Time for Separate 18m Records?
Old April 21st 20, 12:29 PM posted to rec.aviation.soaring
Roy B.
Default Time for Separate 18m Records?
Kristian:
I think that you are correct about the world records - but more pilots (who cannot afford to go to Namibia or Argentina) are interested in national records for their country - and in those countries the difference between 18m and 27m is important.
And on your last point, "I would actually like to acknowledge records made with pure glider. Now there is a difference" I agree completely. With a motor available, it is a different sport.
Best regards
ROY
Old April 21st 20, 03:19 PM posted to rec.aviation.soaring
krasw
On Tuesday, 21 April 2020 14:29:09 UTC+3, Roy B. wrote:
Kristian:
But you can do what ever you like with national records, you don't need FAI for that.
Old April 21st 20, 04:29 PM posted to rec.aviation.soaring
Bob Youngblood
On Tuesday, April 21, 2020 at 7:29:09 AM UTC-4, Roy B. wrote:
Kristian:
Best regards
ROY
With a motor available it is an entirely different approach to sticking your neck out on a limb. Many times I cross the state and late in the afternoon must combat a headwind and declining conditions. I get back home, close my triangle and sit down and have a cold brew! Have I ever not made it back home, YES. Not to knock the guys and gals with motorgliders, although I do poke a bit of fun at them over the radio. I will call on the radio and ask if any of you guys at Seminole are flying your motorgliders? They usually laugh and say yes, they do have a good sense of humor!
Old April 21st 20, 11:34 PM posted to rec.aviation.soaring
“13.5m is just historical burden of massively failed class that should have no record category or competition class”
Well thats a slap in the face to all us guys flying them! Stick you ass in one of these short wing birds and set a record before you condemn the whole class.
If guys are worried that state, national, and world records are no longer attainable without oudles of money or super ships look at the 13 meter record lists, there are many areas where a person of meager means can chase records specially at the state level..
Dan
Holder of 6 13n records
Old April 22nd 20, 07:05 PM posted to rec.aviation.soaring
Dan
Dan: you are making the assumption that 13.5m gliders are affordable. Some low-performance models are, but as the expensive, higher-performance ones become more common, it will be more difficult to set even state records in a low-performance glider. E.g., I was all hot to set 13.5m state records in my 12.6m Russia AC4, but then a fellow club member bought a Mini-LAK, with "full-size" 13.5m wings, flaps, ballast etc, which has (according to the official handicaps) a 25% performance advantage. So now I think I'll concentrate on Sports Class records.
In any case, the whole point (to me) is to challenge myself to go farther faster. In states where the official records (in some class) are sparse, trying for them is one way to do that. I fly in a small state. In larger states with more established records that is a much higher bar, simply given the history of other pilots' achievements. Witness the "reset the records" thread. So one is limited to other ways to measure ones' exploits against others, e.g., OLC.
Old April 22nd 20, 12:34 AM posted to rec.aviation.soaring
jfitch
Kristian:
Best regards
ROY
"With a motor available it is an entirely different approach to sticking your neck out on a limb." I find that pilots who believe this are nearly all ones who do not frequently (if ever) fly cross country in a motorglider, and are therefore speaking from ignorance. Sticking your neck out on a limb by depending on a motor is self limiting activity as even many time world champions have recently found out. It is a convenience, not a safety tool. As a convenience does it contribute to longer flights? It can, because the inconvenience of a retrieve is less of a consideration. So if you want your record attempts to be convenient and easy, either buy a motorglider or hire a full retrieve crew (the latter will cost you less).
I have asked this before without response: produce an example of a record owned by a motorglider that was achieved by flying too low over unlandable terrain. If you cannot, then you have no argument.
That should get this thread well hijacked! :-)
Old April 22nd 20, 12:41 AM posted to rec.aviation.soaring
Kristian:
Best regards
ROY
Not really. The most important thing is confidence. Having a motor improves confidence.
