Adhesive for wing bumper pads
Old July 4th 20, 08:52 PM posted to rec.aviation.soaring
william geiger
Default Adhesive for wing bumper pads
I need to reattach one. What adhesive would work? I think I put this one on with rubber cement and got 10 plus years service but was wondering if there is a better solution for getting the flat surface of the rubber bumper to adhere to the curved wing surface.
Old July 4th 20, 11:25 PM posted to rec.aviation.soaring
AS
Hi Bill,
sand the old gunk off of both surfaces, clean them thoroughly with denatured alcohol and then use contact cement according to the mfg instructions. That stuff works best for that application.
If you ever have an undue side-load, you want these things to come off clean rather than break the glass or gelcoat. The tail-skid of the early Std.-Astir was attached to the tail boom the same way for the same reason.
Uli
'AS'
Old July 4th 20, 11:39 PM posted to rec.aviation.soaring
I've been quite happy usiing 3M VHB tape on mine.
Robert
Old July 5th 20, 12:08 AM posted to rec.aviation.soaring
william geiger
Thank you gentlemen.
Best adhesive remover/cleaner for wing tape Eric Greenwell[_4_] Soaring 19 October 16th 14 01:45 AM
APH5 Helment Pads CF[_2_] Piloting 0 July 5th 11 10:49 PM
Crash Pads Paul Tomblin Piloting 7 April 4th 08 01:25 AM
crash pads [email protected] Piloting 1 March 14th 06 02:10 AM
Piper Rudder Pedal Pads Mike Spera Owning 1 November 4th 05 04:31 AM
