![]() "Jim Weir" wrote in message news ![]() " jls" shared these priceless pearls of wisdom: - -And if the burn is cooler when 100LL (rather than 80) is run through the -carb, why is it the engine must have special 100LL exhaust valves, which are -designed with high-temperature alloys? The alloy of a valve in a low-compression Continental engine is precisely the same alloy as the 100LL exhaust valve. The 100LL valve has had some machine work and clearance work (mainly in the stem area and in the angle of the valve seat area) done to make it compatible with the excess 100LL lead that jams valves. I stand corrected, then. Thanks for your lecture and I note that you rubbed it in a little too. OK, all in a day's fun. I can take it. Sniffle I had read that the 100 octane valve was a different alloy but always wondered if it were so. It sure is a comparatively expensive little bugger. -I don't know the answer but I tell you what I suspect. I suspect the egt -of 100LL will be higher. You suspect wrong. I have made this exact same measurement on several low-compression Continentals before I started using mogas (primarily the O-300D, but a couple of more engines to a lesser extent. Mogas burns hotter according to the EGT. Thanks. I will find out soon with respect to my own O-300 which will have EGT sensors and will compare results. Btw I enjoyed the poke you took at the poor guy who had chickens in his sparkplugs. He was right gentlemanly about the poke too. -Higher octane gasoline like 100LL, furthermore, is a little less volatile -than mogas and burns more slowly because of the higher RON numbers, so that -when the exhaust valve opens combustion is less complete than with the same -charge of mogas -- in the low-compression O-300. So if you're running -100LL in an O-300-powered 172, why do you need 100-octane exhaust valves, -whose faces are something like inconel or another exotic alloy designed for -temperatures much higher than the stock exhaust valves? You predicate your entire argument on the fallacy of "exotic alloy" valves, when in fact, the only difference is in the settings of the lathe that cuts them. Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
![]() "Jim Weir" wrote in message news ![]() " jls" shared these priceless pearls of wisdom: - -And if the burn is cooler when 100LL (rather than 80) is run through the -carb, why is it the engine must have special 100LL exhaust valves, which are -designed with high-temperature alloys? The alloy of a valve in a low-compression Continental engine is precisely the same alloy as the 100LL exhaust valve. The 100LL valve has had some machine work and clearance work (mainly in the stem area and in the angle of the valve seat area) done to make it compatible with the excess 100LL lead that jams valves. Now that I have done some homework, I find your statement here to be in error. Please look up the alloy formula for stellite, which is the exotic alloy coating on expensive 100-octane aircraft engine exhaust valves. I bought several of these exhaust valves recently for a small Continental engine. I had earlier told you that I stood corrected but now must refute what you have said here after having studied your arguments and contentions. As for most of the typical exhaust valve surface it is chromium-plated and the stellite added to the 100-octane exhaust valve is plated onto the seating face. -I don't know the answer but I tell you what I suspect. I suspect the egt -of 100LL will be higher. You suspect wrong. I have made this exact same measurement on several low-compression Continentals before I started using mogas (primarily the O-300D, but a couple of more engines to a lesser extent. Mogas burns hotter according to the EGT. Yes, then, a negligible number, like 9 degrees as stated by a later poster flying an O-360 powered 172 with avgas in one tank and mogas in the other. 'Net homework also shows, as this poster found, a negligible increase in EGT with mogas. -Higher octane gasoline like 100LL, furthermore, is a little less volatile -than mogas and burns more slowly because of the higher RON numbers, so that -when the exhaust valve opens combustion is less complete than with the same -charge of mogas -- in the low-compression O-300. So if you're running -100LL in an O-300-powered 172, why do you need 100-octane exhaust valves, -whose faces are something like inconel or another exotic alloy designed for -temperatures much higher than the stock exhaust valves? You predicate your entire argument on the fallacy of "exotic alloy" valves, when in fact, the only difference is in the settings of the lathe that cuts them. I am afraid that the manifest weight of authority is against you and completely refutes you on your contention here. I just looked up those stellite constituents for the typical 100-octane stellite exhaust valves sold for Continental engines. They are pretty exotic, as in: manganese, molybdenum, chromium, silicon, nickel, and cobalt. That doesn't sound to me like enhancing a steel valve with a lathe. That stellite stuff sounds like "exotic alloy" hardening to me. You do YOUR homework now, fella. I'll respect your authority on the issue of radios and antennae, however. I have now retracted my earlier statement admitting error and saying that I stood corrected. The floor is yours now to resurrect your case, if that is possible. Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Stu Gotts wrote:
