Did you ever notice that fixing one thing often seem to break something else
in the old airplanes most of us fly? We just had our new Directional Gyro installed today (just six weeks after our Attitude Indicator failed), and lo and behold, our autopilot works again! The gyros erect immediately, and no precession of the DG was noticed in our test flight -- all was right with the world again! Well, almost. It immediately became obvious that something was amiss with our Com 1 radio. Depressing the PTT produced a nasty, high-pitched hum that didn't sound good, and it didn't seem like we were hearing much of anything on Unicom, despite several planes working the pattern. After a few minutes of futzing around, we determined that we could just barely receive the AWOS broadcast, despite being parked right next to the transmitter! We switched to Com 2, which was working normally, and proceeded with our test flight. Since Com1 is our newest radio (the digital Narco 820R), we figured it couldn't be a problem with the radio itself (although, of course, you never really know). And, of course, the panel had JUST been ripped apart to install the new DG (And I had them replace ALL the vacuum tubing from the vacuum pump back, as long as we had everything open. It was the ORIGINAL tubing, dated 1975!) So, we pretty much knew that SOMETHING had been accidentally disconnected during the installation -- but what? So, it was back to my A&P's shop, where they resignedly (but good-naturedly) started trouble-shooting the issue. Of course, it meant taking the seats out again, and climbing up under the panel with a shop light -- no easy task for two heavy-weight guys approaching 60 years old. The radios in our plane have probably been replaced six times since 1974. Worse, every guy that put in a new radio seemed to string new wires, simply cutting off the old antenna wires. This meant that there are several "antenna wires to no where" under the panel -- making determining which one was disconnected an exercise in frustration. Well, after almost two hours the bugger was found, and reconnected -- but what a pain, for all concerned! Somehow during the installation of the instruments, vacuum hoses, filters, and hose clamps, this one wire was accidentally detached, leading to a long wild goose chase. This isn't the first time this has happened to me. Anyone else have a similar experience? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Back when I used to be an electronics tech, we called this phenominon
"repair damage" ;-) |
Jay Honeck wrote:
: The radios in our plane have probably been replaced six times since 1974. : Worse, every guy that put in a new radio seemed to string new wires, simply : cutting off the old antenna wires. This meant that there are several : "antenna wires to no where" under the panel -- making determining which one : was disconnected an exercise in frustration. My airplane has also gone through many radio installations, from the original dual narco 2-piece tube units onward. When I replaced the audio panel in my airplane, I also removed and replaced all of the radio audio signal wires, and power wires. I removed all of the "wires to nowhere" that were disconnected at both ends. I retied all of the wire bundles under the dash. This probably added 4 to 6 hours to the job, but since I did it during the 9/11 grounding the extra days weren't too critical. I don't think many people would pay someone to do this, because it doubled the job time. Since I was working myself (under supervision), the time was less of a factor. Net result? Instead of the wire bundles being 3" in diameter, they're now 1" in diameter. The radios don't hum, whistle, or otherwise misbehave. And, I ended up with a 33 gallon trash bag full of bits of wire! I removed over 4lbs of unused, disconnected, wiring and a mess of unnecessary connectors. -- Aaron Coolidge (N9376J) |
On 3-Dec-2003, "Jay Honeck" wrote: Well, after almost two hours the bugger was found, and reconnected -- but what a pain, for all concerned! Somehow during the installation of the instruments, vacuum hoses, filters, and hose clamps, this one wire was accidentally detached, leading to a long wild goose chase. This isn't the first time this has happened to me. Anyone else have a similar experience? In a forum of airplane owners it would be more realistic to ask if there is anyone who had NOT had a similar experience! -- -Elliott Drucker |
"Neal" wrote in message ... Back when I used to be an electronics tech, we called this phenominon "repair damage" ;-) Or....take a call, make a call. |
