#31
On Tuesday, August 13, 2019 at 11:38:43 AM UTC+10, son_of_flubber wrote:
What are your favorite aircraft types (and modifications) for glider towing in high density altitude and/or short runways? eTugs are now certified in Australia and are in production. Tow costs are half avgas powered PA25 - 235 tugs. Michael |
#32
On Thursday, August 15, 2019 at 6:20:09 PM UTC-7, wrote:
On Tuesday, August 13, 2019 at 11:38:43 AM UTC+10, son_of_flubber wrote: What are your favorite aircraft types (and modifications) for glider towing in high density altitude and/or short runways? eTugs are now certified in Australia and are in production. Tow costs are half avgas powered PA25 - 235 tugs. Michael Michael, are they producing a two seat version of the eTug? Cheers, Craig |
#33
What are your favorite aircraft types (and modifications) for glider towing in high density altitude and/or short runways? Yes, there is a one and one half seater (single controls) has been converted, but remember the conversions are only of the existing aircraft. Aircraft are not being made from scratch. Michael |
#34
If you cant tow your glider behind a Turbo Čmelák, then shoud it not been towed at all
![]() http://www.flugzeuginfo.net/acdata_p...ta_z37t_en.php |
#35
I saw a friend towed (pulled) aloft in a IS28b2 Lark by Steve Wolf in his 450hp Samson biplane at an airshow in Spokane, WA. It was an impressive climb angle, to say the least.
#36
On Friday, August 16, 2019 at 1:30:50 PM UTC-7, George Underhill wrote:
I saw a friend towed (pulled) aloft in a IS28b2 Lark by Steve Wolf in his 450hp Samson biplane at an airshow in Spokane, WA. It was an impressive climb angle, to say the least. I only consume 1/2 gallon to launch my ASH31Mi motorglider to 3kft (the same was true for the 26e and DG400, and most every other self-launcher that I can think of, well maybe not the Space Shuttle). So, for a 4 hour flight my "burn rate" is 1 pint per hour. Tom |
#37
On Thursday, August 22, 2019 at 11:50:40 AM UTC-4, 2G wrote:
I only consume 1/2 gallon to launch my ASH31Mi motorglider to 3kft (the same was true for the 26e and DG400, and most every other self-launcher that I can think of, well maybe not the Space Shuttle). So, for a 4 hour flight my "burn rate" is 1 pint per hour. Self-launch gliders are obviously appealing, but I'm curious about their limitations wrt density altitude and turbulence. What is your climb rate in your typical density altitude? Do you ever launch in turbulent conditions with lots of sink? What density altitude leads you to cancel your flight? What is the highest density altitude that you have launched in? |
#38
It's not the same with other self-launchers, of course, but my S10-VT
has a turbocharged, 4-cylinder engine rated at 115 (nominal) horsepower.Â* With the turbo, it achieves its rated power to a very high altitude, which I haven't seen stated, but it has a published service ceiling of 33,000' MSL.Â* Density altitude has no effect on it other than some reduction in propeller efficiency and engine temperature limits.Â* I imagine the higher true airspeed for a given IAS at takeoff at high altitude airports makes up for reductions in wing lift.Â* At maximum power it burns around 5 gallons/hour (about 3.2 gph in cruise at 18,000' MSL for repositioning flights), so I'd guess I burn less than a half gallon of gas per normal soaring flight, including taxi and takeoff. Engine overhaul will cost a few pennies more than with the smaller ships... On 8/23/2019 10:30 AM, son_of_flubber wrote: On Thursday, August 22, 2019 at 11:50:40 AM UTC-4, 2G wrote: I only consume 1/2 gallon to launch my ASH31Mi motorglider to 3kft (the same was true for the 26e and DG400, and most every other self-launcher that I can think of, well maybe not the Space Shuttle). So, for a 4 hour flight my "burn rate" is 1 pint per hour. Self-launch gliders are obviously appealing, but I'm curious about their limitations wrt density altitude and turbulence. What is your climb rate in your typical density altitude? Do you ever launch in turbulent conditions with lots of sink? What density altitude leads you to cancel your flight? What is the highest density altitude that you have launched in? -- Dan, 5J |
#39
On Friday, August 23, 2019 at 12:30:29 PM UTC-4, son_of_flubber wrote:
On Thursday, August 22, 2019 at 11:50:40 AM UTC-4, 2G wrote: I only consume 1/2 gallon to launch my ASH31Mi motorglider to 3kft (the same was true for the 26e and DG400, and most every other self-launcher that I can think of, well maybe not the Space Shuttle). So, for a 4 hour flight my "burn rate" is 1 pint per hour. Self-launch gliders are obviously appealing, but I'm curious about their limitations wrt density altitude and turbulence. What is your climb rate in your typical density altitude? Do you ever launch in turbulent conditions with lots of sink? What density altitude leads you to cancel your flight? What is the highest density altitude that you have launched in? Also... How long is your runway? Is it level? Is it paved? |
#40
On Friday, August 23, 2019 at 9:30:29 AM UTC-7, son_of_flubber wrote:
On Thursday, August 22, 2019 at 11:50:40 AM UTC-4, 2G wrote: I only consume 1/2 gallon to launch my ASH31Mi motorglider to 3kft (the same was true for the 26e and DG400, and most every other self-launcher that I can think of, well maybe not the Space Shuttle). So, for a 4 hour flight my "burn rate" is 1 pint per hour. Self-launch gliders are obviously appealing, but I'm curious about their limitations wrt density altitude and turbulence. What is your climb rate in your typical density altitude? At 2000 ft DA it is 500 ft/min; at 9000+ DA it is 300 ft/min. Always seeking lift, so this is mixed. Do you ever launch in turbulent conditions with lots of sink? Not with lots of sink - try to launch when there is lift. What density altitude leads you to cancel your flight? None. What is the highest density altitude that you have launched in? 9600 ft. |
Perlan High Altitude Tow Plane | Frank Whiteley | Soaring | 32 | August 25th 18 01:32 PM |
Martin B-57 Canberra pics [19/20] - NASA High Altitude Plane.jpg (1/1) | Miloch | Aviation Photos | 0 | August 26th 16 12:34 AM |
High Altitude simulator accuracy in X-Plane | Ghazan Haider | Simulators | 2 | August 16th 05 06:01 PM |
Pressure Altitude or Density Altitude | john smith | Piloting | 3 | July 22nd 04 10:48 AM |
