I've had a questions I'd like to foist upon the collective knowledge
here... I have a few of those "World's Worst Airplane" books and enjoy reading about the creations of those in the old days who were basically working by the seat of their pants. I've noticed that their were many planes during the prop-to-jet transition years from about 45 to about 55 that used counter rotating propellers. I'm wondering what the perceived advantage was? Seems to me that the added complexity and cost would be a disadvantage. It's pretty simple with one propeller: Take engine. Fasten propeller to flange on front. Put on airplane, Fly into the wild blue yonder, All those gears and driveline parts were mighty complex and, in my reading, the added complexity was usually the thing that put the plane into the 'world's worst' catagory. I notice that notable post war military aircraft such as the B-36 and the C-130 (plus more) used one propeller per shaft. If there were an advantage, you'd think you'd find 'em on a military plane. Yet, if my reading is correct, the Soviet long-range Bear bomber had counterrotating propellers. So, that leaves me again with my initial question: What advantages were being sought through the counter rotating propeller and, if there were indeed advantages, why aren't they seen on production propeller driven aircraft today? raoul |
Raoul wrote: I've had a questions I'd like to foist upon the collective knowledge here... I've noticed that their were many planes during the prop-to-jet transition years from about 45 to about 55 that used counter rotating propellers. I'm wondering what the perceived advantage was? Several: Main one was that the torque effects cancelled out, so that the aeroplane wasn't always trying to turn itself over/around in flight, which was getting to be a real pain even with the last generation of WW fighters, let alone the more powerful ones coming along. I've spoken to at least one pilot who flew Seafires (the carrier-based Spitfire derivative) and he was lavish in his praise of the F.47 which used contraprops - "it flew like a jet" - less so of the earlier Griffon-engined types. And the Seafires "only" had 2200hp or so - imagine what the torque effects would have been in something like the Westland Wyvern (3600hp) without contraprops (and it was no delight with 'em). A related issue was maintainance (this for multi-engine types): if you wanted to avoid torque effects you had to have "handed" engines, turning in different directions on each side (like the Lockheed Lightning or the De Havilland Hornet), or you put up with the torque effects and had the mainatainance/suppy gain of n identical engines. Go to contraprops (as on the Avro Shackleton) and you had four identical engines and the torques cancelling out. Another issue was ground clearance - by the generation of fighters which included the Corsair and its peers it was getting /very/ difficult to put a big enough prop on the front to handle the power. Contraprops cut down the size of the prop disc and made for easier takeoffs and landings (the undercarriage didn't need to be so nose-up). Seems to me that the added complexity and cost would be a disadvantage. It's pretty simple with one propeller: Take engine. Fasten propeller to flange on front. Put on airplane, Fly into the wild blue yonder, All those gears and driveline parts were mighty complex and, in my reading, the added complexity was usually the thing that put the plane into the 'world's worst' catagory. Except that (almost - the Harvard is the exception I can think of) pretty well all aeroplanes already used geared engines (and had since rotaries went out of fashion in 1918 or so) - so you already had the gearbox there. Another issue is that it makes it easier to combine more than one engine on one shaft (the fewer shafts the better for aerodynamics, but you might not want a single enormous engine turning over for cruise, say). The Fairey Gannet did this - two turboprops driving a contraprop. For takeoff or speed you ran both engines, for stooging around (the Gannet did ASW and AEW) you ran on one engine. I notice that notable post war military aircraft such as the B-36 and the C-130 (plus more) used one propeller per shaft. If there were an advantage, you'd think you'd find 'em on a military plane. Yet, if my reading is correct, the Soviet long-range Bear bomber had counterrotating propellers. Chack out the engine powers! The turboprops on the Bear are /big/ - 14000+shp, IIRC. There's no way you could fit in propellors big enough to take that power and have an aeroplane which could be handled on the ground - even with the contraprops the airliner derivative (Tu114) wouldn't fit into normal airport gates.. What advantages were being sought through the counter rotating propeller and, if there were indeed advantages, why aren't they seen on production propeller driven aircraft today? Not sure whether the Antonev 70 is actually in production yet, but it uses four big contraprops.. -- Andy Breen ~ Interplanetary Scintillation Research Group http://users.aber.ac.uk/azb/ "Time has stopped, says the Black Lion clock and eternity has begun" (Dylan Thomas) |
On 18 Sep 2004 16:05:44 +0100, ANDREW ROBERT BREEN wrote:
A related issue was maintainance (this for multi-engine types): if you wanted to avoid torque effects you had to have "handed" engines, turning in different directions on each side (like the Lockheed Lightning or the De Havilland Hornet), or you put up with the torque effects and had the mainatainance/suppy gain of n identical engines. Couldn't you use identical engines, but mount them back-to-front on one wing? -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia (Email: zen19725 at zen dot co dot uk) |
Raoul wrote in message ...