Jay Honeck wrote: : The radios in our plane have probably been replaced six times since 1974. : Worse, every guy that put in a new radio seemed to string new wires, simply : cutting off the old antenna wires. This meant that there are several : "antenna wires to no where" under the panel -- making determining which one : was disconnected an exercise in frustration. I have often speculated that iffen I were clean-sheet designing a nav/com; I would do about what ICOM did on at least one series of VHF amateur transceivers. There'd be a control panel, with display and controls. It has fiber fiber back to the box under the rear seat. The control panel is say 1" deep -- it has nothing but the displays, LED's, optical spin encoders, and a minimum of drive electronics. This gets all the electronics of import out of the jungle oven known as "in front of the panel" to where they can be easily wired, seen and cooled. CG permitting, you could add a adjacent 3AH GelCell as emergency power. You could also do the same with GPS, xponder, etc. In fact the panels might be the same hardware, except for labels. Yea, I know, that's ~~what the ARINC standard used to do on DC-6 era beasts -- remote everything down to the radio bay. One issue you add is the interconnecting wiring as failure points. But if we use flexible fiber jumpers, instead of 18-odd wires, that's a different kettle of fish. Further, if it loses the fiber connectivity, the radio can revert to ?121.5? and preset volume, etc. Now, I don't think anyone will ever do this -- for all the reasons the GA fleet is what it is. But I still think it is a fun engineering dream, at least. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
David Lesher wrote:
I have often speculated that iffen I were clean-sheet designing a nav/com; I would do about what ICOM did on at least one series of VHF amateur transceivers. There'd be a control panel, with display and controls. It has fiber fiber back to the box under the rear seat. The control panel is say 1" deep -- it has nothing but the displays, LED's, optical spin encoders, and a minimum of drive electronics. This gets all the electronics of import out of the jungle oven known as "in front of the panel" to where they can be easily wired, seen and cooled. CG permitting, you could add a adjacent 3AH GelCell as emergency power. You could also do the same with GPS, xponder, etc. In fact the panels might be the same hardware, except for labels. Yea, I know, that's ~~what the ARINC standard used to do on DC-6 era beasts -- remote everything down to the radio bay. One issue you add is the interconnecting wiring as failure points. But if we use flexible fiber jumpers, instead of 18-odd wires, that's a different kettle of fish. Further, if it loses the fiber connectivity, the radio can revert to ?121.5? and preset volume, etc. Now, I don't think anyone will ever do this -- for all the reasons the GA fleet is what it is. But I still think it is a fun engineering dream, at least. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 Back in the "good old days" when I was an avionics tech, they HAD to put things in the back; the equipment was just too big to fit it all behind the panel. The equipment rack in the back of your average Cessna/Piper is no heaven for equipment. It vibrates just as much and it is actually hotter than behind the panel. Remember, there are no vents back there while up front you have cabin vents. Most of the problems with the old MK-12 solid state inverter power supplies and the AT-5 transponders were due to the heat and vibration in the back. Running cables of any kind from the back to behind the panel is also highly labor intensive when done correctly. Basically, you just about have to gut the seats and carpets to get under there and make sure the cables are properly secured and protected so they don't wind up interfering with control mechanisms or getting chaffed in two where they run over all the sharp metal edges down there. Lots of problems turned out to be nothing more than marginal installation of cables under the floor done by somebody on the cheap. The only solution was to rip it all out and replace it correctly. While you could replace a lot of the wiring with a fiber optic data cable, you still have to run power back there and you still have to keep the cables protected and out of the workings. Plus splicing and putting connectors correctly on fiber is a pain in the butt. -- Jim Pennino Remove -spam-sux to reply. |
is anyone who had NOT had a similar experience! Yeah, I guess that *was* pretty silly of me... ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Happens all the time. This is one reason I never fly a plane on a trip
right after a repair or inspection. jerry This isn't the first time this has happened to me. Anyone else have a similar experience? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
| Thread Tools | |
| Display Modes | |
| Big Bertha Thing blogs | Tony Lance | Owning | 14 | January 19th 05 11:17 PM |
| Big Bertha Thing blogs | Tony Lance | Military Aviation | 9 | September 1st 04 12:01 AM |
| OSH - the chair thing | Montblack | Owning | 9 | July 24th 03 09:19 PM |
| SUV thing | Fastglasair | Home Built | 4 | July 12th 03 06:32 AM |
