Wildcat on the Ronald Reagan
Old September 18th 03, 03:11 PM
Andrew Toppan
On Thu, 18 Sep 2003 01:35:32 -0400, "Charles Talleyrand"
the catapult cannot be dialed down low enough for the light weight
plane, or the connection between them has changed shape
and size.
Many WWII carriers did not have catapults, and the planes operated just fine
without them. What makes you think a catapult is necessary now?
Andrew Toppan --- --- "I speak only for myself"
"Haze Gray & Underway" - Naval History, DANFS, World Navies Today,
Photo Features, Military FAQs, and more -
http://www.hazegray.org/
Old September 21st 03, 05:17 AM
Elmshoot
In the Prowler flight simulator we used to do a deck run after a trap. We would
just taxi back to the round down and spin around and cob the power. It was
really not to difficult I would think that any moderen Jet aircraft F-14,
F/a-18, EA-6B, S-3, E-2 could do a deck run the full length of the deck and get
airborne at max landing weight. If you cranked up the wind you might make it at
max T/O weight as well but I'm not sure about that.
Sparky
Old September 17th 03, 01:46 PM
Ogden Johnson III
"Charles Talleyrand" wrote:
Suppose someone tried to land an F4F Wildcat on a modern American
aircraft carrier. We'll give the carrier a few hours to prepare, and lets assume
the carrier is at sea and moving.
Can a WWII fighter land on a modern carrier? Can it get back in the air?
As others have pointed out, certainly. If a C-130 can do it, albeit
gingerly, an F4F certainly could.
_Safely_ landing would be the question. The pilot would have to be
conversant with the present optical systems, and some LSOs would have
to be trained for the F4F's [or other WWII aircraft you're
postulating] characteristics and landing profiles. My only question
would be can modern arresting gear be set to handle the, generally,
much lower weights of WWII carrier aircraft compared to those
operating today? [e.g., F4F ~7,500 lbs, A4M ~25,000 lbs]
OJ III
Old September 17th 03, 02:47 PM
Pechs1
OJ- My only question
operating today? [e.g., F4F ~7,500 lbs, A4M ~25,000 lbs] BRBR
I would guess they would pull the wires and let the A/C just land.. CV with 35
knots on, plus any natural wind, F4F would be closing at about what, 50 knots
or so-easy to stop.
P. C. Chisholm
CDR, USN(ret.)
Old Phart Phormer Phantom, Turkey, Viper, Scooter and Combat Buckeye Phlyer
Old September 22nd 03, 04:37 PM
Joop Schaeffer
"Pechs1" schreef in bericht
with 35
knots
or so-easy to stop.
Wildcat:
airplane characteristics & performance burea of aeronautics-navy dept.:
take-off distance -15 kn 410 ft
take-off distance -25 kn 278 ft
http://www.history.navy.mil/branches/hist-ac/f4f-4.pdf
Old September 17th 03, 02:33 PM
Red
"Ogden Johnson III" wrote in message
lets assume
OJ III
I don't think you would need arresting gear. Getting forty knots + of wind
across the deck would be no problem. You might have a little truouble
holding the F4F onto the deck. Between the high drag and low speed of the
F4F its brakes shouldn't have any problem stopping.
Speaking of the high drag,
If the F4F is "dirty", gear, flaps, etc.down, with 20 knots headwind and the
CVN making 40 knots, can the F4F catch it? What was the landing speed on an
F4F. What about the take-off speed. Can the F4F fly off the bow, or will it
be like a chopper, and have to go off to the side. (There is a reason that
most of the time a chopper lands and takes off from the stern of a ship). I
can see it now, the F4F takes off, climbs to 250 feet, the CVN sails out
from under it, the CVN slows down, and the F4F catches up and lands. I can
see it now, ROTFLMAO.
Old September 17th 03, 02:43 PM
Andrew Toppan
On Tue, 16 Sep 2003 23:58:10 -0400, "Charles Talleyrand"
Umm...if it can land and take off from a smaller, WWII-era carrier, why
couldn't it land and take off from a *larger* modern carrier?
Old September 17th 03, 02:45 PM
Pechs1
Charles- Suppose someone tried to land an F4F Wildcat on a modern American
assume
the carrier is at sea and moving. BRBR
BRBR
Pull the rods and get about 35 knots and let the A/C use the whole deck, yes to
both is what I think.
P. C. Chisholm
CDR, USN(ret.)
Old September 17th 03, 05:10 PM
Charlie Wolf
What would the landing weight (no ordnance) of an A-1 Skyraider be?
The ones they used on supercarriers in Tonkin Gulf. I'm assuming the
situation would be comparable.
Regards,
-Much Thanks
-CMTalleyrand
Old September 18th 03, 04:11 AM
Walt BJ
Considering that a Wildcat had a tail hook, why not? As for the
optical system, it'd take about a 5 minute chalk talk to show a WW2
pilot how it worked and what to do. We USAF drivers didn't get any
briefing at all and we used to use the field optical landing system at
Navy Key West, absolute proof that anyone with half a brain can do it,
right? (G)
General Zinni on Sixty Minutes WalterM140 Military Aviation 428 July 1st 04 11:16 PM
What if Reagan was tried for war crimes ? B2431 Military Aviation 8 June 14th 04 09:48 PM
missing man formation for Reagan Paul Hirose Military Aviation 1 June 14th 04 12:50 AM
~ I WISH RONALD REAGAN WAS STILL ALIVE ~ ArtKramr Military Aviation 1 June 9th 04 12:49 AM
Wildcat crash in Houston Wright1902Glider Home Built 3 October 27th 03 09:24 PM
