First glider Nimbus 2 ?
Old January 6th 21, 06:37 AM posted to rec.aviation.soaring
Default First glider Nimbus 2 ?
On Wednesday, January 6, 2021 at 11:56:48 AM UTC+13, kenward1000 wrote:
On Monday, January 4, 2021 at 11:34:50 PM UTC-8, Surge wrote:
I chose the Nimbus 2 for various reasons:
1. There was nothing available with a 40+:1 L/D within my budget. ASW20's were selling for 3 to 4 times the price and club single seaters were not always available and often had a waiting queue which meant long cross country flights on nice days were not possible.
2. I wanted to have 100% ownership in a glider which I know no one else has broken, mis-rigged, etc. without my knowledge. I saw club gliders being abused or landed hard and then hangared for the next person to fly so safety became a motivating factor.
Bingo. I'd been flying a club Pegasus 101A for 7 years. Nobody in the club took care of the ship like it deserved. Had a scary flight because previous pilot, post flight, used white electrical tape on the upper aileron gaps, instead of real tape. On tow, had zero roll control as the tape detached, fluttering in the middle but not on the ends, blanketing the ailerons in turbulent airflow. Wanted something better but only had Pegasus money. Bought my LAK-12 for $26K and believed it to be the best bang for the buck, especially now as they're only bringing $15K. Roomy cockpit.
If you have belly dolly and a remote controlled power rigger a Nimbus 2 is a breeze to rig, I can rig my ship in my backyard (not smooth ground) on my own, the hardest part is the last 10mm as the metal fittings are very tight tolerances, takes about an hour, a tail dolly fitting that makes the glider like a trailer sorts most handling issues on the airfield .
I know someone who had a kestrel 19m who was often near last to derig who fitted a remote controlled boat winch to haul the major sections into his trailer .
With a little thought and basic engineering most issues can be sorted.
Gary
Old January 6th 21, 08:38 AM posted to rec.aviation.soaring
Andreas Maurer[_2_]
On Mon, 4 Jan 2021 23:34:48 -0800 (PST), Surge
Have you actually flown a Nimbus 2? I suggest you organise a test flight before making the purchase. Maybe you can organise a dual in something with an all flying elevator like a Janus first.
I would never lend my Numbus 2 to a pilot with so few hours. Never.
Old January 6th 21, 10:38 PM posted to rec.aviation.soaring
Piotr Mis
Å›roda, 6 stycznia 2021 oÂ*08:39:02 UTC+1 Andreas Maurer napisaÅ‚(a):
ok, so I understand that you consider a flight in Nimbus executed by a 70 hours pilot would be very dangerous to a both glider and pilot. But what exactly are the factors of that danger? is it just "no, because no" type of argumentation or do you mean any particular elements of flying technique / tactics which are neccessary to execute a short, safe flight in good conditions within a gliding range of the airfield, and which a-70-hour pilot cannot possibly have?
Old January 7th 21, 12:19 AM posted to rec.aviation.soaring
Dne stÅ™eda 6. ledna 2021Â*vÂ*22:38:36 UTC+1 uživatel napsal:
Hi,
Im in similar position as you (150H PIC in GLD and TMG) and Im starting scanning market for first glider too. Im not flying Nimbus2 so Im not able to camment in flight characteristics, but Nimbus 2b was bought by another club-member (after about 2- 3years flying XC in low performance gliders) so there are some notes only from ground. Long wings are quite low so you have to watch it, which is challenging when flying in cross-winds and ground runs at takeoff and landings are looong, because this thing is simply heavy. Some folks above sad it can be landed short but you have to be on exactly right speed, OK for airport with stable or no wind and free space before touchdown zone, in not known place and some croswind I woud like to keep some more speed probably, ant then ground run can be quite long. So this combination is for safe outlanding for me big NO, and from my experince in air (sinks can be prety strong) when Im not sure than I can land plane in field I don't leave airport from my sight, so there is no need to have big L/D because you can fly in same are with L13. About flaps I dont right to say nothing because I dont fly plane with them, but I fly TMG and I know that every one lever or button you have to push, need your attention especially when you are learning new plane. And when things are not optimal there is not a small chance you forget something. This is up to you if you thing that in glider that you flying you are enough relaxed so you are able to keep up with more workload.