1 What is it going to show happened to the EGTs when you switched tanks? I was taught that 87 and 100LL avgas burns at the same temperature. The octane only allows the flame front to propagate smoothly through the cylinder. Autogas is a different formulation, so it may burn at a different temperature. If autogas burns cooler, the EGTs will decrease. If autogas burns hotter, the EGTs will increase. 2 What is it going to show happened to the CHTS when you switched tanks? CHTs will follow EGTs. 3 (not in the JPI, but: ) What is the airspeed going to do? Increase? Decrease? Stay the same? Why? Depends on the energy content of the fuel, not the temperature. Pistons work on pressure. The more energy released by the fuel, the more pressure is generated to drive the piston. More energy means the engine is turning faster (higher torque?). More torque transmitted to the prop produces more airspeed. That's my reasoning. |
![]() "john smith" wrote in message ... Stu Gotts wrote: 1 What is it going to show happened to the EGTs when you switched tanks? I was taught that 87 and 100LL avgas burns at the same temperature. The octane only allows the flame front to propagate smoothly through the cylinder. Autogas is a different formulation, so it may burn at a different temperature. If autogas burns cooler, the EGTs will decrease. If autogas burns hotter, the EGTs will increase. http://www.avweb.com/news/columns/182149-1.html April 27, 2002 Pelican's Perch #55: Lead in the Hogwash Tetraethyl lead has been gone from automobile gasoline for two decades, and it's only a matter of time before leaded avgas goes away as well. Despite a huge amount of industry research, nobody yet has a suitable replacement fuel, and nobody's yet quite sure what will happen to today's piston-powered fleet when the supply of 100LL dries up. AVweb's John Deakin dispels a bunch of myths about TEL, explains what it does and why it's so indispensable in high-performance recips, and talks about one solution to the coming unleaded-avgas crisis that actually works. |
Before this morfs into how the innkeeper built his homemade fuel
pumper, I thought I would post the answers. I'm surprised many more didn't take a shot at this but then again, it's not regular hangar chat. How well did you do? EGT = Exhaust Gas Temperature CHT = Cylinder Head Temperature ROP = Rich of Peak LOP = Lean of Peak (and I should have listed this earlier, sorry!) The lower octane should cause a faster overall burn time and short interval to peak pressure - - and that should result in lower EGTs. For the same reasons, the peak pressure increase should cause higher CHTs. And the horsepower ?? It probably would not change much... 1-2 % . The overall effect is the same as if you had improperly advanced the timing 3-7 degrees. Regards, George Contact George at gami.com for any further explanations. Ok... little MOGAS quiz for you. You run the Left tank dry and fill it up with premium unleaded car gas. Right tank has 100LL. Takeoff on the RH tank and climb, level off, and set up the mixture for cruise flight. Either ROP or LOP. Your choice. THEN, you switch to the LEFT tank. You change nothing else. Later you download your JPI and plot the data. 1 What is it going to show happened to the EGTs when you switched tanks? 2 What is it going to show happened to the CHTS when you switched tanks? 3 (not in the JPI, but: ) What is the airspeed going to do? Increase? Decrease? Stay the same? Why? |
Stu Gotts
shared these priceless pearls of wisdom: -Before this morfs into how the innkeeper built his homemade fuel -pumper, I thought I would post the answers. I'm surprised many more -didn't take a shot at this but then again, it's not regular hangar -chat. How well did you do? The innkeeper built his homemade fuel pumper after seeing the plans that a sparky gave him at an Oshkosh forum, but to the point... Now to the point -- I thought you said that your source had DONE the experiment and HAD data. People who have been there and done that don't say "SHOULD" and "PROBABLY", they say "DID". I think you've dicked the problem without hard data. Jim - -EGT = Exhaust Gas Temperature -CHT = Cylinder Head Temperature -ROP = Rich of Peak -LOP = Lean of Peak -(and I should have listed this earlier, sorry!) - - -The lower octane should cause a faster overall burn time and short ^^^^^^ -interval to peak pressure - - and that should result in lower EGTs. ^^^^^^ - -For the same reasons, the peak pressure increase should cause higher ^^^^^^ -CHTs. - -And the horsepower ?? It probably would not change much... 1-2 % . ^^^^^^^ - -The overall effect is the same as if you had improperly advanced the -timing 3-7 degrees. - -Regards, George - -Contact George at gami.com for any further explanations. - - - - - - -Ok... little MOGAS quiz for you. - -You run the Left tank dry and fill it up with premium unleaded car -gas. - -Right tank has 100LL. - -Takeoff on the RH tank and climb, level off, and set up the mixture -for -cruise flight. Either ROP or LOP. Your choice. - - -THEN, you switch to the LEFT tank. You change nothing else. - -Later you download your JPI and plot the data. - -1 What is it going to show happened to the EGTs when you switched -tanks? - -2 What is it going to show happened to the CHTS when you switched -tanks? - -3 (not in the JPI, but: ) What is the airspeed going to do? Increase? -Decrease? Stay the same? - -Why? - Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
