Wing Wheel by Andy (GY)
Old April 28th 18, 07:55 AM posted to rec.aviation.soaring
Default Wing Wheel by Andy (GY)
Andy,
if you see this, could you let me know if you upgraded your wing wheel design so that its hieght could be adjusted? You posted that you were going to do that back in 2010...
if so, could you post pics of the new design and perhaps describe it a bit.
i'd like to build a wing wheel for ground handling my glider, your design seemed very straight forward, what I could see of it from the pics you posted on the SSA picture gallery...
Regards,
Mike V
N171XX, Mini Nimbus "MV"
Old May 10th 18, 11:35 PM posted to rec.aviation.soaring
Hi Mike, we share the same wing. Will take pics for you, but mine is converted unicycle with height adjust, bonded to wing cuffs, easy and cheap ($20usd)
Cheers,
Andy
NZ
Mosquito
Old June 22nd 18, 01:08 AM posted to rec.aviation.soaring
Hi mike, apologise for delay.
The height is already adjustable theough the standard unicycle seat post system, identical to most bikes. The wheel can also rotate 360 degrees or ge locked. The wing cuff was bonded to short tube underneath (seat post), and the unicycle wheel locked under. I did have to grind off the pedal crank assy.
My direct email is " will get detail pics asap.
Old June 27th 18, 09:06 AM posted to rec.aviation.soaring
Pics by request as I seem unable to copy and paste here
Old July 23rd 18, 10:15 PM posted to rec.aviation.soaring
Paul Agnew
Pics, please, Andy. I’ve been unsuccessful reaching you via email and PM.
Thanks!
Paul A.
Blue Jet 941@ Gmail .. Com
Wing wheel needed... [email protected] Soaring 5 July 17th 15 09:21 PM
Youth soaring program looking for wing wheel for large-chord wing Jay[_2_] Soaring 1 September 17th 14 03:44 AM
FS - IMI Wing Wheel slbair Soaring 0 September 17th 13 05:27 PM
making a wing wheel Tony[_5_] Soaring 10 June 5th 11 06:03 AM
Tow-Out Wing Wheel [email protected] Soaring 0 July 14th 06 12:49 AM
