I have such a radio, and when you turn one of those concentric knobs, the other one turns too, unless you hold it firmly. Thus it takes two hands to turn only one knob. How can I adjust it work as intended?
On Friday, September 7, 2018 at 5:39:17 PM UTC-7, wrote:
I have such a radio, and when you turn one of those concentric knobs, the other one turns too, unless you hold it firmly. Thus it takes two hands to turn only one knob. How can I adjust it work as intended? On most dual concentric knobs, you take off the cap of the smaller (closer) knob and loosen the screw under the cap. Then pull the knob out a bit and tighten the screw. Check it for friction, make sure it's really tight and put the cap back on. Jim |
On Friday, September 7, 2018 at 8:47:09 PM UTC-4, JS wrote:
On Friday, September 7, 2018 at 5:39:17 PM UTC-7, wrote: I have such a radio, and when you turn one of those concentric knobs, the other one turns too, unless you hold it firmly. Thus it takes two hands to turn only one knob. How can I adjust it work as intended? On most dual concentric knobs, you take off the cap of the smaller (closer) knob and loosen the screw under the cap. Then pull the knob out a bit and tighten the screw. Check it for friction, make sure it's really tight and put the cap back on. Jim Thanks Jim. That did it, and was easy. I had no idea that cap comes off. Was looking for screws on the sides, and there are none. |
| Thread Tools | |
| Display Modes | |
| Becker AR4201 | John Williams | Soaring | 3 | August 12th 17 04:09 PM |
| Becker AR4201 | Robin Birch[_2_] | Soaring | 0 | April 21st 14 07:22 PM |
| Becker AR4201 | Robin Birch[_2_] | Soaring | 0 | April 21st 14 06:11 PM |
| BECKER AR4201 | guts | Soaring | 1 | April 23rd 12 09:50 PM |
| VHF Becker AR4201 | Philippe | Home Built | 2 | July 9th 04 09:30 PM |
