Cobra Trailer Part Needed
Old August 15th 18, 02:02 AM posted to rec.aviation.soaring
[email protected][_2_]
Default Cobra Trailer Part Needed
I am in the middle of converting my Cobra trailer tongue from the round tube (broken) to the newer square tube type and find I am missing a part. There is a rubber/plastic plug that goes in the rear end of the square tube to keep debris and small critters from getting inside the trailer box. W&W does not stock this plug. Anybody in the US got a spare one of these I could get quickly? Lots of this type of thing online but none look to be exactly the right thing.
Terry
Old August 15th 18, 03:18 AM posted to rec.aviation.soaring
Carve one out of a wood 2x4. Plus, I doubt any "critters" will make it past the damper mechanism. A couple of layers of Gorilla tape will also work.
Old August 15th 18, 03:23 AM posted to rec.aviation.soaring
2G
Terry
I think I have this plug - I will check in the morning.
Tom
Old August 15th 18, 10:38 PM posted to rec.aviation.soaring
2G
Terry
I do have it, but I now realize where it came from and have to use it!
Tom
Old August 15th 18, 10:45 PM posted to rec.aviation.soaring
2G
Terry
This supplier carries them:
https://www.mocap.com/tube-plugs-square-metric.html
Old August 16th 18, 01:41 PM posted to rec.aviation.soaring
OHM Ω http://aviation.derosaweb.net
Yes, critters can get pass the damper mechanism. A field mouse can squeeze past some incredible small holes.
I use a bunch of stainless steel scrubbing pads stuffed into the tube. You can find them at nearly any store that sells kitchen cleaning supplies (big box, grocery stores, hardware, etc).
Good 15 m Cobra trailer needed urgent Steve Koerner Soaring 2 May 6th 14 02:54 AM
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
Cobra Trailer Top Adjustment Advice Needed jcarlyle Soaring 3 June 30th 08 01:07 PM
Cobra Trailer fender needed! [email protected] Soaring 1 April 28th 08 01:56 PM
