On Sun, 21 Mar 2021 12:32:55 -0700, Chris Behm wrote:
On Sunday, March 21, 2021 at 6:55:24 AM UTC-7, Hank Nixon wrote: We are looking at what gliders may be suitable for heavy pilots. Gross weight, max mass of non lifting components, and forward CG limits. Subject pilot weighs 280 lb. Ant experience out there? Thx UH UH- I have been wondering if anyone in the past has modified a dual seat glider into a single seat for heavy pilots. I would think it would be possible and an option, although getting it done and approved might be a bigger problem. Doing this to a high performance 2 seat glider seems like it would be an attractive option for large and heavy glider pilots. Bear in mind that many (most) German gliders design straps and their mount point requirements to match the maximum per-seat load, so adapting a dual seat glider for a 200kg pilot would need cockpit structural changes to (roughly double the max load on straps and their attachment points as well as seating position changes to keep the CG within limits. All in all, it sounds to me like a job needing the expertise of Bob K or the Streifeneder team at Glasfaser. -- Martin | martin at Gregorie | gregorie dot org |
280 is alot
Would a Grob Speed Astir or one of the Grob single seat models work? My Grob Twin Astir had large seats.... Nick T |
On Sunday, March 21, 2021 at 6:04:26 PM UTC-6, wrote:
280 is alot Would a Grob Speed Astir or one of the Grob single seat models work? My Grob Twin Astir had large seats.... Nick T There are a few that would be within CG range, but very few that would allow that margin with non-lifting parts. Genesis 2 could probably be 'weighted' to work using the rear ballast weights and may still be in the non-lifting parts range. IIRC, Open Cirrus CG range is good to about 350lbs, but it would exceed the seat weight restraint limit of 242lbs, yet still be within the max dry weight and non-lifting parts range (551lbs) of 882lbs. BGA allows a LAK12 to put lead in the tail to allow 130kg in the cockpit, but the cockpit may be tight in other dimensions. Frank |
I have flown a twin astir at max front seat weight ,
You run out of back stick to get speed down , NOT a glider to fly over max weight ,you run out of elevator Gary On Monday, March 22, 2021 at 1:04:26 PM UTC+13, wrote: 280 is alot Would a Grob Speed Astir or one of the Grob single seat models work? My Grob Twin Astir had large seats.... Nick T |
On Monday, March 22, 2021 at 2:29:22 AM UTC-6, wrote:
I have flown a twin astir at max front seat weight , You run out of back stick to get speed down , NOT a glider to fly over max weight ,you run out of elevator Gary I've heard a heavy pilot can fly it solo from the back seat. Should help with the elevator. Frank |
| Thread Tools | |
| Display Modes | |
| Heavy pilot - what glider to opt for? | [email protected] | Soaring | 53 | April 7th 14 05:38 PM |
| Hangar dolly for heavy glider | Dave Nadler | Soaring | 20 | May 29th 13 06:49 PM |
| Glider pilot and ME 163 Komet Pilot Rudy Opitz Has Died | Paul Remde | Soaring | 5 | May 12th 10 01:56 AM |
| ETA glider landing with heavy front wind in Rieti, videoclip | PCool | Soaring | 2 | October 1st 09 04:10 PM |
| Heavy pilot & lead in tail | Flyhighdave | Soaring | 8 | January 4th 04 02:28 AM |
