Rechargeable Zinc-Air battery moves closer to commercialization
Old September 27th 18, 04:06 PM posted to rec.aviation.soaring
son_of_flubber
Default Rechargeable Zinc-Air battery moves closer to commercialization
https://www.nytimes.com/2018/09/26/b...lar-power.html
Old September 27th 18, 05:12 PM posted to rec.aviation.soaring
If it is as "simple" as claimed, why is the circuit board (seen in the photos in the article) so complicated? Also, this has been in development for some years, so clearly there are some significant obstacles (see he https://en.wikipedia.org/wiki/Zinc%E...hargeable %29 ). If they've solved them, cool!
Old September 27th 18, 06:40 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
https://www.nytimes.com/2018/09/26/b...ironment/zinc-
battery-solar-power.html
obstacles (see he
Zinc%E2%80%93air_battery#Secondary_%28rechargeable %29
I notice the article doesn't mention the energy density, capacity or
charge/discharge rates of that battery. Without this info we can't know
whether this technology is only useful for powering lightbulbs, radio
repeaters etc. or if it has enough grunt to run a car or an FES system.
In this the NY Times is, little better than New Scientist, which
periodically talks up some doctoral student's new, lab-scale battery
technology that, thesis written, is never heard of again.
Martin | martin at
Gregorie | gregorie dot org
Old September 28th 18, 12:00 AM posted to rec.aviation.soaring
"....which periodically talks up some doctoral student's new, lab-scale battery
technology that, thesis written, is never heard of again."
That also describes "Gliding International" when it comes to battery technology, electric airplanes and the like.
Old September 28th 18, 08:09 AM posted to rec.aviation.soaring
RW[_2_]
Ultra capacitors !
Old September 28th 18, 04:48 PM posted to rec.aviation.soaring
Soartech
Ultra capacitors !
A gallon of gasoline contains 120 million Joules of energy.
Now use this website to calculate what size ultra capacitor you would
need to achieve this amount.
http://hyperphysics.phy-astr.gsu.edu...ic/capeng.html
Old September 28th 18, 05:49 PM posted to rec.aviation.soaring
Dave Nadler
Try a dose of reality:
https://www.youtube.com/watch?v=JELN...ature=youtu.be
Old September 28th 18, 05:58 PM posted to rec.aviation.soaring
On Fri, 28 Sep 2018 07:48:13 -0700, Soartech wrote:
Ultra capacitors !
A more useful equivalent for comparison is that a litre of petrol is as
near as dammit 10 kWh in energy terms - and petrol spiked with methanol
will be a bit less: 9-9.5 kWh at a guess,
So a US gallon (3.78l) would be the equivalent of 37.8 kWh of
unadulterated petrol or 34-36 kWh if its a gasoline/methanol blend.
By comparison, the Gen 2 FES battery has 14 cells, each of 2.1 kWh, or
29.4 kWh for the standard 14 cell pack, so an hPh Shark (dual packs
carried has just less than 60kWh of energy onboard, or 1.6 US gallons of
avgas equivalent.
The dual packs are about 18 litres total volume, so on a volumetric basis
they're about 1/3 as good as petrol when it comes to storing energy in
limited space.
Martin | martin at
Old September 28th 18, 06:09 PM posted to rec.aviation.soaring
Dan Marotta
Dammit, I hate it when someone uses math to prove a point... :-D
Ultra capacitors !
avgas equivalent.
limited space.
Dan, 5J
Old September 30th 18, 01:38 AM posted to rec.aviation.soaring
Ultra capacitors !
avgas equivalent.
limited space.
Martin | martin at
But, an electric motor is more than three times as efficient as an internal combustion engine - 98% vs. 33% - so they don't need as much 'fuel'.
PowerFLARM portable: rechargeable battery recommendations ursus Soaring 1 February 1st 12 07:02 PM
Harry (finally) lights the torch! ...and etches some zinc off too! wright1902glider Home Built 29 February 22nd 09 07:23 PM
Powdered zinc oxide? Michael Horowitz Home Built 4 November 2nd 08 02:57 PM
Typhoon 'How much closer do you want me' Grouper Aviation Photos 1 May 25th 08 02:54 AM
Zinc Chromate in 2005 Michael Horowitz Home Built 4 October 16th 05 07:44 PM
