5 to 10 years. When it fails the unit's electronic security seal and settings and files will be lost. It is pretty easy to replace the battery, but you should have an LX Navigation dealer like myself do it because there are several similar batteries and you don't want to change the wrong one. Also, only a dealer can re-seal the unit for you. I can change the battery and re-seal it here for $30. I can recalibrate the logger altimeter for an additional $95, plus return shipping costs.
Best Regards, Paul Remde Cumulus Soaring, Inc. On Monday, April 2, 2018 at 3:26:58 AM UTC-5, wrote: There does not appear to be anything wrong with the integrated flash memory but has anbody had problems with the internal RAM backup power battery failing on this unit? |
What Paul said.
I had one that came with my Stemme and, like yours, it went stupid every time I shut down.Â* Since I didn't care about badges, records, or contests, I opened mine, noted the battery size, and bought one at the local hardware store.Â* Turned out that the new battery was thicker than the old and, when I tried to install it, I broke the battery holder. Undeterred, I bought a bag of battery holders from Amazon (5 holders for $10), and removed and replaced the battery holder.Â* Now the unit worked, but I hated it so I replaced it with a ClearNav system. Much happier now! On 4/2/2018 5:16 AM, Paul Remde wrote: The internal battery is a lithium button battery which will fail after 5 to 10 years. When it fails the unit's electronic security seal and settings and files will be lost. It is pretty easy to replace the battery, but you should have an LX Navigation dealer like myself do it because there are several similar batteries and you don't want to change the wrong one. Also, only a dealer can re-seal the unit for you. I can change the battery and re-seal it here for $30. I can recalibrate the logger altimeter for an additional $95, plus return shipping costs. Best Regards, Paul Remde Cumulus Soaring, Inc. On Monday, April 2, 2018 at 3:26:58 AM UTC-5, wrote: There does not appear to be anything wrong with the integrated flash memory but has anbody had problems with the internal RAM backup power battery failing on this unit? -- Dan, 5J |
Momentary GPS data dropouts with PowerFLARM to SN10A to Oudie2 setup | kirk.stant | Soaring | 8 | May 7th 13 03:06 PM |
FS SPS-1 power/data box- 2 nimbus cradles - Ducati ignition box | Devin Bargainnier | Soaring | 0 | April 13th 11 05:18 AM |
Wanted Power/data connectors for Compaq Aero 1500 PDAs | Paul Remde | Soaring | 3 | April 16th 10 01:23 AM |
LX 7007 Pro IGC (used) | Werner Rüegger | Soaring | 5 | August 1st 09 11:52 PM |
gps-nav to ipaq 3600 data and power | Rich Chesser | Soaring | 2 | May 26th 04 02:59 AM |
