#21
On Tuesday, April 3, 2018 at 8:24:03 PM UTC-5, MNLou wrote:
Yeah Herb - WTF? (Tony paid me to post this ![]() Lou Flying downwind is for hang and para-gliders. We haven't done that in contests since the early 70's. But I do enjoy looking at Tony's excellent adventures now and then. Take note: if you disagree with me, that's fine. Just exercising my right to an opinion, that's all. |
On Monday, April 2, 2018 at 10:47:02 PM UTC-7, krasw wrote:
tiistai 3. huhtikuuta 2018 2.16.45 UTC+3 kirjoitti: The theoretical number of times the batteries of each type can be cycled is irrelevant if they will die of old age in a number of years, even if that's 10+ years for LiFePO4 and only 3-4 years for SLA in my use. In my experience lifetime of LFP is not better than SLA. My first battery died completely in 6 months, second had much reduced capacity after 2 seasons. Idea that chinese LFPs last thousand cycles or decade is just false. In my experience LFP batteries are much better than SLA and deliver close to the label AH for many cycles. And if you drop them on your foot is does not hurt as bad. Richard Richard |
I have flown with both an LFP and SLA battery in my ship for 5 years. I alternate which one is primary and which one is secondary on each flight. A PowerSonic 12V14Ah SLA vs Powerizer 12V15Ah LFP. With all my instruments running the SLA voltage drops below the minimum requirements of my radio by 5 hours. My LFP has never failed to power everything up to a 7 hour flight.. The SLA gets replaced after 3 years. My LFP is six years old and still working perfectly.
When I fly in very cold conditions (0C) the SLA is usually not driving my radio by three hours. Again, the LFP has run up to six hours without any significant voltage drop. |
#24
Would you use any of the lithium batteries for initial hi current demand tasks such as electric pylon deployment and self-starter motors?
#25
On Tuesday, April 3, 2018 at 11:05:18 PM UTC-4, wrote:
I have flown with both an LFP and SLA battery in my ship for 5 years. I alternate which one is primary and which one is secondary on each flight. A PowerSonic 12V14Ah SLA vs Powerizer 12V15Ah LFP. With all my instruments running the SLA voltage drops below the minimum requirements of my radio by 5 hours. My LFP has never failed to power everything up to a 7 hour flight. The SLA gets replaced after 3 years. My LFP is six years old and still working perfectly. When I fly in very cold conditions (0C) the SLA is usually not driving my radio by three hours. Again, the LFP has run up to six hours without any significant voltage drop. My microair 760 likes the higher voltage of the LiFePo, and I needed two 12V9Ah SLAs for long flights; never had to switch to back-up with LiFePo. I also like the faster charge, and the way the new batteries maintain charge. |
#26
On Tuesday, April 3, 2018 at 10:12:41 PM UTC-4, Richard Pfiffner wrote:
On Monday, April 2, 2018 at 10:47:02 PM UTC-7, krasw wrote: tiistai 3. huhtikuuta 2018 2.16.45 UTC+3 kirjoitti: The theoretical number of times the batteries of each type can be cycled is irrelevant if they will die of old age in a number of years, even if that's 10+ years for LiFePO4 and only 3-4 years for SLA in my use. In my experience lifetime of LFP is not better than SLA. My first battery died completely in 6 months, second had much reduced capacity after 2 seasons. Idea that chinese LFPs last thousand cycles or decade is just false. In my experience LFP batteries are much better than SLA and deliver close to the label AH for many cycles. And if you drop them on your foot is does not hurt as bad. Richard Richard What if we want to drop it on Herb's foot? Chris |
#27
As seen on a late night TV talk show: The top reasons for using SLA/AGM batteries in gliders.
.. As tail ballast. .. To maintain the "cheap" glider pilot stereotype. .. Wir haben es immer so gemacht. Jim |
#29
On Tuesday, April 3, 2018 at 8:16:30 PM UTC-7, Duster wrote:
Would you use any of the lithium batteries for initial hi current demand tasks such as electric pylon deployment and self-starter motors? I would (and do) use a properly spec'd LFP for that purpose. However saying so will start an epic chit fight on this thread like the other ones. So it would be best to live in the past and use whatever your copyright 1995 flight manual says to use. Don't do so unless you are familiar with all the issues and able to make a proper engineering call. |
#30
On Monday, April 2, 2018 at 1:14:19 PM UTC-4, john firth wrote:
Recently I tested two 12v SLA s which had been in use sequentially for some years usually recharged before going going flat, or at least within one day. Both were run down to 10.5 v with a 10 ohm load and then recharged to 14v, The Yuasa 7 AH bought 2005 was good for about 2.5 AH the UB 1280 8AH 6 years old good for 2AH. On this showing the Yuasa look like the better battery. Both were used as panel supplies running at .5 A load. Any opinions on competing SLA batteries? John The specs on the Dakota 12v 10 ah ($99) bats look good Any experiences? JMF |
LiFePO4 batteries | JS | Soaring | 26 | October 15th 12 02:51 PM |
Batteries Included | Mitchell Holman | Aviation Photos | 0 | September 21st 08 12:33 AM |
AGM Batteries | Dave Anderer | Owning | 13 | March 29th 08 07:38 PM |
2-Batteries | [email protected] | Soaring | 69 | January 4th 07 04:09 AM |
160 new batteries | Mal | Soaring | 0 | October 27th 06 11:36 AM |
