I'm looking for some advice on a voltmeter (preferably digital) that
will plug into the "cigarette lighter" of my airplane. I found one on the J. C. Whitney site, but $50 is too much for what I want to use it for. I've got a JPI analyzer which reads voltages off the avionics bus, and also a Davtron clock which does the same. Curiously, they differ, with the JPI reading 0.3 to 0.5 volts lower! Furthermore, the voltage on the avionics bus seems to be less than I'd expect, anywhere from 12.2 to 13.0 (instead of the 13.2 I'd expect). Further-furthermore, the voltage drops during flight (I guess as the voltage regulator cuts off the alternator as the battery is recharged after starting) to the point where I get low-voltage warnings from the JPI. No other symptoms of electrical problems. Been doing this for many months (since I had the JPI installed) but still cranks fine. Anybody know of a reasonably priced gadget that will let me monitor the MAIN bus feeding the cigarette lighter? Rich |
Bob writes:
I'm looking for some advice on a voltmeter (preferably digital) that will plug into the "cigarette lighter" of my airplane. I found one on the J. C. Whitney site, but $50 is too much for what I want to use it for. I've got a JPI analyzer which reads voltages off the avionics bus, and also a Davtron clock which does the same. Curiously, they differ, with the JPI reading 0.3 to 0.5 volts lower! Furthermore, the voltage on the avionics bus seems to be less than I'd expect, anywhere from 12.2 to 13.0 (instead of the 13.2 I'd expect). Further-furthermore, the voltage drops during flight (I guess as the voltage regulator cuts off the alternator as the battery is recharged after starting) to the point where I get low-voltage warnings from the JPI. No other symptoms of electrical problems. Been doing this for many months (since I had the JPI installed) but still cranks fine. Anybody know of a reasonably priced gadget that will let me monitor the MAIN bus feeding the cigarette lighter? Rich www.google.com - "cigarette lighter voltmeter" yielded http://www.cetsolar.com/voltmeter.htm - $16.99 The "reasonable price" limitation of your query, though, might not help the situation. I suspect that you want an instrument which will give you a reference voltage. A "reasonably priced" voltmeter may be less accurate. Hope the link helps. -Jack |
Bob wrote:
I'm looking for some advice on a voltmeter (preferably digital) that will plug into the "cigarette lighter" of my airplane. I found one on the J. C. Whitney site, but $50 is too much for what I want to use it for. I've got a JPI analyzer which reads voltages off the avionics bus, and also a Davtron clock which does the same. Curiously, they differ, with the JPI reading 0.3 to 0.5 volts lower! Furthermore, the voltage on the avionics bus seems to be less than I'd expect, anywhere from 12.2 to 13.0 (instead of the 13.2 I'd expect). Further-furthermore, the voltage drops during flight (I guess as the voltage regulator cuts off the alternator as the battery is recharged after starting) to the point where I get low-voltage warnings from the JPI. No other symptoms of electrical problems. Been doing this for many months (since I had the JPI installed) but still cranks fine. Anybody know of a reasonably priced gadget that will let me monitor the MAIN bus feeding the cigarette lighter? Rich The problem is you need accuracy and cheap and accuracy don't go together. I would be surprised if the accuracy of the existing voltmeters are much better than about 2%, which would easily account for the difference. Multimeters in the $50 to $100 range have a typical accuracy of 1% for DC. That translates to +/- .13V at 13V, which gets you close, but is a bit much to pay for a one-shot measurement (unless you have other use for the multimeter). The cheapest option would be to find someone that already has a decent meter (HAM, repair guy, etc.) that will let you borrow his so you can make a calibration chart for the meters in the A/C. As to the voltage, it does sound a little low. One check you can make is to note the voltage with everything turned on at runup RPM. Then turn everything you can off and note the voltage again. There should be no change. If there is a change, I would check, clean and tighten the connection(s) from the battery to the avionics bus. While you're doing that, I would also check to see if the JPI and Davtron have their power and grounds connected to the same things. Some installations also have a ground bus where all the avionics grounds come together with one heavy connection to the A/C ground. If you have one of those, check, clean and tighten the connection between the bus and the A/C ground. Then run the check again. If it still changes you probably need a trip to the avionics shop to fix it unless you happen to be good at this sort of thing. -- Jim Pennino Remove -spam-sux to reply. |
YEAH!
