A CG hook and high tow is a recipe for disaster. I only have CG on my Dg200, no problem at all with low tow.
We don’t allow anything other than Tost here, thank goodness. |
Why is CG and high tow a bad thing???
![]() Quote:
I'm more concerned with saving lives than anything else having been a second or two from losing mine. If your mechanics can't find the appropriate STCs and 337s perhaps you need to find another mechanic. I've been contacted by one tow pilot who has acknowledge my actions which influenced his facility to make the changes I recommended. By his acknowledgement it saved his life shortly thereafter. I've heard from commercial operators who experienced this event and realized the potential. They did the work needed to make the changes to a safer, more accessable system. Have a nice day. Walt Connelly Former tow pilot Now happily flying Whirlybirds. |
![]() Quote:
I don't follow you on the Schweizer vs Tost system regarding accidents. I have not seen those statistics, perhaps you could site them? I will say that in 7000 tows I have never had a problem with a CG hook glider but then again most of these are flown by more experienced pilots. It will be the student on solo or occasionally an older pilot who should no longer be flying who will upend you. Walt Connelly |
You don’t mention what type of fleet you have. Putting a Tost tow hook on a Pawnee, Super Cub or Husky is very simple mechanically and paperwork wise.
On Wednesday, May 1, 2019 at 12:02:59 PM UTC-4, Paul Agnew wrote:
Does anyone know the limits on these STC'd hooks? They claim to be better than Schweizer hooks, but don't list any numbers to substantiate it. (I've emailed an inquiry to them.) https://pacificaerialtowhooks.com/ I just heard back from Pacific Aerial Towhooks. #1200 glider weight limit using AC 43.13-2B, 804(d). Their release handles look to be at least 5:1 by design. PA |
On Monday, April 29, 2019 at 1:37:55 PM UTC-7, Jason Scott wrote:
Currently operating 3 tow planes, all with Schweizer hooks installed. I would love to get access to some concrete information on the issues with the Schweizer hooks, comparison between the two, and any concerns with the TOST system. My goal is to likely switch over the fleet, having personally experienced a situation with a glider losing directional control on tow, and causing momentary upset to the towplane. In my opinion, the TOST system is superior, and tangible information is the best way to present this opinion to the other parties involved in our operation. Pacific Aerial Tow Hooks has an FAA approved STC with a hook that has lower release forces than the Schwitzer hook. The tested release load on a new PATH hook is only 56 lbs with a 1000 lb tow load at 20 degrees. The whole kit is STCed on a wide variety of aircraft. |
On Wednesday, May 1, 2019 at 9:02:59 AM UTC-7, Paul Agnew wrote:
Does anyone know the limits on these STC'd hooks? They claim to be better than Schweizer hooks, but don't list any numbers to substantiate it. (I've emailed an inquiry to them.) https://pacificaerialtowhooks.com/ Paul as I replied to your email, The pacific Aerial Tow Hook is rated for a limit load of 1440 lbs. using AC 43.13-2B, 804(d) the glider can be 1200 lbs or a banner can be 720 lb, (although we recommend a banner limit of 600 lb.) The rope for glider towing is limited to 960 lbs breaking strength. The geometry of the Schweizer hook has a load ratio on the release of .377 and the PATH tow hook has a load ratio of .265, so the release loads on the Schweizer are 42% more. Also the ring is held in one location and can't move around like the Schweizer hook. |
Of tow hooks and wheel brakes | [email protected] | Soaring | 10 | June 11th 13 05:17 AM |
Roeger Hooks for ASW Sailplanes? | RAS56 | Soaring | 7 | October 24th 12 01:38 PM |
Towing Schweizer Gliders with tost rings? | [email protected] | Soaring | 12 | December 22nd 10 03:59 AM |
OTTFUR HOOKS | Paul Moslin | Soaring | 0 | January 5th 09 08:15 PM |
FS: Schweizer 1-34, Schweizer Open Trailer | F.L. Whiteley | Soaring | 2 | April 10th 04 02:52 AM |