What advantages were being sought through the counter rotating propeller and, if there were indeed advantages, why aren't they seen on production propeller driven aircraft today? One object of the exercise, I think, was to straighten the airflow to get more trust from the same power. The idea is that the energy that goes into making the air go 'round and 'round is wasted and if the air can be pushed straight through the propulsion device then it will be more efficient. Two problems with counter rotating propellers a 1) The airflow into the second propellor is turbulant which impairs the efficiency of the second propeller. and 2) The counter-rotating propellers put energy into spinning the air and then put more energy into 'despinning' the air. No energy is regained by straightening the flow. IIRC ducted fanjets do spin the outerflow counter to the inner flow through the turbine. I don't think that improves the efficiency, rather it reduces the net torque on the aircraft. There have been successful designs that used seperate engines to spin a fore and aft propeller, the DO-335, the Cessna-337 and it's military equivalent that you seen in the movie _Bat 21_, I forget the designation, O-something. These use counterrotating engines so that there is no net torque on the fuselage, which improves handling rather than efficiency. There is an additional advantage in that putting two engines inline allows the use of the power of another engines without the additional drag of another nacelle. I think Rutan has a GA aircraft with a similar configuration to the DO-335. -- FF |
Well, counter rotating props eliminate torque on twin engined
airplanes & on at least some, improves the single engine performance & handling. However, your question really seems to be about contra-rotating props, which is the case of a single engine driving 2 props on a co-axial shaft, rotating opposite of each other. Same thing, it eliminates the torque & therefore makes the airplane more docile. Contra-rotating props are same shaft, same engine, like a late Seafire or Shack or Bear. Counter-rotating are separate engines, like the P-38 or F-82 or several twin engine Pipers. Raoul wrote in message ... I've had a questions I'd like to foist upon the collective knowledge here... I have a few of those "World's Worst Airplane" books and enjoy reading about the creations of those in the old days who were basically working by the seat of their pants. I've noticed that their were many planes during the prop-to-jet transition years from about 45 to about 55 that used counter rotating propellers. I'm wondering what the perceived advantage was? Seems to me that the added complexity and cost would be a disadvantage. It's pretty simple with one propeller: Take engine. Fasten propeller to flange on front. Put on airplane, Fly into the wild blue yonder, All those gears and driveline parts were mighty complex and, in my reading, the added complexity was usually the thing that put the plane into the 'world's worst' catagory. I notice that notable post war military aircraft such as the B-36 and the C-130 (plus more) used one propeller per shaft. If there were an advantage, you'd think you'd find 'em on a military plane. Yet, if my reading is correct, the Soviet long-range Bear bomber had counterrotating propellers. So, that leaves me again with my initial question: What advantages were being sought through the counter rotating propeller and, if there were indeed advantages, why aren't they seen on production propeller driven aircraft today? raoul |
Andy,
ANDREW ROBERT BREEN wrote: In article , Raoul wrote: I've had a questions I'd like to foist upon the collective knowledge here... I've noticed that their were many planes during the prop-to-jet transition years from about 45 to about 55 that used counter rotating propellers. I'm wondering what the perceived advantage was? Great reply................. Major snip................... Not sure whether the Antonev 70 is actually in production yet, but it uses four big contraprops.. IIRC, the An-70 is not a contraprop as such - the D-27 engine is a twin-spool propfan - and the props are driven by the two shafts, not through a 'normal' contraprop gearbox. It has 8 blades in the front row and 6 in the rear - 14 blades per engine - making a staggering total of 56 blades !!! It is extremely fuel efficient......... Ken |
![]() "Ken Duffey" wrote in message ... Andy, ANDREW ROBERT BREEN wrote: In article , Raoul wrote: I've had a questions I'd like to foist upon the collective knowledge here... I've noticed that their were many planes during the prop-to-jet transition years from about 45 to about 55 that used counter rotating propellers. I'm wondering what the perceived advantage was? Great reply................. Major snip................... Not sure whether the Antonev 70 is actually in production yet, but it uses four big contraprops.. IIRC, the An-70 is not a contraprop as such - the D-27 engine is a twin-spool propfan - and the props are driven by the two shafts, not through a 'normal' contraprop gearbox. It has 8 blades in the front row and 6 in the rear - 14 blades per engine - making a staggering total of 56 blades !!! It is extremely fuel efficient......... Wait a sec. If this was such an extremely fuel efficient system, the short-haul airlines would be banging down the various manufacturers' dorrs demanding such systems--which they decidedly ain't doing. The prop fan configuration was tested here in the US a few years back (on a DC-9 airframe, IIRC), and it apparently was found wanting (how much of a problem in that regard the noise issue is I don't know). The An-70 has had a rather troubled development history (so much so that the Russians have gotten rather cold to it), and IIRC one of the major problems has been the powerplant. Brooks Ken |
Raoul wrote:
