My Stemme, finished in PU and 16 years old still has a perfect finish
except for chips and scratches.Â* I fly in wave quite often. On 1/29/2020 9:24 AM, wrote: On Wednesday, January 29, 2020 at 11:16:57 AM UTC-5, Eric wrote: Can anyone tell from experience how well a PU finish holds when flying in wave conditions, i.e. low temperatures & strong turbulence? I'm considering to repaint my glider, remove old gelcoat apply T35 as filler polyurethane on top. Can I go wave-flying again with peace of mind? To what extent is a PU finish vulnerable to cracking due to change in temperature? There's tons of information on the refinish topic, but I couldn't find the answer to this particular question. Thanks! T35 is polyester "gelcoat". That is the stuff that cracks. I would remove all "gelcoat", fill and surface with thin layer of polyester spray filler, then paint in UU/PU. Good luck UH -- Dan, 5J |
Single digits, say 5 deg F.
On 1/29/2020 10:46 AM, Eric Greenwell wrote: Dan Marotta wrote on 1/29/2020 9:28 AM: On 1/29/2020 9:24 AM, wrote: On Wednesday, January 29, 2020 at 11:16:57 AM UTC-5, Eric wrote: Can anyone tell from experience how well a PU finish holds when flying in wave conditions, i.e. low temperatures & strong turbulence? I'm considering to repaint my glider, remove old gelcoat apply T35 as filler polyurethane on top. Can I go wave-flying again with peace of mind? To what extent is a PU finish vulnerable to cracking due to change in temperature? There's tons of information on the refinish topic, but I couldn't find the answer to this particular question. Thanks! T35 is polyester "gelcoat". That is the stuff that cracks. I would remove all "gelcoat", fill and surface with thin layer of polyester spray filler, then paint in UU/PU. Good luck UH My Stemme, finished in PU and 16 years old still has a perfect finish except for chips and scratches.Â* I fly in wave quite often. It's not the wave flying that does it, of course, but the low temperatures. What OAT do you typically see while wave flying, and what is the lowest OAT you've seen while flying the Stemme? -- Dan, 5J |
| Thread Tools | |
| Display Modes | |
| AVE Mizar pics [8/9] - Flying Ford Finds Fateful Fiery Finish.jpg (1/1) | Miloch | Aviation Photos | 0 | December 25th 18 04:32 PM |
| Please send me logs, stories of flying in thermal wave over the plains | danlj | Soaring | 8 | November 16th 15 04:33 PM |
| Practical Wave Flying - Revised Edition | son_of_flubber | Soaring | 5 | October 29th 15 01:36 AM |
| Lake Placid, NY - Wave & Flying Encampment | Tim Hanke | Soaring | 0 | July 29th 14 07:45 PM |
| How well does linear polyurethane paint hold up to flying in wave and sunlight? | son_of_flubber | Soaring | 0 | October 1st 12 02:52 AM |
