Is there a 3-circuit socket which is more easily serviced when the total pressure (pitot) O-ring fails?
Jim |
On Friday, March 8, 2019 at 10:48:26 PM UTC-5, JS wrote:
Is there a 3-circuit socket which is more easily serviced when the total pressure (pitot) O-ring fails? Jim Jim, it is possible to replace the last o-ring (4mm) on a multi-probe. I did it once. I must admit a lot of bad words came out of my mouth over a period of half a day, but it was done. You would need to manufacture your own tooling to do this and have incredible amount of patience, but I am certain you will succeed. |
Yep done the outer, dental pick tool, and a Delrin rod to seat the new O-ring in place. Done outside on the ramp at an airport, and yes lots of swearing... |
On Sunday, March 10, 2019 at 5:41:10 PM UTC-7, Darryl Ramm wrote:
Yep done the outer, dental pick tool, and a Delrin rod to seat the new O-ring in place. Done outside on the ramp at an airport, and yes lots of swearing... There's a kit labeled "TE Probe" at home. Came with one of the 27s. Also a spare UN socket which by now could need new O-rings. The kit is like what you describe. Not thrilled about using it without better currency at swearing in German. Perhaps time to practice on the spare one. For a replacement... Is there a difference in serviceability between type UN, UNG and SUN sockets? This is for a friend's DG. There's always the possibility that any leak is the probe itself. I've seen two triple probes and a standard TE probe that didn't seal, when other probes used in the same socket did. Thanks, Jim |
Not being a mechanical engineer, could anyone enlighten me as to why the
o-rings are installed internally in the socket rather than externally on the probe?Â* In either case the o-rings are getting rubbed each installation/removal cycle and it seems light lubrication, like the skin oil from one's nose, would work nicely. That's how I lube the probe on my Stemme. And, BTW, the o-rings would be oh so much easier to replace... On 3/10/2019 7:11 PM, JS wrote: On Sunday, March 10, 2019 at 5:41:10 PM UTC-7, Darryl Ramm wrote: Yep done the outer, dental pick tool, and a Delrin rod to seat the new O-ring in place. Done outside on the ramp at an airport, and yes lots of swearing... There's a kit labeled "TE Probe" at home. Came with one of the 27s. Also a spare UN socket which by now could need new O-rings. The kit is like what you describe. Not thrilled about using it without better currency at swearing in German. Perhaps time to practice on the spare one. For a replacement... Is there a difference in serviceability between type UN, UNG and SUN sockets? This is for a friend's DG. There's always the possibility that any leak is the probe itself. I've seen two triple probes and a standard TE probe that didn't seal, when other probes used in the same socket did. Thanks, Jim -- Dan, 5J |
On Monday, March 11, 2019 at 4:56:13 PM UTC, Dan Marotta wrote:
Not being a mechanical engineer, could anyone enlighten me as to why the o-rings are installed internally in the socket rather than externally on the probe?Â* In either case the o-rings are getting rubbed each installation/removal cycle and it seems light lubrication, like the skin oil from one's nose, would work nicely. That's how I lube the probe on my Stemme. And, BTW, the o-rings would be oh so much easier to replace... In ESA probes the UN sockets (eg for triple probes) have the O-rings in the socket and the ST sockets (eg for TE/Static double probes) have the O-rings on the aluminium probe fitting but those ones are more prone to fractures of the fitting on older probes - at the O-ring groove of course. |
Dan:
For some reason the O-Rings on my South African glider get really dry & stiff. We use a very light coat of silicone "plumbers grease" on the probe about twice a year to fix that (petroleum based grease attacks the O-Ring). My US glider in Massachusetts doesn't have the problem. ROY |
Humidity difference?
On 3/11/2019 7:52 PM, Roy B. wrote: Dan: For some reason the O-Rings on my South African glider get really dry & stiff. We use a very light coat of silicone "plumbers grease" on the probe about twice a year to fix that (petroleum based grease attacks the O-Ring). My US glider in Massachusetts doesn't have the problem. ROY -- Dan, 5J |
On Monday, March 11, 2019 at 9:52:53 PM UTC-4, Roy B. wrote:
Dan: For some reason the O-Rings on my South African glider get really dry & stiff. We use a very light coat of silicone "plumbers grease" on the probe about twice a year to fix that (petroleum based grease attacks the O-Ring). My US glider in Massachusetts doesn't have the problem. ROY If everyone used this, we'd have fewer problems: https://www.amazon.com/Dow-Corning-V.../dp/B001UHMNW0 What I use on the o-rings I rely on in my day job, as well as my triple probe socket. T8 |
| Thread Tools | |
| Display Modes | |
| Proper Way to Insert Multi-Probe | Dan Marotta | Soaring | 18 | February 19th 18 02:31 AM |
| Prandtl multi probe receptacle used for TE only? | Matt Herron Jr. | Soaring | 12 | February 15th 18 09:32 PM |
| castellated socket | Stuart & Kathryn Fields | Home Built | 1 | June 3rd 08 01:37 PM |
| Replacing innertubes without replacing tires? | Ben Jackson | Owning | 28 | November 6th 06 05:54 PM |
| Multi - probe | KP | Soaring | 1 | March 7th 05 07:03 PM |
