"Michael" wrote in message om... My friend just bought an airplane. He did the prepurchase inspection himself. That's not as bad as it sounds - he is an A&P/IA and has owned and restored many airplanes. The plane was an older model light twin and he got a great deal on it. On the flight home one of the nav's (the only one with GS), one of the comm's, the DME, one of the EGT's, and the Mode C all failed. This was after he completed the inspection and wrote the check. Everything worked when he started the flight home. When he bought his last light twin several years ago, he had a similar streak of failures bringing the plane to his home base for an inspection. However, that time the owner was with him, and they had not yet negotiated a price. Once again, everything worked when they started the trip. A different friend of mine ferried a light complex single from Texas to the East Coast. They started the trip with a full IFR panel (dual nav-coms, DME, ADF, etc) and finished with a single radio and transponder - everything else had failed enroute. Do I simply know the wrong people, or have others had the same experiences? Michael A few years back I was going from Wichita to Richmond in my P Baron. Motoring along at FL 230 I was picking up intermittent ice at night. Simultaneously, the stall horn went off and the autopilot quit. The stall switch failed and a circuit breaker wire came loose. Two uncorrelated, simultaneous failures. It does happen. H. |
| Thread Tools | |
| Display Modes | |
| OT but good..the death of Mr Common | BllFs6 | Home Built | 0 | August 25th 04 04:01 AM |
| General Zinni on Sixty Minutes | WalterM140 | Military Aviation | 428 | July 2nd 04 12:16 AM |
| Naval Air Refueling Needs Deferred in Air Force Tanker Plan | Henry J Cobb | Military Aviation | 47 | May 22nd 04 04:36 AM |
| Germany Lost the War... So What? | robert arndt | Military Aviation | 55 | February 26th 04 09:51 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
