....as production on troubled aircraft grinds to a halt
more at https://www.dailymail.co.uk/news/art...-supplier.html Boeing suppliers are bracing for a halt in production of the 737-MAX that will start in January Grounding of the planemaker's fast-selling aircraft will likely result in lost revenues for hundreds of suppliers Boeing has continued to purchase parts from some suppliers at a production rate higher than its own, in order to keep the supply chain fluid and avoid major disruptions when the MAX returns to service But photos show there are dozens of 737-MAX fuselages sitting outside a factory in Wichita, Kansas Spirit AeroSystems receives nearly 80% of revenue from Boeing as it makes the fuselage, pylons, thrust reverser, wing leading edges and engine nacelles Spirit has continued to churn out parts for the jet at a rate of up to 52 units per month, even as Boeing cut its own production to 42 per month - and at least 90 fuselages are now sitting on the concrete waiting to go The suspension of MAX production will pressure suppliers that are relying on the demand from Boeing If parts supply companies stop production, it will be difficult for them to quickly restart their factories, and that could further delay any startup of Boeing´s assembly lines The Max was grounded worldwide in March after the second of two deadly crashes in Indonesia and Ethiopia that killed a total of 346 people Workers at Boeing's biggest supplier for the building of its 737-MAX plane are fearing for their jobs in the week before Christmas after the aircraft manufacturer announced its decision to suspend construction of the aircraft. Layoffs at Spirit AeroSystems Holdings Inc. in Wichita, Kansas seem almost certain, particularly if Boeing stops paying Spirit to build and store fuselages at current rates. Evidence of the slowdown in construction is plain for all to see with at least 90 fuselages simply sitting on the concrete, under wraps, with nowhere to go until a decision can be made to ramp up production once again, perhaps some time in 2020. With overwhelming demand for the 737-MAX plane, Spirit AeroSystems Holdings planned to staff its factory with enough workers to maintain a build rate of 52 aircraft per month with plans to eventually increase to 57 aircraft - but that was before the current nine-month crisis hit. But Boeing's decision to suspend their 737MAX production will lead to a knock-on effect to hundreds of suppliers that come together to help build the plane. The Max was grounded worldwide in March after the second of two deadly crashes in Indonesia and Ethiopia that killed a total of 346 people. For months, Boeing used the parts to build about 400 Max planes that it could not deliver to airlines. Boeing does not currently plan to lay off any of the 12,000 workers at its factory in Renton, Washington. But smaller parts companies like Wichita-based Spirit AeroSystems might not have that luxury. They could be forced to cut employees, and some might even get pushed out of business. With 13,500 workers, Spirit is the largest employer in Kansas´ biggest city. more at https://www.dailymail.co.uk/news/art...-supplier.html * |
| Thread Tools | |
| Display Modes | |
