Cobra Trailer Jam-nuts (loose)
Old September 7th 18, 07:02 PM posted to rec.aviation.soaring
Default Cobra Trailer Jam-nuts (loose)
Another Ship came in yesterday with Cobra...........yep, another loose nut! The rubber pad that protects the spar is also being compressed when the jam-nut is tightened, so UH's fix would be the best way to fix this issue. Jam-nut into another jam-nut. While we're looking things over in our trailers, it's not a bad idea to check all the adjustable fittings too. I have seen wing tip (assembly bar) adjustment so far out that the wing tip jumped out as trailer went down a rough road. Also found a scar on my root rib.............fixed it and next time I assembled the ship, the damned scar reappeared! Turned out the padding on the spar saddle, had compressed to the point the root rib started hitting the mid-span wing saddle, as the wing was pulled out.
Cobra is still the best trailer out there, thanks Spindleberger!
JJ
Old September 8th 18, 02:17 PM posted to rec.aviation.soaring
On my last Cobra, I replaced all four with nylock nuts. It took a long time to turn them into position due to the limited space, but it solved the problem permanently.
Cobra Trailer VIN MSC Soaring 3 July 1st 18 07:05 PM
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
Cobra Trailer [email protected] Soaring 22 December 7th 06 11:38 PM
FS: Cobra Trailer Ed Byars Soaring 0 September 22nd 03 04:47 PM
