rasp forecast almost nil convection, 15-20knts ENE at Kenley we had
streets giving straight line lift of 4-6 m/s almost all day, cruising east to Biggin Hills's ATZ to watch the biz jets fly there landing circuit then back down wind to M25 J7 at 80 and 90 knts in a Grob 103!!! Why did rasdp have it so wrong??? |
Why are they flying LY registered aircraft in Slovenia?
On Friday, 25 September 2020 at 16:46:13 UTC+3, Pat Russell wrote:
Why are they flying LY registered aircraft in Slovenia? Did you read the video description? |
On 9/25/20 2:01 AM, Paul T wrote:
https://youtu.be/vcPCLPyXOYE Notice how much the tail is bouncing even on a golf course quality grass runway? One good bounce and goodbye prop and motor. |
I have an LX 5000, which I want to interface with a Red Box Flarm.
The LX has four ports (five including the vario display connection) labelled: 1. Power (wired to battery main switch) 2. Hold (wired to flip switch. No idea what it does!) 3. DataComm (a previous owner had "hot wired" two of its leads into a Garmin LX12 cable. No Garmin now fitted) 4. Meter ( RJ 12 6 pin phone type port. Not connected.) The LX presumably has a built in GPS, but needs an aerial. The LX is not finding a GPS fix, as there is no aerial. I assume the Garmin had been used to give the LX data via the DataComm hot wires. Now, with no Garmin, I assume the Flarm GPS aerial could do the job. Question, how to wire it all up. Must be simple for anyone other than an electronic imbecile like myself. |
Why are so many topics getting threaded under "Another E glider
concept"? Happens both on my newsreader, as well as when just viewing R.A.S. on Google. On 10/9/20 8:44 AM, Adrian Morgan wrote: I have an LX 5000, which I want to interface with a Red Box Flarm. The LX has four ports (five including the vario display connection) labelled: 1. Power (wired to battery main switch) 2. Hold (wired to flip switch. No idea what it does!) 3. DataComm (a previous owner had "hot wired" two of its leads into a Garmin LX12 cable. No Garmin now fitted) 4. Meter ( RJ 12 6 pin phone type port. Not connected.) The LX presumably has a built in GPS, but needs an aerial. The LX is not finding a GPS fix, as there is no aerial. I assume the Garmin had been used to give the LX data via the DataComm hot wires. Now, with no Garmin, I assume the Flarm GPS aerial could do the job. Question, how to wire it all up. Must be simple for anyone other than an electronic imbecile like myself. |
On Friday, October 9, 2020 at 7:55:04 AM UTC-7, kinsell wrote:
Why are so many topics getting threaded under "Another E glider concept"? Happens both on my newsreader, as well as when just viewing R.A.S. on Google. On 10/9/20 8:44 AM, Adrian Morgan wrote: I have an LX 5000, which I want to interface with a Red Box Flarm. The LX has four ports (five including the vario display connection) labelled: 1. Power (wired to battery main switch) 2. Hold (wired to flip switch. No idea what it does!) 3. DataComm (a previous owner had "hot wired" two of its leads into a Garmin LX12 cable. No Garmin now fitted) 4. Meter ( RJ 12 6 pin phone type port. Not connected.) The LX presumably has a built in GPS, but needs an aerial. The LX is not finding a GPS fix, as there is no aerial. I assume the Garmin had been used to give the LX data via the DataComm hot wires. Now, with no Garmin, I assume the Flarm GPS aerial could do the job. Question, how to wire it all up. Must be simple for anyone other than an electronic imbecile like myself. here's another ![]() https://www.desertaerospace.com/extreme-light-jet--xlj- |
here's another
![]() https://www.desertaerospace.com/extreme-light-jet--xlj- That was an early concept for a personal jet airplane modelled on a glider type fuselage with a wing designed for the flight characteristics envisioned. It was to use a PBS TJ-100 engine like the one Bob was using on his airshow Salto glider (www.vertigoairshows.com) and the two-seat retractable engine TsT-14 BonusJet glider (as well as the four jet powered Arcuses built by Desert Aerospace.) The design was superseded by the jet powered SubSonex from Sonex Aircraft. About a dozen or more are flying today, with probably 20 more kits in progress. https://en.wikipedia.org/wiki/Sonex_Aircraft_SubSonex The XLJ (Extreme Light Jet) concept may be revisited in the future by Desert Aerospace if time permits. |
On Friday, October 9, 2020 at 10:40:20 AM UTC-7, B BRIONES wrote:
On Friday, October 9, 2020 at 7:55:04 AM UTC-7, kinsell wrote: Why are so many topics getting threaded under "Another E glider concept"? Happens both on my newsreader, as well as when just viewing R.A.S. on Google. On 10/9/20 8:44 AM, Adrian Morgan wrote: I have an LX 5000, which I want to interface with a Red Box Flarm. The LX has four ports (five including the vario display connection) labelled: 1. Power (wired to battery main switch) 2. Hold (wired to flip switch. No idea what it does!) 3. DataComm (a previous owner had "hot wired" two of its leads into a Garmin LX12 cable. No Garmin now fitted) 4. Meter ( RJ 12 6 pin phone type port. Not connected.) The LX presumably has a built in GPS, but needs an aerial. The LX is not finding a GPS fix, as there is no aerial. I assume the Garmin had been used to give the LX data via the DataComm hot wires. Now, with no Garmin, I assume the Flarm GPS aerial could do the job. Question, how to wire it all up. Must be simple for anyone other than an electronic imbecile like myself. here's another ![]() https://www.desertaerospace.com/extreme-light-jet--xlj- That doesn't even rise to the level of a concept - more like wishful thinking. Tom |
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [4/5] - "Eclipse Concept Jet 4.jpg" yEnc (1/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | July 31st 07 04:02 PM |
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [3/5] - "Eclipse Concept Jet 3.jpg" yEnc (1/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | July 31st 07 04:02 PM |
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [2/5] - "Eclipse Concept Jet 2.jpg" yEnc (1/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | July 31st 07 04:02 PM |
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [1/5] - "Eclipse Concept Jet 1.jpg" yEnc (0/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | July 31st 07 04:02 PM |
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [1/5] - "Eclipse Concept Jet 1.jpg" yEnc (1/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | July 31st 07 04:02 PM |
