Might have to move the compass up away from the panel. There are a lot
of electrics under the glareshield that could be interfering with it. I had the same problem with a vertical card compass in an Ercoupe, and had to put it way up on the windshield bow. Those vertical card units are very sensitive to vibration. You HAVE to use the really soft, floppy mount they provide for them. Remember that GPS give you track, not heading, and if there's any appreciable wind you won't get anywhere near accurate heading indications for compass calibration purposes. Use the heading indicator instead. Dan |
Dan Thomas wrote: Remember that GPS give you track, not heading, and if there's any appreciable wind you won't get anywhere near accurate heading indications for compass calibration purposes. Use the heading indicator instead. Yep, forget the GPS. Use this method instead: Line up on a taxiway or runway with a known, published heading and carefully set the HI. Go fly on gyro headings 360, 030, 060, etc. and carefully record the magnetic compass reading. You might want to try it with and without lights, pitot heat, any other major power consumers. Return to your known taxiway or runway and verify the HI hasn't drifted. Dave Remove SHIRT to reply directly |
| Thread Tools | |
| Display Modes | |
| Reading the whiskey compass | Ben Jackson | Instrument Flight Rules | 20 | February 28th 04 09:09 AM |
| "Whiskey" for compass? | dale | Home Built | 10 | December 18th 03 12:16 AM |
| RAHian behavior | Morgans | Home Built | 6 | August 12th 03 05:38 AM |
| I'm lost. Which compass? | Greg Burkhart | Owning | 1 | August 12th 03 04:49 AM |
| Vertical Card Compass compatible with "V" brace? | Jeff P | Owning | 1 | July 11th 03 04:46 AM |