For the original question make all the records brand and model specific. Problem solved.
Old April 22nd 20, 01:46 AM posted to rec.aviation.soaring
Roy B.
Jfitch wrote:
"produce an example of a record owned by a motorglider that was achieved by flying too low over unlandable terrain. If you cannot, then you have no argument."
The reason for no response is that this is a false challenge. The issue is not safety nor flying over unlandable terrain. The availability of a motor is a risk management tool. It helps the pilot manage much more than just safety risks. It allows for management of land out risk, risk of adverse decision in crossing large overcast areas or potentially unworkable blue areas, risk of delay by flying into loss of convection, risk of overnight retrieves and other non dangerous risks. The pure glider pilot has only his or her wits to manage those risks and no other tool if they are wrong - and so they make more conservative decisions. But they are not "safer" decisions. That is why I say that availability of a motor makes it a different sport.
I concede that in good conditions close to home there is very little difference between having a motor and not. The difference arises when you are far from home and faced with a decision that might put you on the ground. The fellow with the motor has a tool that makes that decision much less consequential. This is why I believe that the records should be different categories.
ROY
Old April 22nd 20, 02:42 AM posted to rec.aviation.soaring
Anybody arguing for or against motorgliders as a "safety" solution or "risk management tool" when flying over ANY terrain except an actual airport with suitable runway access needs to see Dave Nadler's presentation at the 2020 SSA Convention on motorglider reliability REALITY.
https://www.youtube.com/watch?v=R--m0NDR0j8
Many thanks to Dave, one of the most experienced motorglider enthusiasts, but a realist above all.
Also, thanks for his eye-opening analysis of a catastrophic in-flight emergency that resulted in a dual bailout and crash in a remote area. The video explaining his experience and its aftermath should be required viewing for all aspiring (and current) cross-country pilots. It definitely reorganized my thinking!
https://www.youtube.com/watch?v=v8I3A3dqsu0
Old April 22nd 20, 05:00 PM posted to rec.aviation.soaring
jfitch
ROY
"The issue is not safety nor flying over unlandable terrain. The availability of a motor is a risk management tool." Your premise then is that a motorglider makes record attempts more convenient and therefore easier. There is no doubt about this. However there are MANY things that make record attempts more convenient and easier: the availability of a full time crew, higher performance gliders (even in the same class), the proximity of good soaring terrain to your home, independent wealth, etc. A motor is not the only - or even foremost - difference. So if you want the granularity of motors introduced to records, then several other differentiators should come at the same time, or even first. No one would suggest that it is easier to set a 15m record in a PIK20E vs. a JS-3 because it has a motor.
I've no problem with increasing the granularity of records. The motivation for records is vanity (I say that without judgement - do what turns your prop), and so increasing the opportunity to indulge is overall to the good. There is no need for them to be a zero sum game. Picking out motors as an exception among many variations seems arbitrary. My preference would be to have a "claiming record" such as is done in auto and horse racing. You claim a record, say in the $20,000 class. If your record is recognized anyone may purchase that glider from you for $20,000. This would quickly sort out motors or not, new gliders vs. old, and even expensive avionics. Most pilots would hesitate to enter their JS-3 or AS-33 in the $20K class against the PIK20E, knowing anyone could buy their glider for $20K if the record was granted.
Implausible Time Records Dan Marotta Soaring 82 June 1st 19 02:39 AM
Two Vintage Warbirds Crashed In Separate Incidents On Eve Of Oshkosh Air Show (Updated) Miloch Aviation Photos 0 July 22nd 18 03:29 PM
All US Records are Now Motor Glider Records Tango Eight Soaring 99 March 23rd 17 12:07 PM
Does SeeYou have a separate Validation DLL? Papa3 Soaring 11 October 20th 08 08:10 AM
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap tim liverance Military Aviation 0 August 18th 03 12:18 AM
Copyright 2004-2025 AviationBanter.
