Have there been stall spins during an aero tow?
Today, I had a very scary aero retrieve. From being towed to fast to-to slow. Anyways the scaries part was when, the tow plane started to climb and to slow. The indicated speed on the glider was 50 knots and decreasing. The glider kept slowing down and sinking under the tow plane into the wake. By this time the glider felt extremely sloopy and it felt like it was ready to drop into stall. Fortunately as I felt the wing wanting to drop, the tug leveld some and got back to a decent speed. Yes I did radio the pilot askig for 20 indicated more. And I was attempting to release when I hit the wake, but the release on the standard cirrus is far, and my extention had moved from my legs. |
Btw std cirrus has a cg hook
I also experienced recently slow takeoffs in my fully ballasted 29 which felt very uncomfortable. The yaw string was all over the place often showing skidding. I am noticing it more in my 18m 29 than my 27, perhaps since the wing loading is higher, or due to more adverse yaw. Seems like 70 knots should be the minimum, preferably 75 knots.
Ramy |
On Monday, August 6, 2018 at 12:10:19 AM UTC-5, Ramy wrote:
I also experienced recently slow takeoffs in my fully ballasted 29 which felt very uncomfortable. The yaw string was all over the place often showing skidding. I am noticing it more in my 18m 29 than my 27, perhaps since the wing loading is higher, or due to more adverse yaw. Seems like 70 knots should be the minimum, preferably 75 knots. Ramy From a glider pilot (who has BTDT) and a current towpilot - the answer is simple, if not always effective: ALWAYS establish comms with the tow pilot before the tow (satisfies the FAR requirement for a pilot to pilot briefing).. If you (or the tow plane) do not have working radios, get face to face with the tuggie and TELL HIM what speed to fly - that is YOUR responsibility.. Once on tow, if the tow starts to slow down - TELL HIM ON THE RADIO TO SPEED UP! That's why you have the darn thing! Then, if the tow continues to get dangerously slow (when you can't stay above the wake) and radio or wing rocks do not solve the problem, release (assuming you are high enough for a safe PTT) and get face to face with the tow pilot when he lands and explain the problem, nicely. Especially with tow pilots that are not also glider pilots, they REALLY may not understand what is going on at the back end of the rope! Most tow pilots really want to give you a good tow, but feedback can be rare; take the time to debrief you tow pilot if anything unusual happens on tow, and when possible brief and practice emergencies on tow - visual signals (both glider and towplane), simulated tow plane engine failure, glider dive brakes open, etc. Makes the tow more interesting than just a drag around the local area waiting for 3000' AGL to appear on the clock... Cheers, 66 |
On 8/6/2018 7:47 AM, kirk.stant wrote: Big SnipÂ* Makes the tow more interesting than just a drag around the local area waiting for 3000' AGL to appear on the clock... Cheers, 66 As an active glider pilot and retired tow pilot, it always disappointed me as the tuggie when the glider pilot would tell me he would get off at 3,000' AGL.Â* Then we'd proceed tow through super lift only to have him release in sink at 3,000' AGL and practically beat me back to the ground.Â* Just one of my pet peeves because the tuggie usually gets the blame for the poor judgement of the glider pilot.Â* Get off in lift, not at some predetermined altitude! -- Dan, 5J |
On Sunday, August 5, 2018 at 10:49:48 PM UTC-4, wrote:
Have there been stall spins during an aero tow? Today, I had a very scary aero retrieve. From being towed to fast to-to slow. Anyways the scaries part was when, the tow plane started to climb and to slow. The indicated speed on the glider was 50 knots and decreasing. The glider kept slowing down and sinking under the tow plane into the wake. By this time the glider felt extremely sloopy and it felt like it was ready to drop into stall. Fortunately as I felt the wing wanting to drop, the tug leveld some and got back to a decent speed. Yes I did radio the pilot askig for 20 indicated more. And I was attempting to release when I hit the wake, but the release on the standard cirrus is far, and my extention had moved from my legs. I had to release a couple of times last year; put the first down to new tow pilot. Second... hmmm. When the Pawnee did its annual, transponder (actually encoder) failed, and leak in pitot/static system and a subtly bent pitot tube were found to be responsible. The towplane speed looked good, mine, not so much in a Std class glider with the stick on the back stop, still sinking. When in doubt, release and debrief; multiple times, find what the problem is (I had checked my pitot/static system for leaks too). One problem inexperienced tow pilots cause without thinking is pulling up in lift to use the energy - while the glider is still in the sink surrounding... |
I think the worst I have had was in a contest (upstate NY), ASW-20, maybe 3/4 load of water, summer, weak Citabria towplane.