That's the device I'm looking for! Now to see what shipping would be... or how to find it locally (I'm in SE Mich). Jack, I agree with your counsel and Jim's, that calibration may be an issue. However, I've got a pretty good digital multimeter, and a REALLY GOOD Hewlett Packard laboratory power supply that should allow me to calibrate it (or create a deviation card) sufficient for my purposes. Good suggestion to check grounds, too. I'm SURE they are grounded to different places. I can see where the Davtron mounts... gonna have to figure out the wiring on the JPI (which is using a previous GEM 602 harness). Thanks again! Rich Jack Cunniff wrote: Bob writes: I'm looking for some advice on a voltmeter (preferably digital) that will plug into the "cigarette lighter" of my airplane. I found one on the J. C. Whitney site, but $50 is too much for what I want to use it for. I've got a JPI analyzer which reads voltages off the avionics bus, and also a Davtron clock which does the same. Curiously, they differ, with the JPI reading 0.3 to 0.5 volts lower! Furthermore, the voltage on the avionics bus seems to be less than I'd expect, anywhere from 12.2 to 13.0 (instead of the 13.2 I'd expect). Further-furthermore, the voltage drops during flight (I guess as the voltage regulator cuts off the alternator as the battery is recharged after starting) to the point where I get low-voltage warnings from the JPI. No other symptoms of electrical problems. Been doing this for many months (since I had the JPI installed) but still cranks fine. Anybody know of a reasonably priced gadget that will let me monitor the MAIN bus feeding the cigarette lighter? Rich www.google.com - "cigarette lighter voltmeter" yielded http://www.cetsolar.com/voltmeter.htm - $16.99 The "reasonable price" limitation of your query, though, might not help the situation. I suspect that you want an instrument which will give you a reference voltage. A "reasonably priced" voltmeter may be less accurate. Hope the link helps. -Jack |
YEAH! That's the device I'm looking for! Now to see what shipping would be... or how to find it locally (I'm in SE Mich). Glad to help. Someone on the Piper mailing list has mentioned this device before, but the groupthink has been that the JPI would be more accurate than a cigarette-lighter voltmeter like this. Still, if one didn't have another way to get a quick voltage reading, it's better than nothing. Jack, I agree with your counsel and Jim's, that calibration may be an issue. However, I've got a pretty good digital multimeter, and a REALLY GOOD Hewlett Packard laboratory power supply that should allow me to calibrate it (or create a deviation card) sufficient for my purposes. Again, glad to help. -Jack |
On Wed, 17 Dec 2003 17:28:37 +0000 (UTC), Jack Cunniff
wrote: Bob writes: I'm looking for some advice on a voltmeter (preferably digital) that will plug into the "cigarette lighter" of my airplane. I found one on the J. C. Whitney site, but $50 is too much for what I want to use it for. I've got a JPI analyzer which reads voltages off the avionics bus, and also a Davtron clock which does the same. Curiously, they differ, with the JPI reading 0.3 to 0.5 volts lower! Furthermore, the voltage on the avionics bus seems to be less than I'd expect, anywhere from 12.2 to 13.0 (instead of the 13.2 I'd expect). Further-furthermore, the voltage drops during flight (I guess as the voltage regulator cuts off the alternator as the battery is recharged after starting) to the point where I get low-voltage warnings from the JPI. No other symptoms of electrical problems. Been doing this for many months (since I had the JPI installed) but still cranks fine. Anybody know of a reasonably priced gadget that will let me monitor the MAIN bus feeding the cigarette lighter? Rich www.google.com - "cigarette lighter voltmeter" yielded http://www.cetsolar.com/voltmeter.htm - $16.99 The "reasonable price" limitation of your query, though, might not help the situation. I suspect that you want an instrument which will give you a reference voltage. A "reasonably priced" voltmeter may be less accurate. Hope the link helps. -Jack I think that wherever he takes a voltage reading, there will be a difference. What he needs to do is to hook up the Davtron and JPI to the exact same post, both + and -, use the exact same type of connector and insure that the same wire size is used as lead. Incidentally, I've seen about a dozen Davtron/JPI equipped planes, and none agree on the voltage. One may have built this "flaw" to drive some of the flying population crazy. |