What advantages were being sought through the counter rotating propeller and, if there were indeed advantages, why aren't they seen on production propeller driven aircraft today? Contraprops allow large amounts of shaft-horsepower to be turned into thrust without making a single-engined aircraft unhandlable through torque effects. At takeoff, full throttle can be applied with no unbalanced effect on the aircraft. The extra number of blades also allows the diameter to be reduced, helping to keep the ends off the ground and tip speeds lower. They aren't seen today because nobody is trying to put that much power through propellors. Peter Stickney gave me some very good answers to a similar question a little while ago. Here is an extract from our conversation: ------------------------ Peter Stickney wrote: In article , Alan Dicey writes: Peter Stickney wrote: iii) How does this work with contraprops? On the face of it they must interfere with each other horribly, but they seem to fly quite well. What you gain is a greater ability for a propeller of a particular diameter to absorb power, adn the elimination of torque and P-factor (destabilization of the airframe due to the rotating airflow from the propeller affecting the airframe). So, for an increase in power turned into thrust there's an improvement in flyability and the ability to make the airframe lighter because it doesn't have to absorb the stresses - they're balanced out at the source. That explains to me how the Fairey Gannet was able to shut off one half of the Double Mamba powerplant, feather one half of the contraprop and achieve better endurance at patrol speed. Right. Another example would be the Griffon engined Seafires. With a single rotation prop, the Griffon Seafires had 5-bladed single rotation propellers, and were limited to roughly 66% power on takeoff. This was because of 2 reasons - the Torque/P-Factor would drag the airplane right into the carrier's island. (A bad idea), and trying to hold it straight was overstressing the tire sidewalls, forcing tire changes after only a couple of flights. It's tough when you've got to explain that you need to pull your ship out of the battle because you ran out of tires, rather than gas, bullets, or bombs. The contraprop used on the later Seafire 47s (6 blades, 3 per bank) allowed more power to be used without the swing, and better propeller clearance. The same basic engine allowed the development of the Avro Lincoln into the Shackleton - you could hang Griffons with contraprops in the same wing center section without changing the location of the engine mounts. That's basically a Lancaster wing, so they got a lot of stretch out of it. |
Raoul writes: I've had a questions I'd like to foist upon the collective knowledge here... I have a few of those "World's Worst Airplane" books and enjoy reading about the creations of those in the old days who were basically working by the seat of their pants. I've noticed that their were many planes during the prop-to-jet transition years from about 45 to about 55 that used counter rotating propellers. I'm wondering what the perceived advantage was? Seems to me that the added complexity and cost would be a disadvantage. It's pretty simple with one propeller: Take engine. Fasten propeller to flange on front. Put on airplane, Fly into the wild blue yonder, All those gears and driveline parts were mighty complex and, in my reading, the added complexity was usually the thing that put the plane into the 'world's worst' catagory. I notice that notable post war military aircraft such as the B-36 and the C-130 (plus more) used one propeller per shaft. If there were an advantage, you'd think you'd find 'em on a military plane. Yet, if my reading is correct, the Soviet long-range Bear bomber had counterrotating propellers. So, that leaves me again with my initial question: What advantages were being sought through the counter rotating propeller and, if there were indeed advantages, why aren't they seen on production propeller driven aircraft today? Other folks have been covering aspects of this well, so I'll leave out the long treatise. There's one things that is being messed. Since a contraprop allows more power to be absorbed by a smaller siameter propeller, the tip speed of the propeller is lower. This is important, since teh efficiency of the propeller drops sharply as teh flow over the propeller goes transonic and supersonic. Since the propeller tip speed is the vector sum of teh propeller's rotational speed adn its forward airspeed, it allows better overall efficiency at higher speeds. The Tu-95 uses this in two ways. Not only does the contraprop cut down on the propeller diameter, but the props are geared to turn at about 760 RPM. This allows that big meatgrinder to churn along at Mach 0.85. (Which allows it to outpace a Tornado in dry (No reheat) thrust.) -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
![]() "phil hunt" wrote in message .. . On 18 Sep 2004 16:05:44 +0100, ANDREW ROBERT BREEN wrote: A related issue was maintainance (this for multi-engine types): if you wanted to avoid torque effects you had to have "handed" engines, turning in different directions on each side (like the Lockheed Lightning or the De Havilland Hornet), or you put up with the torque effects and had the mainatainance/suppy gain of n identical engines. Couldn't you use identical engines, but mount them back-to-front on one wing? There's not many engines you could do that with considering the fittings for the accessory drives and power connections tend to make the ends different. Then there are the stress loads, were WWII aircraft engines structural? I'm sure you could design an engine you *could* do it with but it's most likely going to be a good bit heavier. |
Aero Composites Propellers | Badwater Bill | Home Built | 26 | June 18th 04 05:30 AM |
FS Performance Propellers 60 x 66 | Sammy | Home Built | 0 | December 19th 03 01:51 AM |
Performance Propellers 60 x 66 | Sam Hoskins | Home Built | 0 | December 10th 03 01:03 AM |
Wooden Propellers | Dick Petersen | Home Built | 5 | November 13th 03 12:41 AM |