On Mon, 08 Mar 2004 08:08:58 -0800, Jim Weir wrote:
Stu Gotts shared these priceless pearls of wisdom: Now to the point -- I thought you said that your source had DONE the experiment and HAD data. People who have been there and done that don't say "SHOULD" and "PROBABLY", they say "DID". I think you've dicked the problem without hard data. Jim I agree, but that's not in character for him. But if I may be so bold to correct the Great Weir, "Shall" must be used rather than "Should". You're a big boy, call him up and ask him. My "source" is George Braly of GAMI. You know, injectors, turbo normalizing, PRISM, APS, etc. He wrote it, he sent it, he answered it. You may be surprised to hear how he arrived at the answers. |
![]() I don't give a DAMN how he arrived at the answers other than doing the experiment. Obviously he hasn't. I don't know what is in "character" for a person of this magnitude other than to tell it right up front HOW he measured it and under WHAT conditions. Then others can repeat the experiment and show it valid or not. Every scientist from the dawn of time through Newton and Einstein published their theory, and then the proofs, and then the experiments to prove them right or wrong. If Brother Braly isn't willing to give us hard numbers as to his measurements, then we are just whistling in the wind. Try again, and no, I'm not going to waste my time with phone calls. If the "probably"s in this newsgroup were laid end to end, it would be a good idea. Jim Stu Gotts shared these priceless pearls of wisdom: -On Mon, 08 Mar 2004 08:08:58 -0800, Jim Weir wrote: - -Stu Gotts -shared these priceless pearls of wisdom: - -Now to the point -- I thought you said that your source had DONE the experiment -and HAD data. People who have been there and done that don't say "SHOULD" and -"PROBABLY", they say "DID". I think you've dicked the problem without hard -data. - - -Jim - -I agree, but that's not in character for him. But if I may be so bold -to correct the Great Weir, "Shall" must be used rather than "Should". -You're a big boy, call him up and ask him. My "source" is George -Braly of GAMI. You know, injectors, turbo normalizing, PRISM, APS, -etc. He wrote it, he sent it, he answered it. You may be surprised -to hear how he arrived at the answers. - Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Too bad your scope doesn't include an open mind and open ears. What
seems to be your problem? Something you can't claim to know anything about? Poor baby! For those that realize Weir can hurt as much as he helps (old age assaholism, I guess, or maybe he's still ****ed that a foreigner could beat him in the election), and would like to pursue this, a simple email to George will give you any answers yo o may need to justify his quiz Q & A's. I know the guy and his company and his work, and I'll take him at his word. I'll drop him an email to see if he claims to know anything about manufacturing electronics (other than the PRISM system), but I somehow bet he'll leave that to the real experts in the field without questioning them about what they eat for breakfast. On Mon, 08 Mar 2004 19:47:05 -0800, Jim Weir wrote: I don't give a DAMN how he arrived at the answers other than doing the experiment. Obviously he hasn't. I don't know what is in "character" for a person of this magnitude other than to tell it right up front HOW he measured it and under WHAT conditions. Then others can repeat the experiment and show it valid or not. Every scientist from the dawn of time through Newton and Einstein published their theory, and then the proofs, and then the experiments to prove them right or wrong. If Brother Braly isn't willing to give us hard numbers as to his measurements, then we are just whistling in the wind. Try again, and no, I'm not going to waste my time with phone calls. If the "probably"s in this newsgroup were laid end to end, it would be a good idea. Jim Stu Gotts shared these priceless pearls of wisdom: -On Mon, 08 Mar 2004 08:08:58 -0800, Jim Weir wrote: - -Stu Gotts -shared these priceless pearls of wisdom: - -Now to the point -- I thought you said that your source had DONE the experiment -and HAD data. People who have been there and done that don't say "SHOULD" and -"PROBABLY", they say "DID". I think you've dicked the problem without hard -data. - - -Jim - -I agree, but that's not in character for him. But if I may be so bold -to correct the Great Weir, "Shall" must be used rather than "Should". -You're a big boy, call him up and ask him. My "source" is George -Braly of GAMI. You know, injectors, turbo normalizing, PRISM, APS, -etc. He wrote it, he sent it, he answered it. You may be surprised -to hear how he arrived at the answers. - Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Mogas for an O-320 with 160 HP? | jls | Home Built | 3 | December 31st 04 07:48 PM |