Old January 10th 21, 12:19 AM posted to rec.aviation.soaring
Piotr Mis
czwartek, 7 stycznia 2021 oÂ*00:19:50 UTC+1 napisaÅ‚(a):
Dne středa 6. ledna 2021 v 22:38:36 UTC+1 uživatel napsal:
Hi,
Thank you very much for a comment, I am glad to get some input from someone who is facing a similar type of dilemma
Your remarks seem to confirm most of the warnings that I get. For some reason, though, I believe that paradoxicaly, flying a glider which sort of "outsizes" my skills may increase rather than decrease the safety. Why? I experienced a similar thing when I began to ride a motorbike. I bought one which was too strong, too fast, too dangerous for me in opinions of many people.. Knowing that, I drove it very very carefully for the first two years, and here I am, still riding it and enjoying a lot. If you get something which is said to be easy to fly, then you start off with a mindset of flying an easy glider. Are there really "easy" gliders? the ones in which you can make a 55% bank turn before a final at 60km/h speed at 30m AGL?
I am no expert but I guess even the "safest" glider would kill you. Of course you would say that no experienced pilot would ever do it, but interestingly, even exeperience is not a guarantee of safety. Recently I came across a study of glider accidents conducted by French "Bureau d'Enquêtes et d'Analyses (BEA) pour la Sécurité de l'Aviation civile" concerning gliding accidents in France 1999-2001. It shows that in 114 accidents 16 were caused by pilots with less than 100 hours experience, and 98 by those with more than 100 h experience. Those caused by less then 100h pilots resulted in 1 death, thouse by more than 100h resulted in 19 deaths.
I guess after all it is JUDGMENT which is crucial, not glider type, experience etc. And maybe a bit of luck? ...
best regards
Piotr
Old January 10th 21, 12:35 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Piotr Mis wrote on 1/9/2021 3:19 PM:
Do not take any comfort in those numbers. The _exposure_ to risk is much higher in pilots with
over 100 hours, compared to those with less than 100 hours. It does not make sense to compare
the number of accidents at less than 100 hours, to those that might have 1000 hours, or 5000
hours. It also does not take note of the number of pilots flying with over 100 hours, which is
likely many more than those with less than 100 hours.
Old January 7th 21, 02:50 AM posted to rec.aviation.soaring
Andreas Maurer[_2_]
On Wed, 6 Jan 2021 13:38:34 -0800 (PST), Piotr Mis
?roda, 6 stycznia 2021 o*08:39:02 UTC+1 Andreas Maurer napisa?(a):
Well, under normal circmstances a Nimbus 2 is as harmless as any
ASK-21 (I only have some experience in the Numbus 2C).
But, given your limited experience with gliders that are very, very
easy to fly: You are, sorry to say that, not yet qualified to fly a
Nimbus 2.
Given a careful briefing and some additional training in something
similar (Janus, et cetera) you'll probably be able to fly it safely,
but I would never take the risk to lend ***my*** complex glider to
someone with your credentials showing up one afternoon.
One more advice:
Do not over-estimate the performance of an open class glider. I've
been flying one for ages (some kind of ASH-25, with much, much better
performance than a Nimbus 2), and the performance advantage over old
15m class (ASW-20, LS-3) is about 20 percent.
The Nimbus is much too light - to make it perform, you must fly it
with lots of water ballast. Always.
Without water ballast, the old 15m class is going to outperform a
Nimbus in anything but very slow straight flight or extremely weak
thermals - these situations make perhaps 5 percent of all flying.
Combine that with the fear of landing out (safe landing, disassembly
of a heavy, complex glider, big trailer) - and think twice about
buying something a lot easier to handle. Something you simply pull out
of the trailer, put the wings on and fly after 15 minutes.
Cheers
Andreas
Old January 9th 21, 11:31 PM posted to rec.aviation.soaring
Piotr Mis
czwartek, 7 stycznia 2021 oÂ*02:50:24 UTC+1 Andreas Maurer napisaÅ‚(a):
?roda, 6 stycznia 2021 o 08:39:02 UTC+1 Andreas Maurer napisa?(a):
Nimbus 2.
One more advice:
Cheers
Andreas
Thanks Andreas, I am saving all remarks/advice/comments from all of you in a separate file to come back to them and re-read it if I actually buy that Nimbus (I am still weighing pros and cons, plus currently I need to wait until COVID travelling restrictions are lifted to be able to conclude the deal).
From yours and others' comments I conclude that in order to stay on the safe side I must give much consideration to flying conditions (no strong cross winds) and landing spots because of long landing roll. Since I am quite determined to refrain myself from any attempts of long distance xc flying in the first or two years (which I would want ta avoid in any type of glider, also 15m), or attempts of flying in strong cross wind, then I guess that with those two factors of danger ruled out (or at least reduced as much as possible) flying Nimbus should to be pretty harmless as you write.