Stu Gotts wrote:
I think that wherever he takes a voltage reading, there will be a difference. What he needs to do is to hook up the Davtron and JPI to the exact same post, both + and -, use the exact same type of connector and insure that the same wire size is used as lead. Incidentally, I've seen about a dozen Davtron/JPI equipped planes, and none agree on the voltage. One may have built this "flaw" to drive some of the flying population crazy. Theoretically, if you have a sensitive enough voltmeter, that's true, but for the currents drawn by modern solid state avionics if you get ..1V drop accross a connection, it's probably a bad connection. The biggest source of error, assuming both the Davtron and JPI are installed correctly, is their basic accuracy. Most of these things read to .1V resolution, but to get .1V accuracy at 13V means the meter accuracy must be better than .1/13 which is about ..8%. To further complicate the discussion, since these things are digital, you need to have half last digit accuracy to ensure the last digit changes halfway between two values. That is, you need to have .05V accuracy to ensure the last digit switches from .2V to .3V as the voltage passes through .25V for example. At 13V, that means .05/13 which is about .4% accuracy. Most bench test equipment is only good for about 1% accuracy; .4% is starting to get into the realm of lab equipment. On top of all that, there are also the problems of temperature coefficient, how much the reading changes as the temperature of the instrument changes, and periodic calibration to compensate for compenent aging. Anyone taken their Davtron or JPI out to check calibration lately? The practical thing to do about the Davtron and JPI is to get the most accurate meter you can find and note the difference between the 3 meters. For the range of interest, i.e. about 11-13V the difference is going to be linear so all you need is a single correction factor for each meter as opposed to a correction card covering a range. The bottom line is these in panel meters are just reference, not lab equipment, unless someone went to heroic lengths (and a heroic price to match) to get the accuracy and calibration that close and the periodic recalibration to ensure it stays there. -- Jim Pennino Remove -spam-sux to reply. |
If you already have a good DMM, do what I did--
Go to Wal-Mart and buy a cigarette lighter plug for $0.99. Strip the leads and clip to your DMM. Start your motor and go. With my Fluke 87A, I could even trap voltage spikes on the system. Mike M. |
That was going to be my "fall back" plan... and I may still do it,
depending on the readings I get from the Plug in Voltmeter. Reason for the plug in unit was to have something I could leave in the plane and monitor over the course of several flights. Unit is on its way to Michigan from "Auto Barn" in New York. Couldn't find one at several Auto Specialty shops locally. Rich Michael J. Myers wrote: If you already have a good DMM, do what I did-- Go to Wal-Mart and buy a cigarette lighter plug for $0.99. Strip the leads and clip to your DMM. Start your motor and go. With my Fluke 87A, I could even trap voltage spikes on the system. Mike M. |
Bob wrote:
Anybody know of a reasonably priced gadget that will let me monitor the MAIN bus feeding the cigarette lighter? If you connect a third voltmeter, you will now have three different readings. Which are you going to believe? It like wearing three watches, which one is "closest" to the correct time? The only thing that really matters is what is the voltage at the battery terminals. If your batteries are lasting more than three years, and as long as the starter consistently cranks, then the voltage cant be too far off. If you are not consistanly adding water to the battery, then your bus voltage is not too high. If your starter is not laboring, and your airplane starts consistantly, then your bus voltage is not too low. The "acid test" (pun intended) is to check the Specific Gravity of the battery with a hydrometer. MikeM Skylane '1MM Pacer '00Z |
| Thread Tools | |
| Display Modes | |
| Helicopter headset plug - help needed | NewsGroups | Home Built | 4 | September 8th 04 06:21 PM |
| Hubble plug to be pulled | John Carrier | Military Aviation | 33 | March 19th 04 05:19 AM |
| OV-10A Bronco Shameless ebay plug | DavidG35 | Military Aviation | 0 | November 7th 03 07:17 AM |
| WTB: Turbine ignition exciter unit, single plug | Juan E Jimenez | Aviation Marketplace | 0 | August 25th 03 01:48 AM |
| spark plug question | Bill T. | Owning | 0 | July 3rd 03 08:08 PM |