I felt like I was just barely hanging on. Yes, I radioed the tug but IIRC he had a radio issue that was fine on the ground. |
On Monday, August 6, 2018 at 8:00:52 AM UTC-7, Dan Daly wrote:
On Sunday, August 5, 2018 at 10:49:48 PM UTC-4, wrote: Have there been stall spins during an aero tow? Today, I had a very scary aero retrieve. From being towed to fast to-to slow. Anyways the scaries part was when, the tow plane started to climb and to slow. The indicated speed on the glider was 50 knots and decreasing. The glider kept slowing down and sinking under the tow plane into the wake. By this time the glider felt extremely sloopy and it felt like it was ready to drop into stall. Fortunately as I felt the wing wanting to drop, the tug leveld some and got back to a decent speed. Yes I did radio the pilot askig for 20 indicated more. And I was attempting to release when I hit the wake, but the release on the standard cirrus is far, and my extention had moved from my legs. I had to release a couple of times last year; put the first down to new tow pilot. Second... hmmm. When the Pawnee did its annual, transponder (actually encoder) failed, and leak in pitot/static system and a subtly bent pitot tube were found to be responsible. The towplane speed looked good, mine, not so much in a Std class glider with the stick on the back stop, still sinking. When in doubt, release and debrief; multiple times, find what the problem is (I had checked my pitot/static system for leaks too). One problem inexperienced tow pilots cause without thinking is pulling up in lift to use the energy - while the glider is still in the sink surrounding... A simple improvement, if not a fix: If it feels sloppy on tow, put in another notch of positive flaps. Jim |
On Monday, August 6, 2018 at 11:20:51 AM UTC-4, JS wrote:
On Monday, August 6, 2018 at 8:00:52 AM UTC-7, Dan Daly wrote: On Sunday, August 5, 2018 at 10:49:48 PM UTC-4, wrote: Have there been stall spins during an aero tow? Today, I had a very scary aero retrieve. From being towed to fast to-to slow. Anyways the scaries part was when, the tow plane started to climb and to slow. The indicated speed on the glider was 50 knots and decreasing. The glider kept slowing down and sinking under the tow plane into the wake.. By this time the glider felt extremely sloopy and it felt like it was ready to drop into stall. Fortunately as I felt the wing wanting to drop, the tug leveld some and got back to a decent speed. Yes I did radio the pilot askig for 20 indicated more. And I was attempting to release when I hit the wake, but the release on the standard cirrus is far, and my extention had moved from my legs. I had to release a couple of times last year; put the first down to new tow pilot. Second... hmmm. When the Pawnee did its annual, transponder (actually encoder) failed, and leak in pitot/static system and a subtly bent pitot tube were found to be responsible. The towplane speed looked good, mine, not so much in a Std class glider with the stick on the back stop, still sinking. When in doubt, release and debrief; multiple times, find what the problem is (I had checked my pitot/static system for leaks too). One problem inexperienced tow pilots cause without thinking is pulling up in lift to use the energy - while the glider is still in the sink surrounding... A simple improvement, if not a fix: If it feels sloppy on tow, put in another notch of positive flaps. Jim Std Cirrus has no flaps. My Std Class glider has no flaps. Agree flaps work - if you have them. |
| Thread Tools | |
| Display Modes | |
| Stall/spin and ground reference maneuvers | Bill D | Soaring | 55 | March 11th 14 05:35 PM |
| Improved shear/stall-spin alarms | KiloKilo[_2_] | Soaring | 23 | June 12th 13 12:55 AM |
| Another stall spin | Jp Stewart | Soaring | 153 | September 14th 12 08:25 PM |
| Stall/ Spin testing the RV-12 | cavelamb himself[_4_] | Home Built | 3 | May 14th 08 08:01 PM |
| Glider Stall Spin Video on YouTube | ContestID67 | Soaring | 13 | July 5th 07 09:56 AM |