Maybe it seems to make no sense to get Nimbus for near airfield flying, but I would rather get something which outsizes me a bit in the beginning and grow up to it gradually then getting any 15m of that age availabe. My budget is limited and that particular Nimbus seems to be a bargain, being in really good shape, having already had 3000h service life extension inspection with 2300 hours of flying till next inspection. Other 15m gliders of its age have usually aroun 500-100 hours left before costly 3000h inspection.
Question of hard rigging is of course an issue, but I am planning to keep it hangared for the season (one month = 23 EUR) with taking only wing tips off after flying.
Aside from rational arguments I got the similar feeling as I had buying my motorbike: Ducati Monster 1000 ie. Everyone was saying it was an old fashioned, dangerous, defective, inconvinient bike and a more modern Japanese machine would make much more sense. I agreed it shurely would. Then I bought Monster and I love it
best reg
Piotr
Old January 12th 21, 07:07 PM posted to rec.aviation.soaring
Papa3[_2_]
best reg
Piotr
Hi Piotr,
I think I commented on this thread a couple of years back, but just to re-emphasize. If you are not completely comfortable flying and landing the glider in a wide range of conditions, then I think that itself answers your question about whether you are ready. As an instructor, I emphasize with every student that each flight could be an off-field landing. Not just tow emergencies, but mis-judging conditions, getting caught by a sudden weather change, etc. So, while you have the right attitude about wanting to be conservative in your initial cross-country approach, starting with the assumption that you will not land off-field is a bad idea.
Looking at the data from my club (a mid-sized club in the US), we have at least 2-3 off-airport landings each year NOT related to intentional XC flight. One example was a nice, summer day last year. The pilot flying his ASW-24 on a hot summer day was only 15 miles away at 2000M when a set of clouds suddenly turned into a thunderstorm with heavy rain. He ended up getting caught with the storm between him and the airport and had to make a very tricky off-airport landing only a mile away from the home airport. In another example, a pilot flying the "local ridge" ran into weakening conditions and made the conservative choice to land in a big field rather than to try a marginal glide to home.
There's a difference between price and value. Not everything that comes at a low price is a good value. At least think about that before you make the move.
Erik Mann (P3).
Old January 7th 21, 12:14 AM posted to rec.aviation.soaring
2G
I like Dan's comments regarding having the right attitude and aptitude and flying conservatively.
If money is not an issue then an older 15m ship is probably going to be a better idea if you plan to fly aggressively. I don't compete so flying conservative 3 to 5 hours flights (300 to 500km) on nice days suites me just fine. If I wanted to fly aggressively I would not have bought the Nimbus 2.
3. The used glider market in my area is very small with limited demand so purchasing something like an Astir G102 and then being unable to sell it later to upgrade to a higher performance glider wasn't an option.
4. I have long legs and the Nimbus 2 is the only glider I've flown which has a long cockpit I fit in comfortably. Getting cramps in my ankle and calf muscles and having an aching lower back after an hour of flying single Astirs was no longer enjoyable. My long legs ruled out older, affordable 15m ships like Astirs, ASW15, ASW19.
5. The area I fly in has large fields (500m to 1500m long) and often with shorter grass crops so outlandings are less of a risk. That allowed me to remove the tail chute to avoid the "will it deploy when I need it" and "accidental deployment" scenarios. I have the single panel Schempp-Hirth airbrakes so approach control is adequate but not great. If you need to outland in fields less than 500m with obstacles on approach then I would not recommend the Nimbus 2. Fiddling with a tail chute which doesn't want to deploy while trying to outland in a small field is not the sort of risk I want to take.
Each individual has different circumstances, needs and abilities. The Nimbus 2 is not what I would regard as a "sweet ship" so take the advice about the ground handling and less ideal properties seriously before making a decision. One of the other pilots in the club bought a Nimbus 2M and his experience has not been great at all. Having the CofG near the aft limits probably played a large part in that experience.
I am (or was) 6' 2" and fit into an ASW19 just fine with the seat back removed.
Tom
FS: Nimbus 3-25.5 JS Soaring 0 February 19th 08 08:49 PM
FS Nimbus 3 Roy Bourgeois Soaring 0 December 26th 07 08:47 PM
Nimbus down? [email protected] Soaring 2 November 21st 06 03:10 PM
Nimbus 4 Ray Gimmey Soaring 0 May 17th 04 07:46 PM
F.S. Nimbus 3DM Tom Stowers Soaring 0 October 18th 03 08:06 PM
